Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
Dreadnought heavy Space Marines
 Post subject: Re: Dreadnought heavy Space Marines
PostPosted: Fri Oct 17, 2014 7:32 pm
And yet another attempt :)
Playable?
Incompertus, 3000 POINTS
Codex Astartes (NetEA Tournament Pack 2013)
TACTICAL [450]
6 Tacticals, Supreme Commander, Rhinos, Hunter
DEVASTATOR [350]
4 Devastators, 2 Dreadnought
DEVASTATOR [350]
THUNDERHAWK [200]
THUNDERHAWK [200]
SCOUT [150]
4 Scouts, Rhinos
LAND SPEEDER [200]
5 Landspeeder
THUNDERBOLT SQUADRON [175]
2 Thunderbolt Fighters
WARHOUND [275]
1 Warhound Class Titan
WARHOUND [275]
WHIRLWIND [375]
4 Whirlwinds, Hunter
PostPosted: Tue Oct 28, 2014 10:38 am
This looks like a common codex marines list. If you drop one of the devs and replace them with termis you will have the "standard" marines list... ;)
PostPosted: Tue Oct 28, 2014 10:42 am
Yeah, I kind of figured that out and got bored with the whole Idea :)
PostPosted: Tue Oct 28, 2014 10:47 am
PErhaps go something like this
DEVASTATOR [675]
4 Devastators, Supreme Commander, 2 Land Raider, 2 Dreadnought, Hunter
DEVASTATOR [350]
DEVASTATOR [350]
THUNDERHAWK [200]
THUNDERHAWK [200]
SCOUT [200]
4 Scouts, Rhinos, Razorback, Sniper
SCOUT [200]
WARHOUND [275]
WARHOUND [275]
LAND SPEEDER [250]
5 Landspeeder, Chaplain
PostPosted: Tue Oct 28, 2014 10:51 am
DEVASTATOR [675]
:sos :D
If you're going to fork out for a LR dev formation, don't cripple their movement as well!
PostPosted: Tue Oct 28, 2014 2:36 pm
They wouldnt do much moving I think....
PostPosted: Tue Oct 28, 2014 9:58 pm
Hmm, don't forget the use of Landing craft, which could deploy that 'heavy weapons' Dev formation anywhere usefull - like near the T&H objective of choice, or in position to provide Fire support.
PostPosted: Tue Oct 28, 2014 10:23 pm
Yeah you can do some very very fun things with Landing Craft (especially above 3k). They also can block LOS, being a WE, so you can put out some interesting deployment to reduce counter fire (even if it means sacrificing the LC)
PostPosted: Sun Nov 16, 2014 10:24 am
This is the list I ended up with:
DEVASTATOR [675]
4 Devastators, 2 Dreadnought, Supreme Commander, Hunter, 2 Land Raider
DEVASTATOR [300]
4 Devastators, Dreadnought
DEVASTATOR [350]
SCOUT [175]
SCOUT [175]
LAND SPEEDER [200]
5 Landspeeder
THUNDERHAWK [200]
THUNDERHAWK [200]
WARHOUND [275]
WARHOUND [275]
And work has begun:
File comment: And landraiders
File comment: Thunderbolts with squat airship in the background
PostPosted: Mon Nov 17, 2014 1:06 am
It is still deliberately hobbled though...
At the very least don't hobble the land raiders, and get a bit more transport it.
You have to drop a dred, but how about...
Tactical [275, 100, 75, 25, 150] [625] BTS & SC
6 Tac, Rhino, Supreme Commander, Hunter, Razorback, 2 Land Raider
DEVASTATOR [350]
DEVASTATOR [350]
So one less dred, but now your bts can move as otherwise it is just a bts guard and a points sink. It is also more survivable having 2 more models in the formation.
Another option is
Terminator [500] BTS
4 Terminators, 1 Chaplain (in a dred? :) )2 Dreadnought
Landing Craft [350]
Devastator (325)
4 Devastators, 2 Rhino, 1 hunter
Would have been with the theme to replace rhinos with dreds and have a hunter garrison but need 100 more points...
DEVASTATOR [350]
SCOUT [175]
SCOUT [175]
LAND SPEEDER [200]
THUNDERHAWK [200]
WARHOUND [275]
WARHOUND [275]
PostPosted: Mon Nov 17, 2014 12:48 pm
Thanks for the advice!
Everybody seems quite concerned with the mobility of that command unit. The way I figure - all the other units in this list are very flexible and have good movement. So I'm not to bothered that this unit may be hampered by the dreads. Every unit has its role.
I'm hoping to get in a battle or three in the beginning of next year, we'll see how it works then :)
PostPosted: Mon Nov 17, 2014 7:41 pm
It does have a role - just not a very good one! Instead of adding Land Raiders how about save some points for another dreadnaught in the dev formation by getting vindicators instead of land raiders? Currently you are paying a lot of points for armoured mobility you can't use.
Or even just drop the landraiders and have a landing craft instead of a thunderhawk! Tacticals, 2 dreds, 3 rhinos, 1 hunter. Could even switch a scout razorback in as well. Airdrop the formation in... Could put the hunter into a dev/dred/hunter formation that can garrisson forward. In fact there I would drop the SC, put the hunter and an extra dred into the dev with only 1 dred, and landing craft in a tac formation with 2 dreds, 3 rhinos and a chaplain. Scouts lose a razorback though.
PostPosted: Mon Nov 17, 2014 8:40 pm
Ahhh, I see an error... Need to redo again...
PostPosted: Tue Nov 18, 2014 12:25 pm
How about dropping the T-hawks for a landing craft, garrisson both Dev/Dread formations and flying in 6 tacticals, 2 dreads, hunter and 3 landraiders in the landing craft? (would need to lose the supreme commander though) :-\
PostPosted: Tue Nov 18, 2014 1:22 pm
You would lose an activation to do it though - I would just make the BTS cheaper and upgrade a thunderhawk to landing craft. In your idea though, does the codex list let you mix land riaders and rhinos on a landing craft?
Last edited by The_Real_Chris on Sat Nov 22, 2014 1:11 am, edited 1 time in total.
