Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2, 3
NetEA/EpicUK Chaos Aircraft
 Post subject: Re: NetEA/EpicUK Chaos Aircraft
PostPosted: Wed Nov 17, 2010 11:22 pm
Ginger wrote:
Although you can obviously cover this in the 5 min warm-up, this is one of those rules that seems to cause some confusion at regular intervals. It would be really helpful if we could put a definitive answer in the FAQ.
I summon the Epic Rules Committee!
*Spell words expunged from records*
PostPosted: Thu Nov 18, 2010 3:19 am
Ginger wrote:
It would be really helpfull if we could put a definitive answer in the FAQ.
+1
Some thing must be wrong. I have agreed with (and not butted heads) with Ginger on two threads in the past 5 mins. I will go see the doctor now...
PostPosted: Thu Nov 18, 2010 8:33 pm
Hellblades will stay at 15cm range for the NetEA list but drop to 3 for 200pts
www.epic-uk.co.uk
PostPosted: Thu Nov 18, 2010 9:23 pm
So we've come completely full circle, even though the whole reason for the initial change was because 3 for 200 (with 2x AP4/AT6/AA5@15cm) was too cheap?
Do we really need to go through the arguments again on value of 3 fighters vs 2 fighters?
Morgan Vening
PostPosted: Fri Nov 19, 2010 10:16 am
No we don't need to go through the argument again.
3 for 225 was the decision before but testing of that and of 3 at 200 with 30cm shots (which the recent discussions have generally agreed is superior) have shown that its not too good and would be fine at 200
www.epic-uk.co.uk
PostPosted: Fri Nov 19, 2010 11:06 am
nealhunt wrote:
Somewhat cheesy, but legal and effective.
Very, very cheesy! But then again, not a tourney player so don't expect it to be used often against me and I can always pick who I play against.
PostPosted: Fri Nov 19, 2010 11:08 am
Well before you get all sniffy about tournament players nobody talking about how they used the the tactic was a tourney regular
www.epic-uk.co.uk
PostPosted: Fri Nov 19, 2010 1:50 pm
Didn't mean it that way, Steve. I meant that outside tournaments I can play whoever I want and agree beforehand to play what I consider the sensible way to handle this kind of tactic. In a tournament the situation would be out of my control as I'd have to abide by tournament rules and umpire consideration. So wasn't complaining about tournament players, but rather the circumstances themselves. My post could have been less ambiguous though.
PostPosted: Fri Nov 19, 2010 3:33 pm
The recent discussion mostly said that the 15cm stats were more "Chaosy". Only two posters said it was better, and Stompzilla specifically caveats it's at least partly because it's cheaper. That you went with an option that wasn't listed, seems a little manipulative of the results. Personally, I'd prefer the 2xAA6+30cm at 200 be adopted to the 2xAA5+15cm at 200. But I wasn't given that choice.
I've heavily trialled Hellblades at the new(old) cost as both player and opponent, and I found them significantly undercosted. And now it seems we're back to square one.
Morgan Vening
PostPosted: Fri Nov 19, 2010 5:23 pm
I think its the case that against the majority of target (i.e. other fighters) the AA5+ is better - however against stuff with defensive AA its slightly worse (2 hits vs 3) given that defensive AA doesn't always take the attacker home.
However ground attack wise the 30cm version is far superior. I understand the sentiment that the planes overall are equal though that then raises the question of is the 30cm one correctly costed. Of course are the two abilities tradable? The AA is a bit more scarce now with more expensive oblits. Then again it hardly matters in the context of the list where you are seemingly always either going 2 fighters/2 WE or 1 spacecraft /2 aircraft formation/1we /1 aircraft formation/2we
