Post new topic Reply to topic  [ 99 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
New & updated Black Legion units
 Post subject: New & updated Black Legion units
PostPosted: Sat Jul 19, 2008 9:52 pm
This was only for an example how the stats could look like if we follow the lead of the Epic rulebook stats.
Personally i prefere WYSIWYG stats. This includes a change to the Rulebook Thunderbolt.
PostPosted: Sat Jul 19, 2008 10:27 pm
PG lets turn it on its head.  Chaos game out first, created by GW and the ‘blade was given a single shot 30cm AP5+/AT6+/AA5+ shot to represent its “reaper cannonsâ€Â
Tyranid air marshal
PostPosted: Sat Jul 19, 2008 10:36 pm
Quote: (pixelgeek @ 19 Jul. 2008, 21:49 )
Quote: (BlackLegion @ 19 Jul. 2008, 13:39 )
Because the already established Rulebook aircrafts are not true-gun. So why should be the weapons on aircrafts for newer lists?
This isn't any reason to modify the stats of the Hell Talon.
If it performs too well in playtest games then that is one thing. I don't recall there being any sort of consensus from the test reports that were posted regarding the unit so there remains little reason to change the weapon load and if it was going to be changed I'd like to think it was for game balance reasons and not because someone screwed up the weapon load for the TBolt.
That is like saying that GW made the marines missile launcher range too short at 45cm and making the chaos marine's range 60cm.
It doesn't matter if 60cm is the "correct" range of a missile launcher.  A precedent has been set by GW that should be followed, regardless of sense.
Tyranid air marshal
PostPosted: Sat Jul 19, 2008 10:39 pm
ragnarok got it :)
Personally i belive that there is a good reason behind the Epic Rulebook stats of every unit and that they follow some distinct pattern which new units should follow, too.
Either strictly the rulebook way or the WYSIWYG way.
PostPosted: Sat Jul 19, 2008 10:49 pm
Quote: (ragnarok @ 19 Jul. 2008, 14:27 )
Chaos players would be somewhat annoyed by these up gunned Thunderbolts.
If the point cost was appropriate then why would they?
PostPosted: Sat Jul 19, 2008 10:54 pm
This is really a gigantic red herring.
PostPosted: Sat Jul 19, 2008 11:01 pm
Because their Aircraft isn't WYSIWYG.
Why? Do you think the Rulebook stats where only made in this way "because they fit somewhat"?
PostPosted: Sun Jul 20, 2008 12:41 pm
Lets try in a different way
The 'blade is armed with a quad autocannon (AI stats) which is equal to 2 reaper auto cannons on a fighter mount so they get a bonus AA value.
Thus the 'blade has:
2x 30cm AT6+/AP4+/AA5+
The thunderbolt has a quad autocannon (so two twin atuocannons), twin linked las cannons and the option to take rockets or missiles on its wing hardpoints
Thus the bolt should have      but has
2x 30cm AT5+/AP4+/AA5+        1x 30cm AT6+/AP5+/AA5+
1x 30cm AT4+/AA5+                 1x 15cm AP4+/AA5+
1X 30cm AT5+                          1x 30cm AT4+
Now we can ignore the rockets and compare the guns:
blade
dual reaper 2x 30cm AT6+/AP4+/AA5+
bolt
1x 15cm AP4+/AA5+
So the blade has:
Better AP ability, despite having the same amount of AP weapons
   2x 30cm AP4+ Vs 1x 30cm AP4+ & 1x 15cm AP4+
Better AT ability, despite haveing less AT weapons
   2x 30cm AT6+ Vs 1x 30cm AT6+
Better AA ability, despite having less AA weapons
   2x 30cm AA5+ Vs 1x 30cm AP5+ & 1x 15cm AP5+
the only advantage that the bolt has is its 6+ save, which isn't that good if it is being out ranged.
Now if the blades dual reapers were range 15 with the same stats then I think that the blades stats would be okay.  More chance to hit, but much shorter range.
Tyranid air marshal
PostPosted: Sun Jul 20, 2008 3:04 pm
You can try but I don't see the relevance and don't see how the comparison is valid.
PostPosted: Sun Jul 20, 2008 3:19 pm
I think the two sides PG are
1) It doesn't matter what the stats are as long as its balanced points wise and list wise.
2) The stats should first reflect its power relative to other comparable units (in this case fighters), then you get the points level right.
PostPosted: Sun Jul 20, 2008 3:42 pm
Don't think that I don't understand the point. That isn't the case.
I just think that we should focus on testing and getting #1 done and if that doesn't work then attempt #2.
We're a bit stuck. The weapon load for the aircraft already caused a minor sh*t storm when I initially attempted to simply it so it seems that no matter what approach is used it causes people to complain.
Do I need to mention the testing again? :-)
PostPosted: Sun Jul 20, 2008 7:46 pm
No. The two choices are:
a) Pull some stats out of the ass. Background? Wh40k abilities? Which background? What is Wh40k? The stats are balanced for Epic and work. Point.
b) Look at Wh40k. Convert the stats, weapons and the abilities it has according to fluff into Epic stats. Come up with an appropiate number of units in the formation and a balanced points cost.
I stronlgy prefere b)
PostPosted: Sun Jul 20, 2008 8:26 pm
Quote: (Hena @ 20 Jul. 2008, 11:52 )
I'd offer c
Which is what we already have done :-)
PostPosted: Sun Jul 20, 2008 9:40 pm
I'd offer c
Yet my analysis shows that the blade is overpowered compared to the thunderbolt.
What is the justification for this extra level of power?
Tyranid air marshal
Users browsing this forum: No registered users and 93 guests
