Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 163 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 11  Next
Dark Angels
 Post subject: Re: Dark Angels
PostPosted: Sun Sep 19, 2010 10:29 am
Angel_of_Caliban wrote:
[color=#00FF00]DW Formation 400 points
May add 2 DW stands for +150 points
May replace any DW with DW Assault for free
Beleive me, anything which involves more expensive terminators is a burden, not a boon. You can try it yourself. Without the warhound and tbolt prop the cost of marine activations becomes critical.
2) Ravewing: I just don't see MM fitting well.
Really, why is that? The other versions give the long range power, those give the short range power and FF. Seems a 'balanced' close scouting formation that after all gets to point blank range and summons terminators!
3) Plasma: Will the NetEA ever consider changing that damn slow fire! Ugh! But really I think both Devs and Tacs should be able to replace with Plasma for free.
If it was 30cm 5/5 yes the freee swap would be fine. However with SF 4/4 its too much of a boost for devs.
4) Mortis: What are the official weapons again? I think Auto and Las should be the choices.
Problem with that is balance. The double las (2x4+) is weaker than the double autocannon (2x4/5). Also the double autocannon might be trickier to make than the missile launcher or las ones! :)
PostPosted: Sun Sep 19, 2010 10:49 am
You have a point from a Power gaming POV. But that's why its an +150 points option, for those fluffers! =)
Also any feeling on the DW Assault??
I think I mis-worded what I meant. It's a great formation, just MM aren't a DA-ish weapon. I feel RW would use more HB and AC than MM.
Maybe not for free than but still replaceable. 30cm AP4/AT6 No Slow would be ok?
Ah, See I didn't think of that. I don't like or use Auto's much. I would always pick Las. Then maybe ML and Las??
So are you (TRC)or BL Sub-ACing this thing nowadays???
PostPosted: Sun Sep 19, 2010 11:21 am
Oh the 400 is to take into account the fearless? (I have mentally deleted fearless from the basic terminators already!)
The assault would be a basic choice for a 3/1 formation. You have the shooting attack and otherwise have the boosted alpha strike. The second terminator formation might be standard but the first would always be this to account for the anti reaver and the like attack. And if the cost is to account for the CC you have in fact weakened the options. The assault terminators as a whole - I seem to remember in space hulk and 40k always trying to include a heavy weapon with the terminators reguardless of whether the rest had cc or storm bolters.
If it was up to me we would have plasma armed speeders from 1st edition! :)
4/6 is still a boost as the marines tend to use infantry to fight infantry, and thats a boost, especially as you like to be within 30cm!
The not for free thing just brings in min maxing.
I believe that is what it currently is :)
More like BL has the good ideas and I just tried to stop him playing 40k :)
PostPosted: Sun Sep 19, 2010 12:37 pm
30cm AP4+/AT6+ would be the WhES stats for Plasma Cannons.
And yes the current option for Mortis Dreadnoughts is 2 x Twin Missle Launcher or 2 x Twin Lascannon.
Yes you could do 2 x Twin Autocannons but the stats are identical to Twin Missile Launchers :)
Well the above list is a combined effort of TRC and me :) So we both are Sub-AC of the Dark Angels.
PostPosted: Sun Sep 19, 2010 1:08 pm
I thought the idea actually was 2 missile launchers, as the marine dred carries a single on each arm.
So 2x45cm AT4+ or 2x45cm AP5+/AT6+? 2x45cm AP4+/AT5+ is superior to both.
PostPosted: Sun Sep 19, 2010 1:13 pm
A right. Mortis has 2 "ordinary" Missile Launchers not Twin-linked ones. My bad.
PostPosted: Mon Sep 20, 2010 3:25 am
So what's your take on my comments BL???
PostPosted: Fri Oct 08, 2010 11:21 am
Haven't seen BL or TRC post the DA list for the NetEA book. Unloved or not ready?
PostPosted: Fri Oct 08, 2010 11:40 am
Not ready.
PostPosted: Fri Oct 08, 2010 12:11 pm
I think the list is pretty uncontenious, at least it is to me if I post it in a sec with my take on the suggestions above!
PostPosted: Fri Oct 08, 2010 12:15 pm
I think we only need to remove Fearless from the Deathwing Terminators (and add the second Assault Cannon) and thats it?
PostPosted: Fri Oct 08, 2010 3:27 pm
Well, I would for getting something published right this second reckon that this is 99% balanced. Some stuff is more powerful, but thats to try and compensate for the loss of warhounds and thunderbolts. Possibly the only too powerful formation is the ravenwing 1(s). But that's by 25 points if that's the case. The number of new units is cut right down but still the army builds and plays differently to regular marines. Anything remotely odd is gone, indeed I'd be happy to face it in a tourney as is.
darkangelsslowfire1.2.pdf [217.23 KiB]
Downloaded 482 times
PostPosted: Fri Oct 08, 2010 5:11 pm
Is the "Teleport Homer" rule really seeing much use? Just seems unnecessary to me.
PostPosted: Fri Oct 08, 2010 5:46 pm
It isn't in the EpicUK version.
However I have used it in the NetEA version as it can start garrisoned, so a turn 2 teleport after movement and firing turn 1 is very viable.
PostPosted: Fri Oct 08, 2010 6:03 pm
Still quite viable without it, it's the scouting elements that make it worthwhile, not the potential to re-roll an unlikely bad teleport roll; unless you're teleporting a lot of Terminators, this might effect one roll, one turn, per game. Again just doesn't seem needed.
Second issue, since the Masters all have fearless, shouldn't they cost a bit more than normal Marine Commanders?
