Feral Ork Boyz ! WAAAAAAAAAGGHHHhhhhh !!!!!
 Post subject: Feral Ork Boyz ! WAAAAAAAAAGGHHHhhhhh !!!!!
PostPosted: Sun Dec 28, 2014 11:30 pm
Just finished my one Feral Ork Boyz Mob ! Image Image Image Image Image Image
 Post subject: Re: Feral Ork Boyz ! WAAAAAAAAAGGHHHhhhhh !!!!!
PostPosted: Mon Dec 29, 2014 12:11 am
Lovely work L4!
PostPosted: Mon Dec 29, 2014 4:58 am
Coolness!
PostPosted: Mon Dec 29, 2014 7:46 am
It's great to see these go up just when I'm test painting my first Ork bases. I really like them.
I was wondering, dod you actually paint white in some of the tooth areas?
Also, it seems that you use a black undercoat and deliberately have it show through to show contrast. Is there any reason you paint this way, as coming from 28mm it is a different technique than I'm used to, but I'm thinking I may learn it.
PostPosted: Mon Dec 29, 2014 3:38 pm
I love your Ork infantry L4, they always look fantastic! The greens and browns in particular look superb :)
Reedar
PostPosted: Mon Dec 29, 2014 3:43 pm
Many thanx Boyz !!!! Yes, I used white for the "teef", I'd rather use an off-white as I'm sure F/Orks don't brush very much ! :o But I don't feel the off-white would show as well as white. Now for painting these Boyz and painting in general. I this case I base painted the figures in a light gray enamel. Then all the rest of the paints are water based. Then generally using various browns, tans, yellows, etc. ... Colors of furs, leather, skins, etc., paint trousers, boots, shoulder pads etc. each with a different color. Then wash with various colors of GW washes and inks. Then go back to detail and do a little drybrushing. In the process, I do a little "Black Lining" along the seams/edges, etc. using a very pointy brush with a little thinned down flat black ... To continue the bring out the details on the figures. And for detailing the skin I use a very dark green .... Hope that helps ... 8)
PostPosted: Mon Dec 29, 2014 8:06 pm
Looks good, I like the little conversions everywhere.
PostPosted: Mon Dec 29, 2014 9:40 pm
Thank U ! The E:A Feral Orks came with the furs, hats, different faces, etc. ... So with these Boyz I did no conversion work. It was a nice touch that GW took the time to change up the standard Ork figures. 8)
PostPosted: Mon Dec 29, 2014 11:32 pm
Very nice L4. Very nice indeed.
PostPosted: Tue Dec 30, 2014 1:14 am
These look great!
You planning on adding some boar boyz and squiggoths to these? ;)
PostPosted: Tue Dec 30, 2014 11:40 am
Your painting techniques are very different from mine it seems, but I'm definitely going to try some of those ideas out. Plus knowing that someone can paint their teeth convinces me that I should be able to try the same.
Look forward to more.
PostPosted: Tue Dec 30, 2014 4:31 pm
Yes, Mark I have Boarboyz in the line to paint as well as an E:A Orkeosuarus & FW Gargantuan Squiggoth. I painted up my Squiggoths a while back >
652051ea-708d-4141-9331-4ba1dbd9d79d_zpse79cb10b.jpg [ 154.81 KiB | Viewed 7603 times ]
PostPosted: Tue Dec 30, 2014 4:57 pm
Try it out ... for pieces with so much detail, it really brings it out ... I'm working on Feral Ork Nobz now.
PostPosted: Tue Dec 30, 2014 10:47 pm
Cool!
