Post new topic Reply to topic  [ 446 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 30  Next
Workbench of Leaxe - Orks, necrons and other races
 Post subject: Re: Workbench of Leaxe - Orks, necrons and soon KNIGHTS...
PostPosted: Tue Jun 05, 2012 2:35 pm
yes, right.
Depending on the outcome, I might still want put my hands on an otterware model. :)
This one might be too small.
PostPosted: Tue Jun 05, 2012 4:46 pm
It's neat, though.
PostPosted: Tue Jul 24, 2012 2:54 pm
the cheapest Tesco degreaser does a good job again...
PostPosted: Tue Jul 24, 2012 4:12 pm
wow works pretty well
give me that stuff ;D
PostPosted: Wed Jul 25, 2012 6:51 am
Experiment Nr.2 for this week failed...
I have bought lot of orkish infantry which were already glued to the long bases. They looked much too uniform. All alligned perfectly in a neat line. Wanted to remove them from the base.
I had two options. The glue was either superglue or plastic glue. It was not visible, only the bottoms were glued.
method 1: freezer
No effect.
method 2: Tesco Degreaser
Previously it worked like a charm on my 40K Ghazkull model. Eating the superglue perfectly.
No effect this time. Started to suspect that plastic glue was used.
method 3: debonder
Had no effect on the glue, but started to soften the base and the miniatures.
So, either I start cutting off some models or leave them as they are.
PostPosted: Wed Jul 25, 2012 9:53 am
if you don't mind cutting the bases up, you can often get them off by cutting the base next to the circular tab, then sliding a knife blade between the tab and base
I found that bending the bases into an arch shape helps loosen the models too
it's a ballache for sure, but probably not impossible!
PostPosted: Wed Jul 25, 2012 10:13 am
cut base in half. glue two halves together along a long side. fill in missing corners with putty = mobs of random orks
My shifting projects
PostPosted: Wed Jul 25, 2012 11:09 am
thanks for the tips. It seems I have to take drastic measures...
PostPosted: Wed Jul 25, 2012 11:20 am
This helps a lot old glue often breaks when bended
PostPosted: Thu Sep 13, 2012 8:21 am
I still did not manage to do anything remarkable, but I just have to share this with you guys.
The marine player did not like the original landing craft, so he kitbashed his own.
More:
https://plus.google.com/photos/10919397 ... 3879253841
A tank as a donor...
PostPosted: Thu Sep 13, 2012 8:28 am
I just see he created a topic for it. sorry.
THen I share all I did this summer. Will be a battle/gunfortress
I am building 4 of them.
Tiger tanks by Dragon
http://i299.photobucket.com/albums/mm31 ... /ork-2.jpg
http://i299.photobucket.com/albums/mm31 ... /ork-1.jpg
Still WIP
PostPosted: Thu Sep 13, 2012 8:50 am
looking good.... excited to see them painted up and ready to go!
PostPosted: Thu Sep 13, 2012 6:25 pm
awesome - that blue barrell needs more detailing though.
PostPosted: Thu Sep 20, 2012 1:14 pm
yep, true.
Everything will get more detail.
In the meantime I managed to update my ork stat cards. Some corrections, some new units.
As it is .doc, it is easy to adapt it to any army.
http://dl.dropbox.com/u/14514088/Epic/ork-cards-5.doc
PostPosted: Sun Sep 23, 2012 3:05 pm
Flames or residual heat from athmospheric re-entry? :)
Users browsing this forum: No registered users and 176 guests
