Post new topic Reply to topic  [ 303 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 21  Next
A beautiful (Hive) Mind
 Post subject: A beautiful (Hive) Mind
PostPosted: Mon Feb 26, 2007 5:33 pm
(Warmaster Nice @ Feb. 26 2007,16:25)
It's a new "Super Harridan" in the Tyranid list. :cool:
And it *rocks*!  I finally used one in a battle last night!
PostPosted: Tue Feb 27, 2007 6:10 pm
Oi !  Datz 'Uge !  It's going to take a lot of firepower to down that bird !  But IT will look great it the "flesh" so to speak !  :D
PostPosted: Sun Mar 04, 2007 11:42 am
Finished the Malefactors and also did a quick test assembly for the Exocrine. As you can see it is pretty huge compared to the old version - about the size of a Hierodule but I do like the design a lot. Also in NetEpic the Exocrine is listed in the Tank section rather than the Artillery section so I don't mind it looking a bit well armoured.
Lastly a size comparison: Assault spawns, Hierodules, Hydraphant. The Hierophant will be based on the Tyranid Warrior body but with some serious modifications for a more "Spidery" appearance.
PostPosted: Sun Mar 04, 2007 11:54 am
Wow that's big!
Very nice though - looking forward to seeing them painted :)
PostPosted: Sun Mar 04, 2007 1:00 pm
I was thinking the same thing when I started these. However since I wanted to redo all the Nid tanks I needed a standard size body for the stuff smaller than Hierodules (Assault spawn) so I decided to use the Warriors for Hierodules and Gaunts for the smaller stuff (Including the Trygon BTW)
There's a different problem with the Gaunts int hat their legs are very long so it is difficult to make them look "heavy" enough to make passable tank sized creatures.
PostPosted: Sun Mar 04, 2007 2:33 pm
The "Exocrines" would make good Heirodules....pretty huge for a normal "tank" though.
Fire bad, tree pretty - Buffy
PostPosted: Sun Mar 04, 2007 3:55 pm
I love you, man! :D  That exocrine looks the business!
A few judicious cuts should help in removing sections of the legs without leaving the remainder stumpy or too ill-fitting.  It still means some putty work, though.
PostPosted: Sun Mar 04, 2007 11:16 pm
this is fantastic work! im amased how much your getting out of the warrior sets.
also i think the balrog wings are availabe at ?6 a pair from mail order. as GW are now able to sell LOTR parts
Legio Nova guard: Finished
legio Storm lords: built
legio warp runners: un built
skitari: built
Eldar: in boxes
Orks: built, gargants painted
Ultra marines: 5 companies
Thousand sones: 5 companies (unpainted)
PostPosted: Mon Mar 05, 2007 1:34 am
Those are some mean looking bugz !
PostPosted: Mon Mar 26, 2007 8:51 pm
Well not a hell of a lot of progress singe the last update. I did make a single Venomfex (Regardless if they're going to remain in the list or not) and also did a bit more work on the Exocrines. I've also been tinkering a bit with a FW style Hierophant but I can't quite make it work...
Other news: I've got the parts for the Vituperator. A Glalrauch Chaos dragon tail, Red Terror body, Dominatrix head. I'm going to try and enlarge the Morathi Pegasus wings with greenstuff to make them suitable for the model. I figure a singe cm on each wing will do the trick. Werther or not I can pull it of is a different matter altogether :p
Also I got some Broodlord bodies for my Dactylis. Smaller than the Tyrant Guard these look pretty good for the job. Just waiting for some Genestealer Scything talons to arrive from Ebay. :;):
PostPosted: Tue Mar 27, 2007 12:19 am
Wow !  MoFo Ugly Bugz ... but Nice job, anyway ! :alien:
PostPosted: Tue Mar 27, 2007 1:46 am
Hi WN,
Amazing! I want some!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Mar 27, 2007 2:05 am
While you're kit-bashing, you might want to have a look at
http://www.mongoosepublishing.com/home/ ... sSeries=26
(The Starship Troopers 28mm line. ?Too bad they're not doing 6/8mm! ?But they do post their components online...)
It's funny how many similarities there are with WH40k, up to the point that the "Skinnies" have a suspiciously pointy helm!  But the "bugs" are buggier.
