Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3  Next
Anyone have any experience using dettol to strip minis?
 Post subject: Re: Anyone have any experience using dettol to strip minis?
PostPosted: Fri May 16, 2014 3:17 pm
They have Target in the UK?
PostPosted: Fri May 16, 2014 3:25 pm
Alf O'Mega wrote:
I used dettol for a while then switched to fairy power spray. I believe simple green might be an equivalent in the states? Dettol works but I found it kind of messy, and yes, running them under the cold tap can make things a lot harder!!
Fairy power spray for me now all the way - and it smells nicer too!
I have used simple green and it was the worst performer of the several thing I tested.
Easy off heavy duty oven cleaner was so good, I just dumped everything else.
The only thing I kept was pure acetone for metal models that are glued. Do not use with resin/plstic as the acetone will liquify them!
PostPosted: Fri May 16, 2014 3:32 pm
I have seen easy off sold in most stores like walmart or any super market.
I ran a search and an easy off equivalent in the UK is called "Mr Muscle Oven cleaner".
http://www.mrmuscleonline.co.uk/kitchen ... eaner.html
You have to specifically get the "caustic one" that you need gloves to use, the others won't work.
PostPosted: Fri May 16, 2014 3:54 pm
Yeah, thinking about it I think Fairy Power Spray is probably closer to an oven cleaner type product than Simple Green - anything that claims to bust grease is what you want!!
From what I understand Simple Green contains Pine Oil, which is also what Dettol contains, but it's the chloroxylenol (sp?) in Dettol that gets the job done...
PostPosted: Fri May 16, 2014 3:57 pm
Rug wrote:
It is more expensive than Detol but you can reuse it more easily as it isn't as messy (smell, gunk etc).
Wait, how do you re-use power spray? Are you dunking the minis in liquid power spray poured out of the bottle, or spraying it on?
PostPosted: Fri May 16, 2014 4:08 pm
I dunk and leave till I remember I put them in it!
@MephistonAG for all sorts of twitter madness
PostPosted: Fri May 16, 2014 4:17 pm
I use Simple Green available in hardware or even grocery stores for plastic and paint thinner for metal. Soak'm overnight ... then got at them with an old tooth brush ... repeat as needed ... then wash with soapy water ...
PostPosted: Fri May 16, 2014 4:54 pm
*re-evaluates his use of power spray*
I've just been spaying it onto things :(
PostPosted: Fri May 16, 2014 5:16 pm
yeah Simple Green has worked wonders. I've also used it on hard plastic too
PostPosted: Fri May 16, 2014 5:28 pm
Wow I've zero luck with simple green.
PostPosted: Fri May 16, 2014 5:50 pm
You're holding it wrong? ;)
PostPosted: Fri May 16, 2014 6:22 pm
Switch it off and switch it back on again?
PostPosted: Fri May 16, 2014 6:37 pm
Did you let it soak overnight ? :gah
PostPosted: Fri May 16, 2014 7:04 pm
For days.
Users browsing this forum: Google [Bot] and 40 guests
