Mars Forgeworld terrain ideas for 6mm Epic-40k?
 Post subject: Mars Forgeworld terrain ideas for 6mm Epic-40k?
PostPosted: Tue Dec 21, 2004 4:01 am
I'm looking for some ideas for Mars Forgeworld terrain at a 6mm Epic-40k scale.
- We've already built some base boards, a refinery, a landing pad / spaceport, and a factory. :)
*** Anyone have any other ideas? ***
*** What kind of terrain and scenery do you think would be found on the Mars Forgeworld? ***
- Any ideas how to build the terrain and scenery you think would be found on the Mars Forgeworld would also be highly appreciated! :)
Shalom and Thanks ahead of time,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Dec 21, 2004 7:59 am
-Airships: Like in Blade Runner, but displaying hymnals and devotional slogans instead of adverts.
-Arcane-looking Sensor Masts:
-HUGE chemical tanks:
-Huge pipelines:
-Monorails:
-Reservoirs of Toxic Goo:
-Slag heaps:
PostPosted: Tue Dec 21, 2004 8:12 am
I will never reveal the secrets of my home land.
Oh all right, then:
Huge Crawler:
- A very large tracked transport a la shuttle transporter.
- Use any 1/72 scale tank as a chassis.
Mega Crane:
- This one's at least three times taller than the Imperator.
- Use an old windscreen wiper with the rubber removed; this can be a mast if you just fix it in the ground, or a real crane if you construct a good anchor and base and winch
- Any pics of tower cranes or dockside cranes should help, as would plastic-card and loose odds and ends.
Transport Vehicles:
- Use Epic models or scale-similar stuff from others...
- But no trucks...
- Unless they have more than 10 wheels!
Walls:
- Fortress sections, based on any suitable fortress sections or made of (ideally) ceiling panels cut to size; with tech-areas scattered around
- Use bits of wrecked printers, circuits, etc.
COLOURS:
- Oh, and remember, all colours should be shades of red down to reddish brown, with sand and the occasional black and yellow stripes.
Oh, and send pictures - I'm homesick! :D :D
P.S.
- You could even add a small, sinister, skull bedecked, metallic colour shrine; remember the Dragon (no, not Bruce Lee, that C'tan type....)
P.P.S.
- THOUGHT FOR THE DAY: EPIC
- NOTHING IS TOO BIG FOR US (er - except a Repulsive class grand cruiser; or an Orc Hulk; or a craftworld...
Back from oblivion (again)?
PostPosted: Tue Dec 21, 2004 9:55 am
I'd go with all the above too, I've always pictured it, like the earth, as being entirely built on, no virgin ground at all, usually too with a blade runner flavour. Not really practical to actually play on so I suppose some abstraction would be required.
PostPosted: Tue Dec 21, 2004 12:03 pm
Well I can only add my voice to everything that's been said.
Most importantly Mars terrain should be dense and very BIG!
STEEL PLATING:
- I imagine large town squares or fields covered in steel plating (It could also be the roofs of even larger structures) which should be fairly easy to construct. Counts as roads for the purposes of movement.
PIPES AND GIRDERS:
- Pipes and girders everywhere.
SCRAP MOUNTAINS:
- Mountains of scrap and rivers of corrosive acid. All the wonderfull nasty stuff! :p
- Simply use crushed seashells and small pieces of cardboard sprayed silver and given a heavy wash of rusty browns and blacks for the scrap and rivers are pretty strightforward.
MECHANICAL FORESTS:
- A forest could be made out of cranes or robotic arms on a gigantic assembly line.
GIANT CONVEYOR BELT:
- How abouot making giant conveyour (SP?) belts large enough to carry a Titan which could count as roads only they allow a miniature to triple or half it's speed depending on which direction it is travelling?
GIANT SMELTING PLANT:
- You could have a giant smelting plant.
- Use coffee cups covered in textured paint painted in a suitable slag like grey and filled with plaster which you then paint orange/yellow/whiteish.
- Mount it among a bunch of girders or other supporting structures (maybe have one toppeled over with it's contents running all over the ground -this should count as impassable terrain!).
Oh, my: Now I feel tempted to have a go at such a project myself!
Anyway: just a couple of ideas :;):
Cheers! :)
PostPosted: Tue Dec 21, 2004 6:14 pm
Thanks for all of the ideas so far, guys!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Dec 21, 2004 6:49 pm
Temples, shrines, and/or cathedrals to the machine god would be a good addition.
PostPosted: Tue Dec 21, 2004 10:11 pm
I think there would be covered walkways between some buildings, monorail of some sort, many leveled roads, and lots of towers.
I think one thing I would do also is try and place a few "holes" or openings that give the illusion that there is a lot below the "table" level as well. Once I saw a board that had a few openings with pictures at the bottom taken from some Sci-Fi type movies. the pictures seemed to show many (more the 30) levels down.
dafrca
              - Cities of Death, page 59
Power plant.  All those things need power.
An easy way to represent a factory would be to make a area filled with exhaust pipes.  Along the lines of a a steel forest.
The exhaust pipes are from the factories that are under ground.  This way you only have to represent the pipes and not the factory themselves.   Which may be so large as to not be able to be represented on the board.   :D
Take Care
PostPosted: Wed Dec 22, 2004 1:32 am
*** How about a worshop pit/smeltery/refinery in the spirit of the LOTR pits around Orthanc where Saruman forged his armies? *** ?
That could be hard to get right on a flat atble, but what about inside a hollowed out mountain or inside an extinct volcano aka the Titan base in "Crusade for Armageddon?"
I like the shrine idea too! -
*** What about a temple built around an ancient machine-god: a Titan! ***
Tas
PostPosted: Tue Jan 18, 2005 8:35 pm
A bit late off the draw on this one but since thats the story of my life...
A giant Tech-Priest administration building/cathedral in the form of a pyramid...
Because after all whats Mars without pyramids? :laugh:
And in all honesty I do actually have a couple of old Grendel and JR Miniatures resin pyramids I throw on the table occasionaly just for a different look.
The Cheese! The Cheese!
PostPosted: Tue Jan 18, 2005 9:39 pm
Heh.  When my son came home from Burger King with a Yu-Gi-Oh toy packaged in a pyramid, my mouth started watering.
I went and bought 3 more, just to get the pyramid box they came in.  A masonite base, some gravel and a can of textured spray paint later and I have a set of 4 pyramids on 6" square bases for about 7 bucks in materials.
Plus, my son got to keep the toys.
PostPosted: Wed Jan 19, 2005 2:42 am
Pics!
