Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
Army builder software
 Post subject: Army builder software
PostPosted: Tue Feb 10, 2004 9:18 pm
Does no-one else do the basing first then? I find I tend to accidentally run the drybrush over the legs everynow and then so basing first makes things a lot easier.
I'm with da boyz too, since E40k, might as well run through my painting technique (for da standard boyz):
-clip, clean and glue.
-glue sand onto base
-spray black
-Do the bases: paint bestial brown liberally - chestnut ink - drybrush snakebite
-paint the clothing and shoulder pads scab red
-paint the skin goblin green (a sort of careful heavy drybrush so eyes and lip recesses aren't filled)
-paint the guns scab red
-paint the gun holding hand goblin green
-paint the bayonet boltgun metal
-highlight the clothes, guns and shoulder pads with blood red
-highlight the trousers codex grey (looks a little messy actually but is absolutely fine from above)
-paint the sides of the base bestial brown
-bleach bone round the big gun, then skull white (I find white doesn't paint well straight onto black)
-patch some watered down glue onto the base in 'grass-growthy-looking-patterns' and dunk in some GW flock (it's better than the local railway shop's stuff, imo... if about thrice as expensive :) )
I think that's about it.. I'm quite pleased with how it's turned out  especially as I can get through a whole formation in a couple of hours. Think I'll have a full painted army in no time at all :)
-Sam aka Garcon
PostPosted: Wed Feb 11, 2004 1:07 am
Well been playing/collecting Epic since SM1, so most (like 80%) of my 9 Epic armies (including 30 Ork Warbands) are based on the square bases.
And those are harder to paint than the long E-40K bases...
I learned the hard way... :{ Doh! :o
PostPosted: Sat Feb 21, 2004 9:54 pm
Why do the Hellbore, Moles and Termites, which did have a Firepower rating in Epic40k, not have any weaponry at all in Epic A?  I'm just asking, because it makes my Hellbore and Moles kinda useless in Epic A, and that sucks. :angry:
my 2cents,
iblisdrax
PostPosted: Sat Feb 21, 2004 10:26 pm
At a guess because they dont have any weaponry (that I can remember) sculpted onthe model - Its WYSIWYG.
As I recall, it was the trasporters & not the tunneler itself in most cases that got the firepower originally anyway wasnt it?  :oo
Paul "TuffSkull" T.
PostPosted: Sat Feb 21, 2004 10:34 pm
I brought up this problem with Jervis on the official playtest boards, and he said the same as Tuff, they don't have weapons on them, so they have no firepower. I was annoyed at this, as I have two hellbores myself!
The main purpose of them now is just to be used as another kind of troop transport.
Chris
Chris
PostPosted: Sat Feb 21, 2004 10:47 pm
Rrrr...that is annoying.  Especially in the case of the Moles, who have to stay attached to the formation that they transport.   hmmm, maybe the weapons are in turrets that pop up after the mole surfaces?  I'm going to think on this.
my 2cents,
iblisdrax
PostPosted: Sat Feb 21, 2004 11:21 pm
You could always just model some on and use the WYSIWYG rule... }:)
PostPosted: Sun Feb 22, 2004 2:46 am
Tunnelers are supposed to establish "beachheads" and centers of resistance.
Pretty useless if they dont have armament.
PostPosted: Sun Feb 22, 2004 5:40 am
In SM1 they do and in our Epic paradigm, they still do. ? However, the models have no visable weapons. ?But I did add some on my Hellbore ! ?So G/W can Stuff it !!! :laugh:  The weapons would probably deploy once the tunneller surfaces ... as suggested.  :;):  And with tunnellers, once they surface, the troops inside should be a separate detachment once they disembark ... that is the way we play it. :D
PostPosted: Mon Feb 23, 2004 8:16 pm
Per jervis, the original design (SM-era) was that none of the tunnellers would have any sort of weaponry, as all their internal space went to tunneling gear and cargo room.
They were badgered by the marketting guys into adding weapon stats on the grounds that no one would buy models that did not have weaponry.  So, they made up weapon stats even though the models had none and the designers didn't like the concept.
Since they are OOP and JJ was making fun-stats only, he went back to the original concept that they were merely underground versions of drop pods.
PostPosted: Mon Feb 23, 2004 9:52 pm
All SM1 Drop Pods had weapons too ... I see the designer vs. marketing conumdrum.   We however, still play that all tunnellers and drop pods have weapons ... go figure !  :;):
PostPosted: Mon Feb 23, 2004 11:27 pm
Drop pods STILL have weapons under net epic. There are troops transports, plasma cannon support and lethal "deathwind" missiles to clear landing zones.
PostPosted: Tue Feb 24, 2004 12:06 am
Same here ... even the Assault Pod has a weapon.   :;):
PostPosted: Tue Feb 24, 2004 12:19 am
Really? What kind of weapon you gave the assault pods?
PostPosted: Tue Feb 24, 2004 2:02 am
Whose to say that the post surfacing operation doesnt reveal fold down weapon turrets, exactly as drop pods do when they deploy?
Just because the model doesnt depict it in that way...
I would assume that they would at least have a small close in defence turret
Tas
