Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 148 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10  Next
Fir Iolarion Titan Clan List 2.1
 Post subject: Re: Fir Iolarion Titan Clan List 2.1
PostPosted: Mon Mar 14, 2011 8:39 am
its essentially TK: (4(-1 x (R/15cm)) where R equals range fired
or more simply, the TK value is reduced by 1 for every 15cm the weapon was fired
PostPosted: Mon Mar 14, 2011 9:53 am
Dughan wrote:
ok, this sounds like a good plan, but my question is, how exactly does teh fusion lance work. i may be tired in reading the stat line but what does 4-1 mean per 15 cm. i assume its like the original but the stats confuse me a bit.
JTG points it out nicely.
The depressing part is that my original working file is on my now crashed laptop. So now I have to start a new base file to work off of. Ugh! I really wanna try and 'fix' the extra attacks with the powerfist but with Chroma being MIA is might be awhile.
PostPosted: Wed Mar 16, 2011 5:18 am
Hey Angel of Caliban, you didn't put in stat lines for the eldar knights? are they the same stats that were on Chroma's draft?
PostPosted: Wed Mar 16, 2011 5:30 am
Yes....I only added stuff that was changed. Everything else is what is stated in the NetEA Eldar Book. I wanted to get the Titans down before trying to tweak the Knights.
PostPosted: Wed Mar 16, 2011 5:41 am
they look good so far.. I really like the stats on the old weapons.. so far they look appropriate, but i'm not a good number cruncher for seeing if the stats need to be lesser or greater.. still, a good approach to the list.
PostPosted: Wed Mar 16, 2011 12:50 pm
It basically means that the closer you are the more damage you do, within 15cm you do the full TK(4) damage per shot.
PostPosted: Mon Apr 18, 2011 10:50 pm
I’m disappointed that there’s such a wide gap between the standard lists and these titan-based lists.
The former limit you to 1,000 points of titans in 3,000pt games. The latter force you to take at least four titans (including scouts in single-titan formations) in order to get enough support formations to make it to 3,000pts. I’d bet a lot of people have one battle titan and two scout titans in their collection, plus a few aircraft, and they fall into the gap I was talking about where they can’t use all their stuff in a 3,000pt battle using either list.
Does that sort of “intermediate” list (one- to two-thirds of its points in titans and aircraft) not make for good games in practice?
PostPosted: Mon Apr 18, 2011 11:11 pm
You couldn't use them all in one game, but you would have the choice of which you used in any particular game. Players with both Eldar battle titans or multiple could use the list but not everyone. You could try proxing another titan for a bit to try the list out possibly? (an old friend used a coke can slightly crushed down to the correct height for a Phantom titan in a game once).
I think theming list and limiting support formations in titan lists is wise - they get to have lots of very killy titans, they need a downside! It's also a standard feature of the Imperial Titan Legions list too.
PostPosted: Sat Apr 23, 2011 7:52 pm
So, at exactly 60mm, it only causes a BM then? :D
I see from the Compilation that version 2.1.1 ups the cost of the Phantom and Warlock by 100 points. As there was a lot of talk about there not being enough difference between the costs of these 2, why didn't this end up as 850 for Warlock and 700 for Phantom? As it is now, the difference actually got smaller (percentage wise, anyway).
PostPosted: Sat Apr 23, 2011 8:15 pm
No at 60cm it would be TK 1.
Not sure what you mean about Titan prices. The points are off set for the need to buy your weapon choices. There isn't much difference of the Titans to begin with? Same size/DC. One just had Farsight and can take Psylance weapon from the Standard lists, In the ETC list I also allowed the Phantom to take a Wraithgate like the Storm Serpent. Making the Titan more different than before.
PostPosted: Sat Apr 23, 2011 9:51 pm
Mostly that the prices in this list and the version printed in the Eldar Compendium don't match.
Which one is correct?
PostPosted: Sat Apr 23, 2011 10:15 pm
This is the 'curret' list. When the NetEA books get released/put on on the website(soon) this is the one that will be in it. I sent it to Chroma Forever ago and that's one of the reasons why I haven't updated the list. I want the NetEA Books up before I keep tinkering and more playtests. The latter is just as much my fault as anyone else.
PostPosted: Sun Apr 24, 2011 12:32 am
Okay,
I like these prices better, but the version in the compendium says 2.1.1, so I thought it might be more current.
So, what are folks thoughts on the "ideal" lists?
PostPosted: Mon Apr 25, 2011 9:59 pm
Ive played a few games with this list now and one using the 2.1.1 list.
The biggest thing i find is the 1:1 ratio still is just to harsh, it need to be 2:1 atleast to make any decent viable lists in my opinon, also the spirit sword just seems like a moot choice of weapon when you have the power fist which i think is much better.
Also i dont really see a niche for the phantasm titan,its to simalar to the phantom and doesnt really fill any gaps or stand out in its own right as a "different" option.
Tim NZ
PostPosted: Mon Apr 25, 2011 10:00 pm
Is the list still crushing all comers? :)
