Tau vs Eldar, 2700 points
 Post subject: Tau vs Eldar, 2700 points
PostPosted: Mon Feb 06, 2006 12:20 am
Ginger, thanx for sharing your thoughts on the list design. Now, I have a better understanding of what you were trying to accomplish.
However, I'm still in disagreement with the approach.
Reason: You (TRC and yourself) keep trying one option to try and defeat the 5A approach, but completely discount the other option (taking fighters). I don't undestand this. A fighter is designed to eliminate other aircraft.
Also, for some reason, it seems like you and TRC don't think the air-to-ground capabilities of said fighter aircraft are of value once the TS have been run to ground. Why is that?
I guess I'm looking at the problem differently. From my perspective, the issue is "how do I prevent being ravaged by ground attack aircraft?"
You've already proved that a multitude of flak doesn't seem to work for the Eldar, but choose not to take one of the better assets capable of taking the TS on at an advantage.
So again, I see the point you are trying to make, but feel that the answer that is derived is predetermined because of the way the problem was addressed.
If you had taken 3 figher units and killed all or most of the TS, have you not in effect defeated the TS and allowed your ground assets to do what they need to do?
In conclusion (if it needs saying) - IMHO if an EA novice like me can beat an experienced player like Chris when we have done as much as possible to skew things against the Tau, the unrestricted TS is definitely unbalanced.
I disagree that you have done "as much as possible". Also, the statement is subjective. I'm not saying that unrestricted use of TS is unbalanced as that has yet to be demonstrated against all armies. I am willing to admit that against the list(s) TRC's opponents have fielded, that multiple TS have been the reason the Eldar armies were defeated.
The fact that only 3 a/c were needed to effectively strip the AA in the first turn in both games, even with appalling dice IMHO suggests that the stats themselves are too good in any event ? so as a game designer of several decades experience, I would respectfully repeat the suggestion of reducing the railguns to 1x MW 3+, TK(D3) 30cms, and probably restricting them to 1x TS per 500 air points.
Again, I feel like the case you've been making is that whenever the longer ranged gun on the TS attacks the AA asset, that you feel powerless to defeat the TS. After having run through that scenario several times, why do you continue to take the same approach to the problem?
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Tue Feb 07, 2006 3:42 am
Hmm Honda
I think I understand your points about the use of Air interception rather than ground AA - they will tend to cause more damage (2 hits per formation on average, but 1.33 ?damage assuming no jinking under average saves). So the TS attacks are still likely to complete even if successfully CAPed - and even then 2x air formations attack unopposed.
The probability is that the majority of the TS would survive to turn 3, and though their effect would be diminished, I am not conviced it would be totally countered.
However buying 3x air formations means that I have two less units to defend against ground units, so I suspect the end would be even swifter than before.
Finally we did try beefing up both the air formations and the ground AA in the next game with Orks - Batrep here but as Tau, I won that one even more convincingly, so I stand by my comments about the number of TS formations and the individual TS stats.
Please see my response to CS question on the stats. here
All the best
Ginger
PostPosted: Tue Feb 07, 2006 3:53 am
@Ginger,
I respectfully disagree, but would enjoy shaking your hand at the end of all this, regardless of the outcome.
Honda
PostPosted: Tue Feb 07, 2006 1:12 pm
Honda
Done mate ?:) - if you ever find yourself in London UK on a Tuesday night, drop into JD's Sports bar behind Mornington Crescent Tube station, and we'll yarn about "the good old days" over a pint ?:p - and possibly a game :laugh:
Ginger
PostPosted: Tue Feb 07, 2006 5:31 pm
I am painfully jealous of your club location. Honda, i think we need to explore new environs  :blues:
Did the Eldar give thought to perhaps subbing in a Phoenix  unit as well? that would give you the option of CAP or ground attack. Looking for your train of thought on this item as we are beginning to experiment with aerospace aspects as well (our groups is relatively new).
"Advance to the Rear!"
PostPosted: Tue Feb 07, 2006 6:01 pm
Gents,
CS will either limit the AX-1-0 in some fashion, point change them, or stat change them. Whatever the solution, continual testing of 5 aces at 3K really doesn't do any good for development at this point.
If we wish to test the AX-1-0 envelope, perhaps run two of them per 3,000 points. So either play 2 at 3K or play 4 at 5K games.
As 5 aces was based around 2700 and 3K games, 2 instead of 5 per 3K incriment should throttle down the results adequately. I'd love to hear how your games went in these modes - with the same flier that's already in v4.3.3.
Ginger, if you want to put the kabosh on TRC's 2 AX-1-0's per 3,000 points being played, take some fighters. You mentioned something about Jinking in Honda's recomendation of fighters.
The AX-1-0 is a bomber. Please note, bombers cannot jink. If TRC is jinking with it, well, that's a different problem that has nothing to do with the AX-1-0.
I think its fair to say that regardless of outcome, the 5 aces list will not live on. I look forward to your future bat reps - as well as seeing some fighters in Ginger's lists against TRC.
Ginger - just remember to take out TRC's AA first.
Rob
PostPosted: Tue Feb 07, 2006 6:06 pm
I've always been tempted by Phoenix. But, its a very pricy interceptor or reasonably good bomber. At 400 points for three its a risk as a lucky hit can bring you down a plane even with a 5+ RA save. In fact you have a 4/9 chance of being brought down by a flak hit, and you have 15cm range for the BP weapon.
So you have to really neutralise that flak to use them well. Against Tau it would have been tricky with 12 Ion Cannon Hammerheads ambling around.
PostPosted: Tue Feb 07, 2006 7:03 pm
Who says you have to take it all down TRC?
In order to counter, simply wait out the AX-1-0, he's not going to be sniping with it if you have fighters off the field. So he's limited to his own 45cm shots. He'll move the plane on somewhere. His AA will only support so far.
The figher will have its own range.
The opponent need only break a formation or two to significantly manage that area of the field.
Worst case, the AX-1-0 will have a lessor impact on the game and more of the Tau's game plan will have to be around protecting the AX-1-0 asset in that role.
All of which will have the desired effect, all of which say - bring the Fighters Ginger - make TRC's 2 AX-1-0's of the future think before try to claim complete air control.
Rob
PostPosted: Tue Feb 07, 2006 9:02 pm
Quote (Tactica @ 07 Feb. 2006 (17:01))
Oh I'm hurt at such an acusation!
I actually would have liked to play 5 TS vs 12 Thunderbolts. No longer any activation advantage for me, less planes flying around due to blast markers however I think I wouldn't have lost many TS :)
Unfortuently no more games for me for a while, Wednesday I return to Bangladesh and it seems the new location even lacks the internet :(
I don't understand your point. You mean wait on CAP as there is no way to out activate the little chaps when you have 800 points tied up in two fighter formations. Or do you mean to wait on to bomb?
Is this the Tau or Eldar bombers doing the breaking?
Luckily not that hard as we both love moving our hammerheads up :)
PostPosted: Wed Feb 08, 2006 7:39 pm
Guys and Tactica
Thanks for the advice - but as the Tau player here and also against the Orks, I did take out the opposing AA first - which is all to easy to do with large numbers of TS - as we all seem to agree.
You should also note that as Dysertes pointed out, the 2700 point lists were intended to raise the TS issue - which it did
Sadly, with TRC leaving London for a quite a bit, I may not be able to try out Eldar with both Phoenix and Nightwings on him in the near future, nor a 5000 point battle (the main issue being time - ?typically we only have around 3 hours to complete a game in the pub before we are chucked out) .
When I can pursuade others in the club to resume EA rather than other pursuits, I will try out some of the other stuff
All the best
Ginger
PostPosted: Thu Feb 09, 2006 5:22 am
Ginger,
You still going to [edit]weigh in while TRC is absent?
It would seem odd if you dropped away in TRC's absence as you've been echo to his many arguments recently.
To lose two of the same perspective at the same time would be impacting as we plow ahead with refinements.
Hope you can find a game or two of epic at least a couple times a month and keep us up to date on findings of the pub.
Rob
PostPosted: Thu Feb 09, 2006 6:56 pm
Tactica
I'm honoured and touched by your concern. I will probably continue to weigh in (as you out it) in as unbiased a way as possible. However this may be reduced given the circumstances, but you won't get rid of me all that easily :;):
All the best
Ginger
PostPosted: Thu Feb 09, 2006 7:11 pm
I second Tactica's comments, but don't make me beg. It'll embarrass both of us.
Honda
PostPosted: Thu Feb 09, 2006 10:20 pm
Ginger & Honda,
ROFLMAO!
Rob
