Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4  Next
Consensus?  Or maybe just what seems to be favored
 Post subject: Consensus?  Or maybe just what seems to be favored
PostPosted: Thu Jan 08, 2009 3:11 pm
So to save me from spending a lot of time trying to dig out this "Always popped up" deal? Is the difference that, Popped up is still subject to LOF?
Also, I read the Manta thread and I see where there seems to be a general agreement to tone down the firepower, although the discussion was not conclusive on what would be the new values.
Also there seems to be a lot of discussion on the Planetfall without a Space asset. This part always puzzled me. As I understand it to work, the Tau player rolls for activation, if successful, the Manta is then placed anywhere on the table. Then another activation must be taken in order to do anything with the Manta. Is that understanding correct?
So the only difference between how a Manta and a Moray work is that the Manta does not require a Space asset.
Is that everyone else's understanding?
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Thu Jan 08, 2009 3:18 pm
The unit is just treated as if it was "Always popped-up", so it uses the skimmer LOS/LOF rules in the Errata 2008.
No, there's only a single Action Test taken to deploy and activate the Manta via free planetfall; so roll to sustain fire, put the Manta in the best place possible and fire away!
There might be a provision that it requires an action with a "move" portion, but I don't know it that's correct.
PostPosted: Thu Jan 08, 2009 5:08 pm
From the LRB, 4.4:
You can make a planetfall on the turn the spacecraft
transporting the units enters play. Carry out the planetfall
after carrying out any bombardments and/or pin-point
attacks. Take one of the units with the planetfall ability
and place it anywhere on the table that is within 15cms of
the drop zone co-ordinates recorded at the start of the
game (see 4.3.1). The unit then scatters 2D6cms in a
random direction
and from the (fantastic) Raiders supplement
1.1.2 Free Planetfall
Free Planetfall is plotted exactly as Planetfall in
section 4.4 of the Core rules. Both the turn in which
the formation arrives and the landing location is
plotted. The only exception is that because these units
are much smaller than orbiting spacecraft they may be
plotted to arrive in the same turn that an enemy
spacecraft is present. On the designated turn the Free
Planetfalling unit is activated in the normal activation
sequence, as with Spacecraft. Nominate the action for
the formation and roll to activate. If the unit fails to
activate its arrival is delayed to the next following
turn. If the activation is successful, place the
formation at the plotted landing zone and determine
scatter according to Core Rules 4.4 as if it were a
normal Planetfall, including loaded units
disembarking up to 5cm. The formation’s action
proceeds as normal in all respects from that point. In
other words, the formation gets the “free moveâ€Â
PostPosted: Thu Jan 08, 2009 5:11 pm
So does that mean it's not "Place anywhere I want and Sustain Fire," but rather "Plot a point and hope I can do something usefull?"
PostPosted: Thu Jan 08, 2009 5:12 pm
On a side note: I think the SkyRay and StingRay should be merged. If the Tau had a dedicated AP-Missile Tank then surely the SkyRay would have this option in the Tau Codex? :D
However the SkyRay can mark a Infantry unit and fire a volley of Seeker Missiles at them (nowhere inthe 40k rules it sais that SM can only be fired ad vehicles). Thats up to six Strength 8, ArmorPiercing 3 shots. A single missile would be as effective as a downgrades Lascannon in Epic, so no AP value, but a volley of missiles should be as effective as an Autocannon.
PostPosted: Thu Jan 08, 2009 5:16 pm
Quote: (Onyx @ 08 Jan. 2009, 13:12 )
Zombo, I know you've read the 40K codex where it describes Mantas as the primary anti-titan weapon of the Tau... NOT just a transport.
Leave the solely transport stuff out of this as it is a completely wrong impression of the Mantas abilities.
In no way did I say the manta is "just a transport". Primarily a transport is what I said, so much so that it's described repeatedly as a "super-heavy dropship". Strawman arguments are not needed here.
Note that in 40k the Manta and A-X-10 are armed with an identical weapon, yet somehow in Epic the Manta (and Moray) get twice as many shots with it?
PostPosted: Thu Jan 08, 2009 6:48 pm
I guess the way I always looked at it was the Moray versions broke out the Railcannon and Ion Phalanx of the Manta into two separate chassis. In hindsight, perhaps the Moray should just field half of the Manta firepower and not have any transport.
Re: Always Popped Up - I'm Ok with this as a simplification and clarification approach.
Planetfall - Yes, thank you for memory restart. That was how I now remember playing it. Memory
So the most obvious choice to me for the Free Planetfall is just eliminate it. It's more of a nice to have/characterful addition, but seeing as how we'll probably have enough discussion on the final stats of the Manta/Moray and the attendant costs. Besides, that means we can dump two special rules for one (Support Craft/Free Planetfall for Always Popped Up).
Anyone else in favor of this approach?
Honda
PostPosted: Thu Jan 08, 2009 7:35 pm
Yeah, note that I only had always-popped up as a rule to be tested in my consensus list, not for certain use.
Consensus is to give it a go and see how it works ingame. It might work, it might not.
PostPosted: Thu Jan 08, 2009 7:48 pm
As far as downgrading the firepower of the Manta/Moray the easiest way is to change the Railcannons from 2 separate weapons to one twin-linked system.  The same w/ the Ion cannons, 3 twin-linked as opposed to six separate shots.  Essentially taking away a shot from each of them.
PostPosted: Thu Jan 08, 2009 7:59 pm
Yep, the railcannon is supposed to be twin linked rather than two shots.
PostPosted: Fri Jan 09, 2009 5:03 am
Ok, read the report and the attached thread.
My only comments on the battle were that I think the IG played too conservatively. My experiences against Tau is that you have to take the battle to them and keep them on the back foot, otherwise they get the opportunity to set up serious attack vectors and start ripping apart chunks of your army.
I did like the composition of the IG army, though it seems to be a very fragile combination in the face of long range firepower.
Regarding the "Always Popped Up" rule, it seems workable, but also prone to confusion and it might spur additional measuring that may or may not get annoying ("Am I closer to that or you?")
I will test this as soon as we get the rest of the list sorted out.
I'd also like to follow up on some of my and others earlier comments. There seems to be a strong desire by some to reduce the firepower of the Moray because it is too strong. I don't think that has been clearly demonstrated yet through game play. I am even more cautious about downgrading it if units are now able to hide from the Moray.
The key, which ever path is taken, is to ensure that the Moray is "right sized". By that I mean, it needs to be unique and it needs to be effective or there won't be any reason to take it (see Swordfish). If all the exercise does is reduce it's capabilities to the point where no one thinks it's worth taking, then the effort to correct the unit failed just as strongly as if it were left too strong.
The other thing to take into account when implementing change, is to not change too many variables at one time otherwise you make it extremely difficult to determine whether or not the desired result was accomplished.
So, I would be more in favor of leaving the values as is and then playtesting the "Always Popped Up" rule until a decision can be arrived at. The other possibility is to right size the guns (i.e. half the eventual armament of a Manta) and then play against the current Support Craft rule.
The other thing I am thinking about is removing the FF value. To really model an "aircraft" type vehicle, are FF values appropriate? I'm thinking not. I'd be interested in what others think on that.
Honda
PostPosted: Fri Jan 09, 2009 7:44 am
Well the Moray already has half the armament of the Manta in a sense.  It either gets the Railcannon OR the Ion Guns, not both.  The Moray should find its niche in between the Manta and the AX-1-0.  Once those two are figured out as the high and low end, it should be easy to get it somewhere in between.
It would be nice to see a cheaper Manta as I think they would see the table far more often and they are a beautiful model.  That can be done while still representing the firepower it is described as having.  A 700 - 750 point Manta should be very doable.
PostPosted: Fri Jan 09, 2009 3:22 pm
Agreed. In the discussions I was reviewing, there were general comments on fitting the Manta weapons to more closely align with what has been published. From there, we just have to break the weapons suite in half (basically) and give the Moray EITHER the Rail cannon OR the Ion phalanx.
If points need to be adjusted, then fine, but I would propose leaving the points on the Moray as is, with the adjusted weapons and then trying the "Always Popped Up" rule and see if we are close.
Honda
PostPosted: Fri Jan 09, 2009 3:42 pm
A really important thing for any potential playtesters to remember with this Always popped up thing - they MUST use 12 terrain features as described in the Tournament scenario.
Anything else will be a waste of time.
I believe, that with 12 terrain featurs, Always Popped Up will render Support Craft next to useless and a waste of points.
I hope to be PROVEN wrong though for the sake of the list.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
