Post new topic Reply to topic  [ 4600 posts ]  Go to page Previous  1 ... 223, 224, 225, 226, 227, 228, 229 ... 307  Next
 Post subject: Re: Onslaught Miniatures
PostPosted: Fri Jan 24, 2014 10:09 am
Love 'em :). Go with the flow
" we have had flu for 3 weeks and kid also has both ears infected. Not much hobbytime here"
PostPosted: Fri Jan 24, 2014 10:20 am
nice
PostPosted: Fri Jan 24, 2014 11:20 am
I like those barges, only the infantry embarked looks a bit static. I imagine them to be a bit more agressive, more or less ready to jump off...
Very nice indeed these minis!
My tabletop-blog (in German): http://menofleadandplastic.blogspot.co.at
PostPosted: Fri Jan 24, 2014 1:30 pm
Thanks for the feedback gents -
ForgottenLore wrote:
How is it meant to work? Will it have engines that thrust it forwards while it uses the big sail rudder to steer left or right?
I assume the riders are just to demonstrate where they would sit and the finished version will be empty apart from crew? I wouldn't want riders on there.
You got it about the sail function - each will have engines attached, the sails will direct the exhaust.
All those crew are just there to make sure I have it scaled properly.
PostPosted: Fri Jan 24, 2014 1:57 pm
I love these, they should be awesome once detailed. Please don't change them too much.
PostPosted: Fri Jan 24, 2014 2:07 pm
Moredakka is a wise man and should be listened!
PostPosted: Fri Jan 24, 2014 5:15 pm
I take it the second one won't be transporting any troops? If so, is there a reason it needs to be as big/the same shape as the first?
PostPosted: Fri Jan 24, 2014 5:42 pm
I'd like them to share the same chassis - makes production less expensive and much faster.
PostPosted: Fri Jan 24, 2014 6:33 pm
Perhaps add a vision slit at the top rear of the front and a back hatch or top hatch encasing the driver in the prow in full protection?
PostPosted: Fri Jan 24, 2014 6:42 pm
oh yeah - there's lots of detailing to be done - this is a very basic rough draft.
PostPosted: Fri Jan 24, 2014 6:49 pm
I'll just say, since a couple other people did, that I'm not a fan of the "open-topped floating sail barge" approach to combat vehicles. I do plan on buying Stygians, just not the vehicles. To each his own and it's not like I won't be getting lots of other Onslaught minis. (With that said, given that you're going to go down that road, these are very well executed.)
I realize that this is a popular concept, so I won't say more.
PostPosted: Fri Jan 24, 2014 6:57 pm
There will be additional vehicles that may fit your tastes down the line.
PostPosted: Fri Jan 24, 2014 9:18 pm
Of that, I have absolutely no doubt. Great work so far!
PostPosted: Fri Jan 24, 2014 10:44 pm
Shut up and take my money, sir.
Seriously, these are awesome as is. I really like the vaguely shark-like effect that the sails give.
My name only suggestion is if the central gunner were removed and the gun mounted in or under the vehicle nose. Either on a helicopter-esque chin mount or a fixed mount like an A-10.
I think that does 2 things. First it further differentiates from the source inspiration, while still having the same style, as the gun would help give the same profile the shock prow does in the origin model. And second it would help reinforce the shark effect you get from the sails. Might also give you some extra room for the troop and/or extra gun mounts.
PostPosted: Fri Jan 24, 2014 10:57 pm
good ideas, let me play around a bit.
