Terror question
 Post subject: Terror question
PostPosted: Fri Jul 06, 2007 9:53 pm
If i understand well, one of the most important benefit of the terror, is that the target that is charged cannot shoot in response, even on first fire.
One of my eternal adversary is a fellow GI player, so he's a fond of snap fire, even with the -1 malus, it's still hard to reach him alive.
Today i played tyranids for the first time, and the bio titans cause Terror. We have a discussion about this.
Are titans subject to terror too?
For exemple you run on a titan on first fire order, he still cannot shoot as a normal target? My friend says "no, titans doesn't make moral test so they are immune to psychology". I say "yes, they are just unbreakable as they are lone target, but the crew is still frozen by fear".
And for realism, the way that terror work is a bit strange:
For exemple, tank A, B, C are on first fire. You run on tank A with a blood thirster. The Tank A cannot fire because of terror, but the 2 others can. How does the tank crew knows that only A is the target? (In the case that the thing making the terror is very fast).
Why the tanks cannot shoot before the thing comes too close (for example, a bio titan can make 50cm in charge, so a target in first fire could shoot it before knewing he's the target...)
But for games purpose i understand it is hard to make terror a rule easy to apply. We thought about a zone area. For exemple, targets of the same or lower class around 15cm of the target cannot fire at it when it moves, but that's still crappy for something who moves 50cm and could be snap fired before it reaches the main target...
Thanks in advance for your answers.
PostPosted: Sat Jul 07, 2007 2:55 pm
Took me a while to find the definitiive answer for this one.  Core rules, P32, FEARLESS.  As a Titan has no Morale value ( it is a - ), they never have to check for morale effects such as fear, terror etc.
Fire bad, tree pretty - Buffy
PostPosted: Sat Jul 07, 2007 6:10 pm
So it can snap fire? I know he cannot go on fall back but there is no rules about moral & firing.
PostPosted: Sun Jul 08, 2007 5:56 am
If the Titan is on First Fire why would it bother?  It can still shoot normally in the First Fire phase as it is immune to the Terror effects.
I would say anything could snap fire at the charging GD, but you would need to declare as soon as your opponent says he is moving the GD, not after you know who he is charging.
PostPosted: Sun Jul 08, 2007 10:40 am
Ok, sounds good like this. Thanks again !
