Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
Net Epic Evolution Playtesting
 Post subject: Net Epic Evolution Playtesting
PostPosted: Sat Nov 16, 2013 11:28 am
I haven't posted much in the way of battle reports for Net Epic Evolution so people may be forgiven for thinking that I have given up on playtesting. Nothing could be further from the truth! Unfortunately I haven't got time enough on my hands to post up proper battle reports at the moment but I'm using this thread just to report back on ongoing Net Epic Evolution playtests.
I played a Eldar v Squat 4,000 point battle during the week and despite the result going against me again (I was Eldar) the game was thoroughly entertaining and despite a terrible start for the Eldar, ended up being a close affair fought over three turns. As usual, the ridiculously high break point thresholds greatly aided the Squats, although they were frustrated that my Warlock Titan would not die! Both wing weapons destroyed, head damage that quartered the Titan's CAF and the legs completely crippled and yet it survived the battle! It pretty much came down to a struggle for an objective in woods, and was decided by Squats getting some lucky rolls as Striking Scorpions attacked them. 3 out of 4 Scorpions were slaughtered by snap fires and the objective was lost, ending any chance of victory...
Today I'm back as the Orks in a 5,000 pointer against Squats again. I don't mind my miserable run of defeats continuing if I get another battle that's half as enjoyable!
 Post subject: Re: Net Epic Evolution Playtesting
PostPosted: Sat Nov 16, 2013 3:23 pm
I'm in one of those "off" points at the moment. I'm putting together stuff for a new online RPG campaign, so once I get that done I'll get a play test in. :)
PostPosted: Mon Nov 18, 2013 12:15 am
No probs Primarch! I look forward to more in due course! Unfortunately my game fell through yesterday, but there'll be another during the week!
PostPosted: Wed Nov 20, 2013 8:05 pm
I know now that Orks can win! The bad news is that my IG lost to them in a 5,000 pointer. My miserable run of results continues... :'(
On the plus side, Net Epic Evolution continues to work sucessfully! :)
A new problem occurred to me about Titans going back to standard orders. Under Evolution it makes Praetorians more powerful than Titans because the Praetorians can move 10cm + gain the advantages of First Fire. Therefore, to correct the disparity I propose the following:
Titans may act as though on first fire when on advance orders provided they move no more than 10cm.
This fix may not be perfect but it provides Titans with the same benefits as Praetorians whilest protecting Eldar Titans, eg a Eldar Titan on FF is unfairly penalised in terms of holofield saves. This way the Eldar Titan gains the FF bonus even though benefiting from Advance saves for holofields.
I'm determined to even up the power of Titans with those of Praetorians but at the same time making sure that the overpowered Charge/First Fire situation doesn't arise again. Thoughts?
PostPosted: Thu Nov 21, 2013 4:26 am
I'm going to think about this. I believe a new mechanic needs to be made for titans to fit into NEE. Neither orders or plasma is going to cut it.
I'm mulling over a couple of options, all I need is to make sure they don't have obvious shortcomings.
PostPosted: Thu Nov 21, 2013 9:20 am
I'm intrigued! My main concern is no firing beyond the usual advance rate of a Titan, that's what caused absolute mayhem with my playtests.
I await your findings with interest! :)
PostPosted: Thu Nov 21, 2013 5:53 pm
I think we continue to have trouble with them because we want to still force some kind of orders on them. In a combined activation system things change considerably. Since we already have units that break that rule (praetorians) you are either forced to make praetorians have orders too (an option some might find unpalatable) or come up with a special rule/mechanic for how titans work.
What is comes down to is we want something that doesn't permit them to move to fast and fire efficiently. I'm trying to decide what the best fix is, perhaps without another subsystem. Although a subsystem may be the way to go.
PostPosted: Thu Nov 21, 2013 7:14 pm
You don't think my suggestion above provides a reasonable fix? It would mean no changes would be required to the Praetorians.
PostPosted: Sat Nov 23, 2013 8:13 pm
As I recall, Praetorians do not need orders in normal NetEpic either, whereas Titans do, therefore making Titans require orders in this version shouldn't be broken or unbalanced.
If Titans do require orders, then they should be held to the normal rules for those orders. Phantom Titans should have to choose between having a better Holo save or shooting better. It's part of the strategic challenge.
Net Epic Coordinator
PostPosted: Sat Nov 23, 2013 8:48 pm
There's a bigger advantage to being on First Fire in this new version of Net Epic (you get a +1 on to hit rolls). I'm not happy that Praetorians get to move and gain this advantage when Titans do not. It particularly annoys me because Praetorians are far cheaper to buy than Titans.
I think there is a general consensus that there is a disparity between the Titans and Praetorians - it's why the Titan Plasma rules were devised - but getting the perfect balance for the Evolution ruleset is proving to be frustratingly elusive so far! :-\
I have every confidence that we'll get there in the end though!
PostPosted: Sun Nov 24, 2013 5:21 am
I'm getting sidetracked with some family stuff this weekend Bissler, so give me a few more days to lay out some options.
I'm inclined to given them no orders like praetorians, with a twist (that I am still mulling over), while avoiding the "move to fast and first fire" problem.
PostPosted: Sun Nov 24, 2013 3:37 pm
Well, there is your answer then. Praetorians move and shoot as if they are on charge and first fire. The keywords there are "as if". Being that they do not receive order counters, they could be excluded from the bonus to hit. For fairness sake, you'd also (probably) want to just flat say that any unit that does not receive order counters does not get the bonus to hit. This would mean that Command units would lose the bonus, but they already get a lot anyway.
Alternatively you could require that a unit not move at all, regardless of orders, to receive the bonus to hit. This form would allow Praetorians and Command units to still get the bonus, but only if they do not move.
Another alternative could be to make Titans have a fixed Move value like Praetorians do. That is, their Move would not double for being on Charge. This could allow them to use the rule of not receiving orders and still be balanced. You would probably want to increase Move values slightly (perhaps +5cm generally and +10cm for ones with Agile or similar).
After all, what is a Titan except a semi-sentient Praetorian mounted on legs? They both use hit location templates, perhaps their rules should have more in common than they currently do.
As a note, while any of the three ideas above could solve your problem, using both #2 (not move) and #3 (fixed move) at the same time might be a good idea as well.
PostPosted: Sun Nov 24, 2013 6:20 pm
No fair Magnus your divulging all my secrets!! ;) ;D
Magnus is on solid ground with his thoughts as I have been pondering the same things.
1. Titan need a flat move, perhaps with a small extra move bonus (5, 10 or maybe 15 in case of eldar and bio-titans)
2. Praetorians, should not get the first fire bonus unless they do not move.
In essence what Magnus proposes.
The only thing I was left pondering if I wanted to continue using orders for titans and what they would entail and if I wanted to alter the existing plasma rules to fit the new paradigm.
However if the simplest thing was enough, want Magnus mentions (with my modifications) would be enough:
1. Praetorians only gain the +1 bonus if it doesn't move. Praetorians due to size and slow speed ALWAYS grant a +1 bonus to hit them.
2. Titan use standard order. For any given orders it may move its standard base move (use the titans current base move), thus:
First fire: moves base move, may fire receiving the bonus and penalty related to first fire. May only fire before or after movement (may not fire during movement, this simulates staying still for increased accuracy).
Holofield save 5+
Advance: moves base move +5cm for imperials and orks, +10 for tyranids and eldar. May fire at any point of movement (allowing to fire and use cover). No penalties or bonus to to hit roll.
Holofield save 4+
Charge: moves base move +10 for orks and imperials, +15 for eldar and tyranids. May fire at start or end of move, not during move with a -1 penalty on all to hit rolls. All weapons that may scatter, automatically scatter the maximum distance. One shot weapons and plasma weapons may not be used since the time it takes to prime these weapons is longer than the time a charge order provides
A titan should be able to fire under all circumstances, so I gave them a fire option under charge orders, but with a penalty and restricting what can be fired. I think it gives all orders for titans a tactical value.
Thoughts?
PostPosted: Sun Nov 24, 2013 8:27 pm
We need a facepalm smilie! Excellent idea chaps! Ok, into the nitty gritty...
This fixes the problem outright. Perfect.
Holofield save 5+
Holofield save 4+
Thoughts?
If we limited charging Titans to firing only at the start of their move, all my issues about firing on charge would be resolved. The problems have been because of them getting far too far up the board and then unleashing their arsenal. If we applied this one tweak then I'd be more than happy for all other Titan rules to be applied as they currently stand - though I think the -1 on rolls to hit should also be thrown in for good measure. After all, that was the rule in Adeptus Titanicus...
PostPosted: Sun Nov 24, 2013 9:07 pm
Holofield save 5+
Holofield save 4+
Thoughts?
I think that's an excellent suggestion. Firing limited BEFORE move on charge orders. I like that. :)
I think each order is distinct with a balance.
First fire gives a bonus, but grant one too. They can't move to far.
Advance grants no bonus, nor grants one, but you can move farther and shoot as you move. Very useful and should be the default order.
Charge lets you move farther and fire but before you move and at a penalty.
Sounds good to me.
Now to do some testing. ;D
