[BatRep] Tau vs Eldar (2ooo)
 Post subject: [BatRep] Tau vs Eldar (2ooo)
PostPosted: Sun Dec 18, 2005 8:13 pm
So I got a chane to play my Tau yesterday.  It wasnt against Tyranids or AMTL like I originally though thouh.  I had to run a couple Confrontation games (I'm the Sentinel for the area, much like the Grey Knights/Outriders), so I didn't play right away.  A friend showed up who wanted to learn pic so he gave a run with some Eldar.
Epic Tau 2000 points
Battlesuit Cadre
Shas'o
+2 Crisis Suits (475)
Fire Warrior Cadre
Devilfish
Ethereal (375)
Armoured Cadre
+2 Hammerheads (500)
Stealthsuits
+3 Stealth (400)
Barracudas (250)
From memory he had:
2 Guardians squads with Wave Serpents, an Aspect host with WS, some Warp Spiders, Falcons and a Revenant.
We only managed to squeeze in two full turns beofore the end of the day, but at least it was something.
He won Strategy first turn.
I set up with my HH's in the center of my table edge, Firewarriors were off on the left in some ruins near an objective.  My Crisis suits were off the right, with my Barracudas in support of the suits.  The Stealthsuits were off on the left table edge, and the teleported in on the first turn, receiving a blast marker in the process.
First turn he advanced an aspect squad of Banshees and Scorpions in WS toward the objective in the center of the table with no cover, and unloaded.  The Warp Spiders advanced into some ruins on the left, taking an ojective, while some Guardians on the right adcanced forward and unloaded.
I responded with my HH's up the center, taking out 3 of 4 WS, and taking out a few stands of Aspect warriors.  Next the Stealthsuits advanced on the Warp Spiders and took out about half of them.
This time he activated his Revenant and advanced him forward firing into the Hammerheads.  He only took three out for the time being.  I dno't recall what else happened here at the moment.
I activated my Firewarriors giving them shots into the Falcons that he had moved in the direction of the Stealthsuits.  The Devilfish took out two Falcons, I was rolling exceptionally well today.  My Crisis suits advanced towards his Guardians on the right, nearly decimating that unit.  My next activation sequence the Barracudas would swoop in and finish off the Guardians causing the remaining four stands to break.
I won strategy second turn, activating the hammerheads, and finishing off the Scorpions and Banshees.  My crisis suits took the objective on the right.
He activated the Revenant, who took out all but two hammerheads, which broke.  I don't recall what else was done, though he took the Objective in the enter of the table.  I managed to wipe out the Warp Spiders and take the Objective on the left, though it was soon contested by his Falcons.  At the end of turn two I controlled 2 Objectives while he had 1.
All in all I learnt a lot.  For 2000 points upgrades are not neccessarily worth it.  It's nice having all those shots, but having more units would have been nicer I think.  Thankfully we were pretty eqal in the number of Activations we each had, but having more would have given me a tactical advantage.
My Crisis suits were worth it, but I could see in larger point games where they might be out of their league.  Luckily we play on a scenery heavy table so they get tons of cover to advance in to get close.  And since they were going to take out Infantry it was perfect.
The other good thing about yesterday is that I picked up a ton of Epic Tyranids for $50CAN.  All the infantry is painted, and very well, and there's is a ton of bug tanks and 4 of each bio titan.  So now I need to make a list and see what I have to trade.
PostPosted: Mon Dec 19, 2005 11:41 am
Breten,
Nice synopsis of the battle.
Battlesuit Cadre
Shas'o
Fire Warrior Cadre
Devilfish
Ethereal (375)
Armoured Cadre
Stealthsuits
+3 Stealth (400)
Barracudas (250)
This is a nice "one from column A, one from column B" list that gives your opponent a chance to see various aspects of the Tau list.
I don't really know enough about the Eldar to comment on their composition, but it seemed like a nice mix of units as well.
All in all I learnt a lot. ?For 2000 points upgrades are not neccessarily worth it. ?It's nice having all those shots, but having more units would have been nicer I think. ?Thankfully we were pretty eqal in the number of Activations we each had, but having more would have given me a tactical advantage. ?
I originally felt this way as well, however I think a balance needs to be struck in the smaller point battles. What I think I discovered is that in lower point games, lots of small units break just as easily as in higher points games, however their loss (or lack of use) has a larger impact.
I do agree that more activations is better in general as well, but I think you want to steer towards having one or two more, not a bunch more. JMO
What I currently am looking at (for lower point games), is one larger primary formation that has some depth to it (e.g. FW+HH+PF), with the other formations acting in support.
The smaller formations work like a shields and/or rapiers and set up the larger formations hammer blow, which also tends to have a greater effect at lower points.
Given what figures you have available, you might consider a nice sized crisis cadre, backed up with hammerheads and FW cadres. Did you use the Ethereal at all? What was its impact on the game if any?
My Crisis suits were worth it, but I could see in larger point games where they might be out of their league. ?Luckily we play on a scenery heavy table so they get tons of cover to advance in to get close. ?And since they were going to take out Infantry it was perfect.
I have not played with these a lot, preferring a more mechanized approach. However, my impression of them is that they are fairly fragile and in larger games there tends to be enough other nasty stuff around to really give them heartburn.
You may also discover as I did, that despite GW's attempts to make them nastier in 40K, a couple of girl scout troops with butter knives really mess up their day.
Thanks for posting.
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Mon Dec 19, 2005 1:48 pm
Interesting ... thanks ! :D
PostPosted: Mon Dec 19, 2005 5:56 pm
I did use the Ethereal, and I will likely pass on him next time.  My Firewarriors didn't even take a shot, sitting garrisoned at an objective, only firing on the Falcons once.  And it was only the Devilfish that could hit the Falcons.
And I agree on Activations.  I meant having another 1 or 2 more than my opponent would have been better.
I'll definately be building my force around a core of two Crisis squads.  My group of people like a lot of Infantry as their core squads, I haven't seen a lot of tank heavy forces.  Most guys don't even use aircraft.  So I've warned them if they'll be playing my Tau they better be prepared for it.
The Tyranid force used yesterday didn't even really have any tank bugs in it, mostly Infantry.
I definately like Hammerheads, but man are they fragile, not having RA.  Granted mine were taken out by a Revenant.
And I need to work on the Coordinated Fire and Markerlights.  Need some Piranahs and Tetras.
PostPosted: Mon Dec 19, 2005 8:15 pm
First - thanks for the report!
My findings like yours are that HH are fragile, but their FP is a must have in our list. You want to use them wisely, take advantage of popup and cover. It means you probably aren't going to be using sustain fire all that often, but it also means keeping them alive.
Stand alone Crisis squads are small and can be fragile the larger your games get. IMHO, their short range is very limiting without significant cover on the field for them to hide in/behind.
Stand alone crisis squads seem to get chewed up quick. Something I'd like to try is 1) four crisis base with 2) FW +Devilfish upgrade 2) Ion-HH upgrade and 3) Stingray upgrade.
This would be an uber expensive formation, but I'm bound and determined to find a way to field the crisis that's appealing to me. I absolutely love them as my main fighting force in 40K, however, their value is quite nerfed in E:A by comparison until you get close. So... there's got to be an answer. I do not think it lies in stand alone crisis. If you are looking for a cheaper formation, try Crisis + Drones. Drones act as ablative for them and that may help. If you want to give them an anti-infantry punch, give them stealths too.
The Rev titan in eldar is ugly, nasty, brutal - ugly! :) You want to avoid those things like the plague! I suggest massive AT firepower. the TK shots just don't seem to pay off. Better to hope something gets through and cause it a critical is my experience.
The Eldar are also one of those forces that you can misplay easily and make them just over the top. Example - if somebody fields reverents 1 at a time instead of 2. Those must be fielded in formations of 2 but unless you read the list closely, you miss that. The superheavies have 4+ and the light tanks have 5+. The eldar armor is fragile if you can get to it... the new experiemental pop-up rules are a must IMHO. The eldar move shoot and then move will cause you much pain. Also, they have much better BM managment with some formations that have init 1, some formations that have leaders, and every formation with spirit stones. Good luck making BM stick to the eldar. The rapid strike ability of every formation not to mention the ability to gate in units to the field from objectives or their EoV tanks makes containment just not an option against the eldar. They have more tricks than David Cooperfield. The best play against eldar is overwatch and deal with their long range stuff early. Pick off formations one at a time and get ahead on the activation game early. You have to be able to dig out the formations that sit back and camp with pop up. Those things are vicious.
Our list is not complete, and many will say the Eldar is the strongest completed list out there. You should be quite pleased with a 2-1 result at the end of turn 2... even if the opponent was a newby at the Eldar. They are really tough!
To date, I've beaten the Eldar once with my Tau, and that's only been recently with the current WIP list. I've drawn on several occasions.
Rob
PostPosted: Mon Dec 19, 2005 10:01 pm
Quote (Breten @ 19 Dec. 2005 (08:56))
I won't say anything, I won't say anything, I won't say anything, I won't say anything, I won't say anything, I won't say anything......
PostPosted: Mon Dec 19, 2005 11:00 pm
Did I do something wrong or is there some sticky issue regarding Devilfish?
PostPosted: Tue Dec 20, 2005 12:12 am
Quote (Honda @ 19 Dec. 2005 (04:41))
Thanks for posting.
ROFLMAO - I missed this earlier... yes, I fully agree! In E:A the definition of crisis is something far lessor than I imagine. The 'crisis' are really not meant for such dire situations in E:A
OMG - girlscout with butterknife, yes, that sums it up nicely!
Rob
PostPosted: Tue Dec 20, 2005 12:13 am
Quote (Breten @ 19 Dec. 2005 (16:00))
Bretan,
It's not you... its RD - he can get political and stump speech like when it comes to seeker missles...  :p
Don't get him started.  :/
Rob
PostPosted: Tue Dec 20, 2005 3:06 am
Hey,
Well, its me, the guy that Breten beat with his Tau.
It was my first time playing Epic and loved it.  I thought the Tau were pretty good.  I remember them from 40k.  They have awesome weaponry.
Once I get my Eldar up and running, Brett and I agree that we could have a really good match.
Doug
PostPosted: Tue Dec 20, 2005 3:47 am
Quote (Tactica @ 19 Dec. 2005 (15:13))
Do not worry, I have since entered *twitch* "Seeker Missile Rehab", and am well on my way to becoming a constructive proponent *twitch* of these seeker *twitch* rules.  When I get out, I would like to get a job *twitch*, and maybe even start a *twitch* family.... :P
BTW, glad to see these BatReps, and glad that we have more people joining the Epic:A community!  :>
Happy Holidays!
PostPosted: Tue Dec 20, 2005 6:34 am
ditto on the batreps and new blood - keep em commin' ya'all! ;)
Rob
PostPosted: Tue Dec 20, 2005 7:01 am
I't's quite a good game.  I started back with Space Marine/Titan Legions playing  whatever armies the guy that ran it at our gaming club brought, until I built up my own force of Tyranids.  We played that for a few years until Epic 40K came out, and we all know how that went.  I played one game and vowed never to play it again.  Sold my bugs off a few years back, and this weekend replaced them making them my third E:A army.
PostPosted: Tue Dec 20, 2005 2:51 pm
Crisis:  I've been fielding them with Heavy Drones (so they have MLs) and they work nicely.  It's an 8-unit formation with the drone BM bonus.  While not incredibly tough, they have pretty good durability if you use them correctly and I usually get in at least one good salvo from them, i.e. with the MW, and a round or two of potshot fire.  Stealths would also be a good option for marking and additional units, but more expensive.
Ethereal:  I regard the Ethereal as an extremely useful upgrade, though it is probably questionable in a smaller game.  At 2700-3000, though, it can easily make a large formation of FW Fearless.  FW are one of the few potential assault formations Tau have and making them Fearless is a great benefit.  Even if you don't want to do that, just having a big fearless formation to anchor your force is quite nice.  It's also nice if your BTS formation is Fearless as it makes it much harder for the enemy to claim the goal.
FW in DF,  +FW in DF, +HHIC, +Ethereal
650 points
20 units, Infantry with good saves, decent AT, great AP, Fearless, some AA.
That's a solid anchor formation for any army.
PostPosted: Tue Dec 20, 2005 5:30 pm
No doubt.  You have that garrisoned, it's not likely to be moved.  Or coming up the middle.
