Specs/costs for ork Mega Gargants
 Post subject: Specs/costs for ork Mega Gargants
PostPosted: Tue May 30, 2006 2:49 pm
Does anyone have a good feel for what the mega gargants should cost, based on the stuff here I believe 1600 works for the Imperator, what about these,clearly they are tougher than a great gargant, but how much, maybe 1300 points (so less than emperor, but considerably more than standard)
Thoughts anyone
Robert
PostPosted: Tue May 30, 2006 3:17 pm
I'd start both around 1300 and if they're too good push upwards. The worst that happens is you find them drastically stronger then they should be and need to be pushed up. Just keep trying and you'll find the right spot eventually (Somewhere between 'an army all it's own' and 'just a super-sized gargant' would be ideal.)
PostPosted: Tue May 30, 2006 5:08 pm
The Imperator is definitely more powerful than the Megagargant.  Personally, I'd rate them at about 1600 and 1300, respectively.  Estimates on the Mega have ranged from 1000 to 1600 with most being in the 1100-1300 range.
We've used the Mega a few times and 1300 seems to be about right.
PostPosted: Thu Jun 08, 2006 7:37 pm
Thanks to all
Will let you know
Robert
