Noob speed freeks list adviced needed
 Post subject: Noob speed freeks list adviced needed
PostPosted: Thu Mar 21, 2019 11:37 pm
I am fairly new to epic 40k although i liked it a lot, I played a 4k match using space marines and It was pretty fun.
But I happen to prefer orks, si here is a tentative list to start learning.
As far as I understood, you have plenty of freedom in epic concerning units, so my plan is to play until I find my stile.
Do you guys think this list is ok to start learning or should I change anything?
Veloziwaaagh, 2990 POINTS
Burning Death Speed Freeks (NetEA Tournament Pack 2013)
SPEED FREAKS WARBAND (BIG) [530]
6 Boyz, 8 Trukks, 2 Nobz, 8 Warbuggy, Mekboy Speedsta, 2 Nobz, Gunwagon
6 Boyz, 8 Trukks, 2 Nobz, 8 Warbuggy, Mekboy Speedsta, 2 Nobz, Battlewagon
SPEED FREAKS WARBAND (BIG) [495]
6 Boyz, 8 Trukks, 8 Warbuggy, Mekboy Speedsta, 2 Nobz with Warbike, 2 Nob Warbikes
KULT OF SPEED [250]
7 Warbike, 3 Skorcha
LANDA [200]
FIGHTA SKWADRON [200]
4 Fighta Bomba
4 Fighta Bomba
BLITZ BRIGADE ('UGE) [435]
12 Deth Kopta, Mekboy Speedsta, Nob Warbikes
WARBIKE OUTRIDERS [150]
5 Scout Warbikes
Thanks
 Post subject: Re: Noob speed freeks list adviced needed
PostPosted: Fri Mar 22, 2019 4:59 am
You have 2 BTS-units. You should change one of the Warbands.
PostPosted: Fri Mar 22, 2019 10:24 am
That's true, I didn't considered that. Any other change? Would you recommend me any other unit to learn how to used it?
By the way, are the 8 fights to much? To less?
Thanks
PostPosted: Fri Mar 22, 2019 9:26 pm
8 Fighters are okay, imo.
I think, for the first games with freeks it will be good enough.
PostPosted: Mon Sep 23, 2019 2:18 pm
So I ha e familiarise myself with speed freekz thanks to minigeddon.
So I have changed my list for the better thanks to the experience.
This time I suits my playstyle way better.
WARBIKE OUTRIDERS (BIG) [250]
10 Scout Warbikes
6 Boyz, 8 Trukks, 2 Nobz, 5 Skorcha, 3 Warbike , 2 Nob Warbikes, Mekboy Speedsta
SPEED FREAKS WARBAND [250]
3 Boyz, 4 Trukks, Nobz, 4 Warbuggy, Mekboy Speedsta
BLITZ BRIGADE (BIG) [250]
8 Deth Kopta
KULT OF SPEED [225] (goes in the landa with the warboss)
Warbuggy, 3 Skorcha, 5 Warbike
LANDA [200]
4 Fighta Bomba
4 Fighta Bomba
SPEED FREAKS WARBAND ('UGE) [670]
9 Boyz, 12 Trukks, 3 Nobz, 5 Warbike, 7 Skorcha, 2 Nob Warbikes, Mekboy Speedsta
KULT OF SPEED [250]
Warbuggy, 4 Warbike, 3 Skorcha, Mekboy Speedsta
PostPosted: Mon Sep 23, 2019 3:56 pm
Light vehicles count as two units to transport in the Landa, hence with nine guys counting the Mekboy Bad Ork Bikerboy you could only have a maximum of one Warbuggy or Skorcha in the formation if you want to have all nine inside.
Rest is Ok. Speed Freks have no formation that is much bad compared with the rest.
Sculpting Orks thread
PostPosted: Mon Sep 23, 2019 9:50 pm
Joder es verdad que despiste.
Translation, sheeeeeit, your right. Then I get It will have to be all bikes :(, its fine. any alternative sugestion to fill the landa?
PostPosted: Thu Sep 26, 2019 12:16 pm
That mix of languages gave me a good laugh. Thanks.
About your question, other possibilities would be Warbike Outriders if going for a full Landa or a Warband if you ditch the Trukks and go mainly with Warbikes. This second could work decently with an extra Nobz and/or Stormboyz unit, but would be a waste about the Trukks.
By the way, i forgot before, but you may consider putting your Supreme Commander on the ground if you plan to use its re-roll, as it can only be used as long he is on the board, or on the Landa he is in. If you want it in the Landa for its assault weapons, you can, it is fine.
How were the Mekboy Speedstas on your games, by the way? It is just curiosity.
PostPosted: Thu Sep 26, 2019 12:22 pm
It's ok especially for putting blast marker on a 105cm rangeat the end being orks it is just a matter of overwhelming the oponent.
PostPosted: Thu Feb 11, 2021 9:37 pm
Why landas are incredible.
= They can create an assault.
For speed freaks that means that your very fast units (see scorchas) can double an insance distance, then provide supporting fire to a landa assault, (pretty much anywhere).
The landa can take all the abuse in the assault, - and is tough enough to do so.
But just in case shove a unit with some grotz, (grotz- landa,- paper thin boys, in that order).
This really is an incredible delete button, - with two landas, its re-usable.
So fast, and flying, can work wonders.
PostPosted: Mon Oct 10, 2022 4:04 am
So having a little difficulty seeing how to achieve this with speed freaks.
Cause the basic warband comes with trukks and buggies and so wont fit in the landa.
I think only warhorde can do this.
PostPosted: Mon Oct 10, 2022 12:24 pm
Yup, there's no Grotz in the Speed Freeks list either. Outriders are the only formation that will fit in the Landa.
