Post new topic Reply to topic  [ 95 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
If you could change the rules...
 Post subject: If you could change the rules...
PostPosted: Wed Apr 11, 2018 1:59 pm
That the community can produce new lists even if the game is not supported anymore is very obvious. But something that seems to be very taboo is the changing of the rules. That's often reffered to as a can of worms that shouldn't be opened. But I'm just curious what rules people around the globe think should be changed and/or clarified in order to make epic better (in their view).
Not so much interested in a heated debate where I tell you that your suggestion is crap and that i know best. Just interested in peoples ideas about what rules are bad/wrong/unclear and what their sollutions to the particular rule would look like. I've seen some really clever suggestions and ideas from time to time on this forum and it would be great to see them gathered in one thread.
So please share your ideas ladies and gentlemen!
 Post subject: Re: If you could change the rules...
PostPosted: Wed Apr 11, 2018 2:00 pm
I can start:
I think the following rule...
"A unit must use their counter charge move to move directly
towards the closest enemy unit. It may move into base contact
if close enough, and as long as the enemy is not already in
contact with two defending units. Units can choose not to
counter charge if they wish, but if they do counter charge they
must head towards the nearest enemy"
Should be changed to:
towards the closest or the assaulting enemy unit. It may move into base contact
must head towards the nearest enemy or the assaulting enemy unit.
Why? Because i think this rule creates some irritating scenarios where one side has no chance at all to defend itself in assaults and the outcome is almost automatic. I get that clipping assaults is a tactic widely used, i just dont think it's very good since it hurts CC-orientated units alot more than FF-units and CC-units is already significally worse than FF units i the game.
With the changed wording i think CC-units would be a little more dangerous to assault.
PostPosted: Wed Apr 11, 2018 10:47 pm
In order to declare enemy formations intermingled, all of them must have at least one unit in range (15cm) and LoS.
Or... just get rid of intermingled completely.
PostPosted: Wed Apr 11, 2018 11:45 pm
Hi All..
First off thank you mordoten for doing this..Yes it was on my to do list..
Rule sets need to evolve to remain "fresh" and we don't need to do a complete rewrite..Look, I think the main rule book can tweak to be clearer and less ambiguous..So small changes etc..
I have sticky the page for you..so that it easy to find..
I will also say treat each other with respect..when replying...
Regards
Greg
PostPosted: Thu Apr 12, 2018 12:26 am
The 5 minute warm up should be extended to 10 minutes. And a two beer minimum requirement.
handicaps
winners pay for the beer the next time
mattie
http://maashes.blogspot.com/
PostPosted: Thu Apr 12, 2018 1:32 am
Oh I would first just rewrite the rulebook not to change rules, but to write them in formal description logic axioms.
Kidding! Ish.
PostPosted: Thu Apr 12, 2018 2:08 am
I'd start with rewriting everything in ancient Sumerian to remove language bias. Ok no... that's just dumb. We should use Esperanto ;)
Jokes aside:
I don't think there's much that should be changed. They definitely could use rewriting for clarity. Supposedly they were written by English native speaker but...
If I was to change something by Fiat/handwavium then stuff like=>
-Far more special keywords and redaction of existing ones. Examples like Totem (nearby rally bonus) or Stable Platform (weapon doesn't havealty on double shooting). RA and IS should have the (re)roll value specified on the ability. eg IS(5+)
-D10 or 12's. Resign the d6 to the dustbin of history. Dice roll apps are everywhere nowadays.
-douche the aerospace rules. They're terribad. Use a tried a true idea like line strafing (it works)
-Sime type of CC oriented transport rules, like Assault Transport sorta but in epic. Those poor 'zerkers need a boost :)
-oh and something that actually uses the area effect template that the rulebook hinted would be used in the future.
PostPosted: Thu Apr 12, 2018 11:03 pm
OK, the following...
1) Counter charge move, so I do like want mordoten has put forward….
2) Fliers …In fact the whole section could really do with work over…..
3) Transport rule…remove the restriction on embarking and disembarking in the same move (entirely)…so some kind of movement penalty maybe…. 5cms of movement to both the transport and element when embarking or disembarking. …
4) Limit the range on hack downs…I actually think hack downs should only be limited to engaged units (i.e. within 15cm)…this more to do with the clipping assault.
5) Broken Fearless units and hack downs....1 fearless unit lost for every 2 hack downs…W/E engines (Fearless) are the sticky point, so maybe they are not affected….
thanks for reading..
Regards
Greg
PostPosted: Thu Apr 12, 2018 11:38 pm
I'm very interested in hearing how you guys would do the flyer rules.
PostPosted: Fri Apr 13, 2018 5:09 am
"In fact the whole section could really do with work over".. Sorry general Statement that can taken couple ways. When I wrote it, I was think " lets make the section clear"...Now that you have ask the question, I will add the following...
I do like some of the options that are in the EPIC Fathomless Destruction (ver 2.0), that cover aircraft and Air Transport… I believe he is on a newer version at the moment and so there may have been some changes on the aircraft again. He has not made that available in English yet…
He has many interesting ideas, which I would like to test….
Link…..Four page thread…
viewtopic.php?f=69&t=28874&hilit=Fathomless+Destruction
If you read through, you will find, want I gather is Jimmy’s idea..…although he may have tweak, since then…
Regards
Greg
PostPosted: Tue Apr 17, 2018 1:55 am
I'd like the shooting player to be able to choose whether tanks or personnel get hit by MW weapons. Semajnollissor suggested in a previous thread that MW be turned into a weapon attribute that could be applied to AP, AT, or both (e.g. "AP4+ (MW), AT5+") and that would have a similar effect and would allow split AP/AT values.
Help CC. The proposed counter-charge change and the idea of reducing (or even eliminating!) hackdowns from units in FF range would help with that.
Scouts' zone of control has been a topic of discussion but I don't have a solution to that myself. I haven't been a victim of scouts hiding 10cm in terrain yet…
I'd like to drop the blast marker for coming under fire. I like the -1 to activate, and I realize that coming under fire should be important, but there are a ton of 3-unit formations in this game and they break after one casualty. They're not much fun but there are so many that it's easier to change the rule than the lists. (Also, it's difficult to get more minis.)
Each turn, let armies 'pass' instead of taking an activation for every formation worth more than 500 points at the start of said turn. Make large companies, and company upgrades, worthwhile for once.
PostPosted: Tue Apr 17, 2018 8:06 pm
I quite like the hackdowns idea. Feels right that to get the huge swing benefits of assaults you need to CC. This way it will be tiered:
Shoot and you will do more limited damage but at no risk.
Firefight and you can do a decent amount of damage and break the enemy, but some risk of sustaining damage and being broken yourself. You control the risk/reward.
CC and you can wipe out the enemy, but your units are all at risk so likely to take damage yourself.
PostPosted: Tue Apr 17, 2018 8:28 pm
This is actually doable now:
Code:
WEAPONS   RANGE  FIREPOWER
Weapon X  15cm   AP4+/AT5+, MW
Weapon Y  15cm   AP5+, TK(6)
      or  15cm   AT5+, MW
PostPosted: Tue Apr 17, 2018 8:45 pm
Dave is right. Just AFAIK we don't do that anywhere (or do we?)
PostPosted: Tue Apr 17, 2018 10:11 pm
Shooting Attacks: Macro-weapons that can be used for shooting attacks do not have AP or AT firepower values. Instead they have a macro-weapon value (abbreviated to MW). For example, the volcano cannon mounted on an Imperial Warlord Titan has a fire value of MW 2+. You should roll to hit normally when firing a macro-weapon. Macro-weapons can affect any type of target, so the volcano cannon mentioned above would hit any type of target on a roll of 2+.
Users browsing this forum: Google [Bot] and 19 guests
