Post new topic Reply to topic  [ 238 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
Plastic scenery crowdfunder from Troublemaker Games.
 Post subject: Plastic scenery crowdfunder from Troublemaker Games.
PostPosted: Thu Aug 17, 2017 7:47 am
I'm running a new crowdfunder for plastic scenery.
I've already tested the tooling house with a prototype mould- turnaround time was 3 weeks, so we can be confident there won't be any long delays.
The prototyping mould wasn't especially cheap, so I'm hoping there will be a strong response, as I don't see any profit unless a decent number of stretch goals get reached.
Promo video here: https://youtu.be/tET2IPmI0T4
New Facebook group here: https://www.facebook.com/TroublemakerGames/
My heart: In my mouth.
EDIT: NOW LIVE HERE : https://www.indiegogo.com/projects/smal ... ain-kits#/
Last edited by Evil and Chaos on Mon Aug 21, 2017 10:45 am, edited 1 time in total.
 Post subject: Re: Plastic scenery crowdfunder from Troublemaker Games.
PostPosted: Thu Aug 17, 2017 10:11 am
Looks good in promo video.
PostPosted: Thu Aug 17, 2017 3:25 pm
Looks great! I'll be in for some, good luck with the funding. Any info on pledge levels yet?
Sent using Tapatalk
PostPosted: Thu Aug 17, 2017 3:39 pm
For the initial "Mixed Theme" sprue, most probably:
£20 - hamlet: 40 panels
£35 - village: 80 panels
£65 - town: 160 panels
£120 - city: 320 panels
The same bands will also be available for the first two stretch goals, the Gothic and Cyberhive theme sprues.
I'm hoping this will make full-on "hive" style tables an affordable prospect for people.
Also a £5 pledge for 8 panels as a sampler.
PostPosted: Thu Aug 17, 2017 3:43 pm
Certainly affordable!
PostPosted: Thu Aug 17, 2017 4:46 pm
good prices! I'm up to the zee eyeballs on scenery but I wish you all the best on this venture!
PostPosted: Thu Aug 17, 2017 4:53 pm
Buy moar.
PostPosted: Thu Aug 17, 2017 4:54 pm
It looks like the wooden cubes I used to play with when I was a kid.
There is nothing to break the omnipresent cubic shape.
May be you could design a sprue with half height tiles ?
PostPosted: Thu Aug 17, 2017 4:55 pm
Double height might be easier than halves, given the way the injection ports are set up.
PostPosted: Thu Aug 17, 2017 5:20 pm
Buy moar.
;D
PostPosted: Thu Aug 17, 2017 5:26 pm
Buy moar.
;D
ALL HAIL HOBBY TOAD
PostPosted: Thu Aug 17, 2017 5:27 pm
Sounds good to me. Glad to see the rose window version in there! :-) Guessing this is a stretch goal, so keeping fingers crossed!
Personally i will probably use them more as parts to scratch build with but i get that the simple clip together system will be attractive to many. I still think the easiest way to avoid the cube look will be some add-on parapets for the roofs (which could be metal maybe?)
Sent using Tapatalk
PostPosted: Thu Aug 17, 2017 6:11 pm
So if we buy one of the larger perks (like the £120 one say) will all the tiles be of the same theme, or do we get to pick and mix (say half gothic then half cyber)
Will they become a Vanguard staple once the kickstarter is over, or is troublemaker back doing its own thing?
I intend to tackle the cube problem by adding my own plasticard roofing, and buttresses (heehee). Plus that will save more tiles, which will let me do even more insane buildings. I also have a ton of the GW buildings which with a little chopping and cursing should add a little variety to the shape of the buildings. I see these cubs as the start of something great, rather than the end all to terrain.
I did mention back when Ben first previewed this idea, that perhaps it would be cool to get some gothic-y spires/triangular shapes on the go, and he said it would more than likely have to be a resin add on (or something to that effect! He will probably remember exactly what he said!) If they are not possible, I dont think it would be to hard to knock a few shapes up out of plasticard or foamboard, just to break the cube shapes up a bit.
Jimmy- if you really feel like you dont need any more terrain, you should still grab a small sample pack, just to try them out. The £120 'sample' pack should be just what you need! :D
PostPosted: Thu Aug 17, 2017 7:56 pm
It wasn't going to be proper "Gothic" without a rose window. :)
It arrives in the 2nd stretch goal.
I'm planning on doing metal or resin parapets, yes.
PostPosted: Thu Aug 17, 2017 8:04 pm
The way the system works, it would want me to send just whatever set type was ordered. I might be able to do some post-campaign Q&A.
Personally, I think you should pledge for 3x of each of the "city" sized sets. :)
John has agreed to stock them once they're available.
I'd like to be able to do spires, parapets, buttresses etc. We'll see how much backing we get...
