Epic Dreadnought Basing
 Post subject: Epic Dreadnought Basing
PostPosted: Sat Jan 16, 2016 3:24 am
Hi all,
I am using Flames of War bases for my Epic Space Marines, but there is no suitable base sized small enough for a single dreadnought.
Any suggestions for small bases that are similar that I could use to somewhat match the Flames of War bases?
Thanks!
 Post subject: Re: Epic Dreadnought Basing
PostPosted: Sat Jan 16, 2016 4:17 am
They made a single fig base (1/2 a small), it was metal. You can also cut a small to reduce its size. I did that for plastic Contemptors.
PostPosted: Sat Jan 16, 2016 4:32 am
Thanks for the response Dave.
Do you happen to have any pics of your Contemptors?
My main issue is trying to match the sloped edge of the FoW bases.
PostPosted: Sat Jan 16, 2016 5:22 am
Nope, but I do off some ood Ork Dreads
PostPosted: Sat Jan 16, 2016 6:01 am
Thanks Dave. That's a small Flames of War base cut in half?
PostPosted: Sat Jan 16, 2016 12:45 pm
Yep, I kept the same pattern. 2x2.5, 1.25x2, 1x1.25, .625x1.
PostPosted: Sat Jan 16, 2016 1:11 pm
I just turned the FoW small base sideways and called it good for both dreadnoughts and sentinels.
PostPosted: Sat Jan 16, 2016 1:43 pm
^ Same here. I was pretty happy with the scale.
Tau AC: viewforum.php?
Net EA Chair
PostPosted: Sat Jan 16, 2016 2:35 pm
What did you use to bevel the edge to match the FoW base after you cut it?
PostPosted: Sat Jan 16, 2016 6:13 pm
Looking at the pic I think he's cut the middle out. And put the two short ends together to make the long sides of the new base.
[=] Becomes []
This way there are no new bevels needed to be cut.
( I also like the way he's repositions the claws on those dreads)
PostPosted: Sat Jan 16, 2016 11:23 pm
Wow Kapitan,
Thats one of those forest for the trees kind of thing. I didn't even notice. Definitely looks like the middle section is cut and the two ends are glued.
Dave was even kind enough to post the sizes.
PostPosted: Sun Jan 17, 2016 5:46 am
I'm using FOW too, so these look good. :)
PostPosted: Sun Jan 17, 2016 3:01 pm
I use the 20mm old Space Marine era square bases for my Eldar and Space Marine dreads.
If I get larger dreads or proxies they may go on 25mm round as I like the look of them.
PostPosted: Sun Jan 17, 2016 3:13 pm
Some of mine ...
PostPosted: Sun Jan 17, 2016 7:48 pm
Very cool. Thanks for all of the responses folks.
Great information.
