Final Tabletop Workshop Castle Pictures!
 Post subject: Final Tabletop Workshop Castle Pictures!
PostPosted: Mon Nov 24, 2014 3:55 pm
Hi Guys,
Hope you may find this of interest.
We've recently been using the forums to show off progress of our brand new 28mm Castle Modular Castle Kits . The kits are now complete and I thought I'd show you some of the fortifications you can build with the final products.
In the pictures above, you'll be able to see one of our unpainted designs. We created a huge Square Castle Keep, surrounded it with a Massive Octagonal Outer Wall and added a few 28mm Buildings to complete. The whole Castle has been made from Tabletop Workshop modular kits.
For the first time ever, gamers can design a unique Castle any shape and size. Want to make your Castle taller? Simply add more Tower and Wall middle levels. Smaller? Take the middle levels out completely. Tabletop Workshop Kits are designed to be glued into separate levels and each level uses the same clip and fit system. This means that like a Construction Set, walls can be built up to be as big or small as the creator desires. Want to position your figures inside the Castle? The parapet can be removed during the game allowing easy access to the inside. Simply station your figure next to one of our medieval arrow slits and reign terror from the sky.
Not everyone wants a square Castle. That's why we've designed the Tower and Walls to connect at four different angles through the Connector Sets. In fact, we recently set up a Castle Creation Centre (http://www.tabletopworkshop.co.uk/page_castlesrising.html) to show off our favourites. Our Standard Castle Set offers 3 Walls, 1 Wall Gate, 4 Towers and 4 Connector Sets. Add 2 Towers, 2 Walls and 2 Connector Sets to this and you have the ability to create your very own Hexagonal Castle! Furthermore, add 4 Towers, 4 Walls and 4 Connector Sets for a massive Octagonal Castle.
You can find all of the details on http://www.tabletopworkshop.co.uk/
Over time, we plan to release more modular sets so that the Gamers can expand their Castles. In fact, we're currently working on the massive 28mm Gatehouse which is next in line!
 Post subject: Re: Final Tabletop Workshop Castle Pictures!
PostPosted: Mon Nov 24, 2014 6:14 pm
Looks nice, do you have plans for anything in a 6-10mm scale?
PostPosted: Mon Nov 24, 2014 11:38 pm
WoW !!
PostPosted: Tue Nov 25, 2014 9:36 am
We will be adding new products at new scales over time but there is nothing in the pipeline Mattman. Sorry! You'll find the details of our upcoming projects on our Website and Social Media Sites :(
