Stand-in minis
 Post subject: Stand-in minis
PostPosted: Thu Feb 12, 2004 7:15 pm
Hi everyone, I was just wondering if anyone has an opinion on GHQ's microarmor.  I recently decided to start Epic A but I usualy favor massive battles rather than 3000 pointers, and as such, I need lots of minis.  The prices for some of the new epic releases seem to be a bit prohibitive, do you think it would seem out of place to use microarmor alongside regular epic minis?  Also, is microarmor good qualtiy?  It appears they are from the pictures on the site.
PostPosted: Thu Feb 12, 2004 9:19 pm
GHQ are the "cadillac's" of 6mm WWII gaming. The quality and detail on them are top notch, there's nothing better. They are more expensive though than compared to C-in-C, Heroics and Ros or Irregular.
PostPosted: Fri Feb 13, 2004 5:54 am
Primarch is correct, however, IMO they are generally a little small next to most Epic models.  I'm not a real fan of "massive" battles, around 4000 points basically works for us.  I'm not sure if E:A lends itself easily to 6000-7000 point battles.  I could be wrong.  Time is always a consideration.  :;):
PostPosted: Fri Feb 13, 2004 6:07 am
GHQ is very good quality... and I'm sure it would be ok against other GHQ forces... I have played my epic armies against a friends GHQ armies a few times and it works ok, the GHQ minis look a little small next to guard or marines but are fine otherwise, against tyranids they are great for instance.  The GHQ  infantry is actually very similar in size to GW Imperial guard but the tanks are a lot smaller.
A few people have commented that 'Epic is the best WW2 system they have ever played'. :cool:  Certainly for big games (which I also favour) look into other manufacturers figures.  In large numbers, in such a small figure scale, quality doesn't matter nearly as much as for larger figure scale gaming.
PostPosted: Fri Feb 13, 2004 6:21 am
Epic is very WW2-ish.  Maybe that is why I like it so much ! :;):
PostPosted: Fri Feb 13, 2004 4:15 pm
Thanks for all the replies!  I may just start buying the GHQ minis as painting practice for the US release of the epic models.  Now I just need to work on getting some terrain...
PostPosted: Fri Feb 13, 2004 10:41 pm
Thats why I am adapting the net epic system for WW2. It fits the era well.
PostPosted: Sat Feb 14, 2004 5:32 am
I find irregular to be a bit closer to Epic scale.  They are no way the same quality, but a lot cheaper, and they have some very interesting things like crews, figs sitting on tanks, trucks with the trays filled with troops etc
A reasonable paintjob does wodners for apperaance in this scale anyway and can overcome some casting issues, especially in the quantities you seem to be talking
Tas
PostPosted: Sat Feb 14, 2004 7:59 pm
Hi Sarius,
I really like 6mm minis and GHQ makes incredible models, but...
They also have the highest price in the market. Because of this, I'd rather buy Scotia minis or one of the other brands.
6mm_Miniatures
The above web site has an incredible links gallery and you can find anything you want there. I run it along with some people from this group and some other groups.
I really recommend checking out the "6mm sci-fi manufacturers" links folder.
Cheers and Shabbat Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Sun Feb 15, 2004 12:17 am
No question they are expensive, but still cheaper than GW....  :;):
