Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
Air Assault out of a broken AC?
 Post subject: Air Assault out of a broken AC?
PostPosted: Mon Oct 21, 2013 6:08 pm
An Ork Lander performs an air assault. It takes two points of damage coming in so has 3BMs on it.
It lands within 15cm of an enemy formation:
What happens to the Landa?
1) It's fine
2) It's destroyed because it ended its move within 15cm of the enemy and isn't fearless
What happens to the units inside?
1) Disembark as normal
2) Have to take an armour save (as per destroyed transport rules) and disembark as normal
3) All die because the AC was destroyed before it landed
What happens to the assault?
1) It continues as normal, the Orks don't count as having BMs if the Landa was destroyed
2) It never occurs because the Landa needed to survive (Orks inside activated with it)
 Post subject: Re: Air Assault out of a broken AC?
PostPosted: Mon Oct 21, 2013 6:17 pm
Per 4.1.6 air assaults the vehicle and the transported units considered an intermingled formation.
Air Assault: Transport aircraft may choose to land as described above, and then it and any units that disembark are allowed to fight an assault instead of shooting. If this option is chosen then the aircraft and any units that disembark may enter enemy zones of control as if they were charging. The aircraft and any units that disembark are treated as a single formation for the duration of the assault, in the same manner as units disembarking from a war engine taking an engage action (see 3.1.3). If the aircraft loses the assault it is destroyed, but any units that have disembarked may withdraw normally.
Also per 1.12.7
There are various “auto-kill” effects which result from lost assaults (broken formations wiped out, aircraft destroyed, etc.). Do those happen before or after the extra hits for losing assault?
A: The hits from losing assault (so-called “hackdown” hits) come first. Per the rules, the hackdown hits occur during resolution (1.12.7) and the “auto-kill” hits either explicitly or implicitly occur after that, usually in the “Loser Withdraws” (1.12.8 ) step. To provide specifics, wiping out a broken formation clearly happens in 1.12.8. The formation’s status is changed to “broken” during 1.12.8, so that’s when Chaos Daemons disappear into the warp. Aircraft in a lost air assault (4.2.5) are somewhat ambiguous, but the text implies a connection between the automatic destruction and withdrawal, which would correspond to 1.12.8 as well. In the absence of an effect specifically stating the contrary, assume the losing player gets to allocate hackdown hits prior to auto-kills.
PostPosted: Mon Oct 21, 2013 6:46 pm
I'm not asking about what happens when it looses the assault jimmy, I know how all that works. I'm asking what happens when an AC lands and converts to a ground unit that's broken.
PostPosted: Mon Oct 21, 2013 7:05 pm
I would say that as it lands, the aircraft and units within are considered one formation since it is an air assault and therefore the 3BMs would not have any effect. It would land normally, the units inside would disembark, and the assault would continue normally. The 3BMs would count toward the assault resolution and any additional BMs caused by kills / DC loss would be resolved according to where those hits took place.
Assuming the Orks win, the infantry and Landa would 'separate' and the Landa would break. The infantry would consolidate. I think that since it was already landed at this point, the Landa would simply break. If the Orks lost, the Landa would still be in the same broken state, except of course it may be in a position where it has to retreat (I can't remember if they are fearless or not) in which case it might be destroyed by the hackdown kills or being stuck within 15cm.
PostPosted: Mon Oct 21, 2013 7:08 pm
Mosc beat me to it but yes, in my opinion, that's what I quoted would mean (RIA), mate.
Not disparaging your EA-know-how :)
PostPosted: Mon Oct 21, 2013 7:16 pm
Meh, I went and re-read the rule. If the assault is lost, the Landa is destroyed. So that's easy. If it wins, though, I don't think it is destroyed (see explanation above).
Now this would be different if it was a ground attack. That would mean was broken at the point of the Landa stopping it's movement. But even then, it is a little weird for me. Is it an aircraft when it breaks or a land unit? If it is an aircraft, the number of BMs don't matter. If it is a ground unit, then that implies it is landed and broken on the ground. I'm not convinced it would be destroyed in a ground attack in which it accumulated 3 BMs.
PostPosted: Mon Oct 21, 2013 8:12 pm
4.2.7 Blast Markers
Aircraft collect Blast markers in a similar manner to other units,
but are affected by them rather differently. The following fairly
simple rules reflect the time it takes to rearm and refuel aircraft
after a mission. Aircraft in a formation that has come under
heavy attack and therefore have a lot of Blast markers will take
longer to get ready, and so there is an increased chance that they
may not get to carry out a mission.
Aircraft are not suppressed or broken by Blast markers, but are
not allowed to rally in the end phase either. Instead, the next time
that you want to take an action with the formation, take the
action test as before, but apply a -1 modifier for each Blast
marker on the formation (this modifier replaces the modifier for
having one or more Blast markers).
As I see it the Landa fights the combined assault - meaning formation not broken. Then disengages as an air craft (unless looses assault and killed in assault / hack down because not fearless) then may only enter if rolls over BMs as usual.
PostPosted: Mon Oct 21, 2013 8:46 pm
OK. So it would land and the combined formations would count as having 3BMs for assault resolution. If it won, then the only way I can see it being destroyed if it was within 15cm of another enemy formation. Or if the enemy formation was fearless and refused to retreat... That's a dick move I'll have to file away. Or would it not be destroyed because the winning formation never takes hack-down hits?
@Blip, all that text is while it's airborne though. When it's landed it's affected by BMs like ground units. See the landing section in 4.0.
PostPosted: Mon Oct 21, 2013 9:02 pm
1) It's fine
If a Transport aircraft makes an air assault then it and any units it is carrying count as a single formation for the entire engage action.
Highlighted relevant part.
relevant part from 3.1.3
In both cases, the war engine and the transported units are treated as a single formation until the shooting attack or assault has been resolved.
So the assault would go ahead with the whole (combined) formation counting as having 3 BM's.
neither,
The Orks and the Landa would continue with the assault with the "whole Formation" having 3 BM's, once the engage has finished the landa would take the original 3 BM's.
If the Orks lost the assault the landa would be automatically destroyed, if they won the Landa (if it survived any hits from the engage) would be broken and would take 1 point of damage for each enemy unit within 15cm of it (as it cannot retreat).
From 3.2.4
A broken war engine is assumed to have a number of Blast markers equal to its starting damage capacity for all rules purposes. If there are any enemy units within 15cms of the war engine after it makes a withdrawal then it suffers one extra point of damage (no save allowed) for each enemy unit that is within 15cms. Additional hits caused by losing an assault or receiving Blast markers while broken cause one point of damage each. Roll for critical hits from these extra hits as you would normally.
PostPosted: Mon Oct 21, 2013 9:12 pm
If that's if that's the way its played. As i see it the section for landed AC :
"Once landed, the aircraft is treated in all ways as a ground unit
with a speed of 0 (i.e., it may not move) It may not carry out an
action on the turn it lands. If it is involved in an assault and loses
then it is automatically destroyed. Once landed, the aircraft may
make a disengagement move and exit the table in the end phase
of any turn, including the one it landed in."
...refers specifically to movement while "on the ground" - ie. it can't hop about the board at infinite speed on subsequent turns avoiding flak. I don't see anything that specifically over rules the section about not receiving BMs like normal units.
Though, i can see why it would be played that they can be suppressed, i don't really see any way to resolve a broken AC - if anything surely it would have the option to disengage immediately as its withdraw move....?
Wow, the AC rules are a quagmire of rules, counter rules and exceptions ain't they !? Anyway, I bow to the greater authorities.
PostPosted: Mon Oct 21, 2013 10:38 pm
There are tons of weird bits in the air rules but this one seems quite straightforward. If it were empty it could break when it lands, before the assault happens (like in overwatch). Otherwise it will just have BMs for resolution. If it breaks when the assault is resolved (because the formations split up) then it takes a 0cm withdrawal move as normal and suffers any consequences. Exactly like any other ground unit (which it is). The hardest part is the order i.e. when do the formations split up.
PostPosted: Tue Oct 22, 2013 12:51 am
Late to the party as usual... (living in Australia is wonderful but timing is always an issue).
dptdexys has covered the original question well (thanks mate :) ).
I admit that I played the air rules wrong for a while when I first started so I can understand the confusion that Blip describes.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Tue Oct 22, 2013 10:28 am
I don't understand why when ...
it has 3 blast markers, the Orks win the fight, there are units within 15cm at the start of the end phase
... that the Landa is destroyed? I understand this,
but why wouldn't this occur?
Am I confusing disengagement and retreat?
Thanks! (Poor Landa ...) :wah ;D
Joel
PostPosted: Tue Oct 22, 2013 11:27 am
Disengagement happens in the end phase. Withdrawal happens either when you break, or fail to rally. You take damage if there are units within 15cm at the end of a withdrawal.
So, if the landa has 3 BMs then it will break when it separates from the formation it was carrying (i.e. at the end of the assault). At the moment that it breaks, it can make a withdrawal move (of 2x 0cm), and if it ends the withdrawal within 15cm of the enemy then it loses 1 DC per unit.
There is nothing in the rules to do with being within 15cm of the enemy at the start of the end phase.
PostPosted: Tue Oct 22, 2013 12:23 pm
Thanks for clearing up a new players confusion!
Joel
