Bullock Jet Cycles
 Post subject: Bullock Jet Cycles
PostPosted: Tue May 22, 2012 1:32 pm
Hi,
Does anyone have any pictures of the 6mm Bullock Jet Cycles please? I think I've found one but I'm not sure what they look like, and I want to check it's authenticity. I've no idea where I could find a searchable GW or WD archive for this sort of thing I'm afraid. Thanks in advance.
 Post subject: Re: Bullock Jet Cycles
PostPosted: Tue May 22, 2012 2:30 pm
You mean this - Image Go to EpiCollector Site also ... SM Bikes are under Auxilliaries - http://www.galactic-intrigue.com/epicol ... rames.html
PostPosted: Tue May 22, 2012 7:37 pm
Thanks for that: I'm confused though, the picture on Epicollector doesn't match the one above? Is the "jetbike" from Epicollector a Bullock? Apologies, these questions must seem quite inane.
PostPosted: Tue May 22, 2012 11:56 pm
the epicollector picture is the same as L4s. Its just a different angle. You cant see the rear of the jetbike in L4s photo. The good news is that you can use bluestuff to make a mold of your original. A bit of greenstuff and magic!!.
PostPosted: Wed May 23, 2012 12:27 am
That is correct Lyle ... same model ... different angle !!! ;D Here's a another angle of my Jet Bikes ... blurry photo ... they were moving fast !!! Image
PostPosted: Wed May 23, 2012 7:43 am
The bad news is of course that this is called re-casting and is in breach of copyright and is illegal.
http://angelbarracks.co.uk/
PostPosted: Wed May 23, 2012 9:25 am
Personal use should be fine :-)
MoK's Painting Blog
Now Showing:
PostPosted: Wed May 23, 2012 10:44 am
Nope, that is still illegal.
Unless you own the copyright you do not have the right to copy.
Simple as that.
PostPosted: Wed May 23, 2012 11:11 am
Please review board policy on casting and creating miniatures here:
viewtopic.php?f=126&t=10115
Ownership of concepts is often more important than ownership of physical products and even unproduced products and out of production items are protected. A better solution would be to find 6mm jet bike from another manufacturer.
Anyone know of any?
PostPosted: Wed May 23, 2012 11:18 am
At the risk of talking to myself.... Ohhh....
http://www.wargamesemporium.com/new/osc ... 507cc328f7
PostPosted: Wed May 23, 2012 11:31 am
With the obscene amount of money that GW charge for Epic nowadays, especially with the crap quality of the moulds then I'm not too fussed about people producing knock-offs. I've managed to find one anyway, it's definitely the right one. I found some old Epic 40K rules for it and it sounded pretty cool. +10 points to mount a Chapter Master or Commissar on one. Not a bad deal given the 35cm speed but the armour is pretty dire at only 4+.
Users browsing this forum: No registered users and 164 guests
