Post new topic Reply to topic  [ 355 posts ]  Go to page 1, 2, 3, 4, 5 ... 24  Next
Nitpicks Knapsack - Scratchbilding, painting and 3D stuff
 Post subject: Nitpicks Knapsack - Scratchbilding, painting and 3D stuff
PostPosted: Thu Apr 05, 2012 9:58 am
This thread will now be a catch-all for my 6mm affliction activities
Since way back I have longed for a Nurgle cult style army. Initially I wanted to create a ragtag fanatic horde of giant-snail followers for 40K. However, that never came to be and having abandoned that scale for epic I am thinking of 6mm slimification instead.
However, the nurgle war-engines are fairly difficult to come by (or ridiculously priced) and I have been toying with my own ideas. So here is one for a Plague Tower. Admittedly a very rough sketch indeed, just to get an idea of the basic shape and components.
File comment: Traitoresque Plague Tower
Is it too boring?
 Post subject: Re: Becoming Slime - an attempt at Nurglification
PostPosted: Thu Apr 05, 2012 10:03 am
Suitably slimed i recon that could work. Not sure about the gun in the main turret, does not look so nurgly – maybe more or a mortar or catapult?
PostPosted: Thu Apr 05, 2012 10:47 am
The track section looks particularly slug-like to me :)
PostPosted: Thu Apr 05, 2012 11:04 am
Thanks, I was a bit unsure about using the old super heavy trick, but I think it might work. Guns are placeholders. A mortar is preferable, I agree. I also need two battle cannons which I plan to mount one above the other in bunker style slits in the tower.
PostPosted: Thu Apr 05, 2012 12:18 pm
Classically, Nurgle has two superheavy weapons - the Plauge mortar (60cm range, lots of disrupt BPs) and the Rot Cannon (90 cm range, a single APAT shot)
what you've got would do nicely for the latter.
My shifting projects
PostPosted: Sun Jun 03, 2012 5:47 pm
Time for some threadromancing. I just wanted those of you who gave me good advice to know that it did not pass unnoticed.
Still the same approach, a more suitable Nurgle bulk to the chassis this time around, though. Courtesy E&C-ware.
The whole assembly, bar the barrel for the main snot-gun. The maingun will be a standard simple low fixmount design, with organic guckiness attached.
PostPosted: Sun Jun 03, 2012 8:11 pm
much better! gives me some inspiration :)
MoK's Painting Blog
Now Showing:
PostPosted: Wed Jun 06, 2012 3:09 pm
Some nurglified exhausts:
PostPosted: Thu Jun 28, 2012 9:30 pm
After some protracted unableness to post pictures (masterfully solved by our almighty master of the web), here is the end result!
PostPosted: Thu Jun 28, 2012 10:18 pm
Nice conversion!
PostPosted: Fri Jun 29, 2012 4:51 pm
Thanks! Some crudeness here and there, but seeing as minor corruption is to be expected in these particular demon engines, I am quite happy with the results. I had fun building them. Some more pics on angles and company. The actual camera angle distorts scale a bit, it is actually substantially bigger than the contagion in the foreground...
PostPosted: Fri Jun 29, 2012 5:58 pm
I really like your work on these so far! I'd maybe add a bit of 'flesh' to the frontal cannon though. Somewhat like Granny Wendy's recent plaguereaper conversion.
If you haven't yet, give liquid green stuff a try. I've been using it to make Nurglifified infantry and it's really good for getting natural fleshy layers on minis at this scale.
PostPosted: Fri Jun 29, 2012 6:36 pm
Nice conversion, very imaginative.
PostPosted: Fri Jun 29, 2012 6:52 pm
Thanks! I'm not really satisfied with the main gun either. I'll look into that liquid stuff! Also planning on adding chains and piping before I start painting.
PostPosted: Sat Jun 30, 2012 10:10 am
Wow excellent work
