Hunter/Killer add-on to Chimera(s)
 Post subject: Hunter/Killer add-on to Chimera(s)
PostPosted: Sat Mar 17, 2012 7:23 am
Where does one obtain two HK missile systems for a Chimera? Must I make them or can I buy them somewhere? I want to equip my Chimeras like the Bradleys using TOW. Thanks.
 Post subject: Re: Hunter/Killer add-on to Chimera(s)
PostPosted: Sat Mar 17, 2012 7:29 am
exodus wars does missile packs.
My shifting projects
PostPosted: Sat Mar 17, 2012 3:08 pm
I think you could get away with using these[\url] if you removed the handles. They may need to be down a bit, I think they're 6mm x 10mm or so.
Old Crow also makes [url=http://www.oldcrowmodels.co.uk/6mm/turrets/tursdml.gif]Missile turrets
that may help. They're probably easier to cut off the missiles and attach to a turret than the EW product.
PostPosted: Mon Mar 19, 2012 7:17 am
A guy locally uses jumpers (http://en.wikipedia.org/wiki/Jumper_%28computing%29) which any electronics store should have. At 6mm scale they look great as box launchers.
PostPosted: Mon Mar 19, 2012 1:07 pm
I've got some of the E40k turrets with them on it (#3). I'd trade for Turrets 4 or 5.
PostPosted: Sat Mar 24, 2012 5:27 am
Gentlemen:
Very nice solutions! I think I will try the Exodus crate modification on the seven units I have at hand. Dave, I have no #4 turrets, #5 turrets, and I just used my last seven #2 turrets on these Chimeras, but I thank you for your offer and consideration.
