how do you guys flock your models?
 Post subject: how do you guys flock your models?
PostPosted: Mon Aug 08, 2005 10:24 pm
How do you guys base your models? I was thinking of just plain green flock but it seems a bit boring.
oh ya also do you glue your models to the base before flocking and painting?
thanks all
colban
PostPosted: Mon Aug 08, 2005 10:37 pm
I use a few different techniques. Most of my armies are simply based with painted sand which I'll admit is a bit boring. On some of the newer stuff I'll paint the base black maybe add a few patches of sand and drybrush with Graveyard Earth. When that is completely dry I'll add a bit more PVA glue in patches and sprinkle a bit of green and brown flock. Once completely dry I give it a quick dip of thinned down pva glue mixed with a tiny drop of black paint to prevent the flock from falling off and tone down the colour just a bit.
Try experimenting a bit on some spare cardboard to see what you think looks nice and is relatively easy to do.
Cheers! :)
PostPosted: Mon Aug 08, 2005 11:03 pm
I just flock everything with a woodland scenics mix, but I intend to do some more work on titans bases. I've just stared the sand/graveyard earth combo as WMN has been describing on some larger scale figures, and it looks really good, so i might use that to start with for the titans. Building those ruin sprues that come with the epic infnatry bases into your basing technique is a great idea for titans... it really gives them a sense of scale.
PostPosted: Mon Aug 08, 2005 11:04 pm
I use the simple approach. I use GW flock. PVC glue that I apply to the base and then dip the glue full base in the bag of flock.
Its simple and yields good results.
PostPosted: Tue Aug 09, 2005 2:25 am
Plain flock is just far too BORING and flat for me...
I either drybrush my bases- Bleached Bone highlight over Bubonic Brown base for a desert theme, or Codex Grey over black for urban bases- OR, for snowy bases, fiddle about for hours with thick undercoat, sand and baking soda layers.
I also use small clumps of modelling lichen, static grass, bits of the mini-ruins from the old bases sprues, and stone chips to add realism and extr interest.
www.darkrealmminiatures.com
PostPosted: Tue Aug 09, 2005 2:56 am
Alas, for poor old me wanting in the mighty "enginseer" abilities, simple flocking is all there is.... :)
PostPosted: Tue Aug 09, 2005 7:05 am
I do not bother with flock. That is included in the painter's fees. :p
dafrca
              - Cities of Death, page 59
PostPosted: Tue Aug 09, 2005 7:42 am
Enginseer abilites? We have those? ???
Anyway - sand on PVA can do, but I prefer to undercoat and paint it.
I like static gras in Epic - looks like a grassland to me - but many, I think, don't appreciate this philosophy :p
The standard, small particle flock is good too. But I think a mix of two (not more!) of the above is best. In particular sand with tufts of grass or flock, as in my dark Eldar in the Vanvlakian armies thread in general modelling.
Other options are:
Fullers earth (the clay particle type) cat litter for boulders - I've yet to see anyone else using this!
Pepper for gravel - smells a bit, but looks good and doesn't go bad - at least, some models built around 10 years ago are stil ok! :D
Chinchila dust, as suggested by Killed by Death. Havn't tried this yet.
But the secret stil is to combine two items - makes for a more varied terrain.
I also can't understand why more people don't use the small bits of ruins that come with the bases - they're terrific as a rear edge to the base; better still on War machine or Titan bases.
Back from oblivion (again)?
PostPosted: Tue Aug 09, 2005 12:44 pm
Quote (vanvlak @ 09 2005 Aug.,07:42)
Because they don't come with the bases anymore?  :l
If you suddenly find that I make any sense.... look out of your window for armageddon!
PostPosted: Tue Aug 09, 2005 2:19 pm
:laugh:
That would be a good reason!
dafrca
PostPosted: Tue Aug 09, 2005 2:31 pm
True Primarch, I wouldn't fancy being the poor painter who had to drybrush every base for each thousand stands of IG infantry you send him! :D
PostPosted: Tue Aug 09, 2005 2:44 pm
Quote (Killed by Death @ 09 2005 Aug.,13:44)
Because they don't come with the bases anymore? ?:l
Ooops - doh! moment. Now everyone knows how long it is since I bought troops - although I have to admit I hadn't noticed this with my IG character pack.  :p  :blush:  :p
PostPosted: Tue Aug 09, 2005 2:59 pm
Just like Primarch, white glue and flock, generally. Sometimes sand and gravel.  And if anyone needs those ruins from the E40K base sprues ... I have a bunch of extras ! :D
PostPosted: Tue Aug 09, 2005 3:01 pm
I use a straight flock unless I'm doing a "feature" piece.  A mix of glue, water and paint gives a good color base and adheres the flock.  For rank-and-file models it looks just fine imho.
For a feature piece (commander, titan, etc.) that stands out from the army, I will typically add a small amount of detail.  Examples:
A bit of ruins under a titan's feet
Vehicle wreckage surrounding a commander
A scrying poool for a Farseer counsel
And, of course, typically a bit more variety in flock/base texture.
PostPosted: Wed Aug 10, 2005 10:38 am
Hello to you all,
I base in two (small) steps. First pva on a few places, always including the edges of the models, and dip into gw "sand with stones" stuff. After that I use pva on the open space and aply static grass. It's easy and looks nice imho!
example
greetings,
Gamgee
Users browsing this forum: No registered users and 174 guests
