Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 32 posts ]  Go to page 1, 2, 3  Next
NetEA Army List Compendium 2012 - 20120208
 Post subject: NetEA Army List Compendium 2012 - 20120208
PostPosted: Wed Feb 08, 2012 4:41 pm
OK, take two.
Please restrict posts on this topic to typos only.
Also, when posting typos/omissions please provide:
  • the page number (use the page number according to the PDF program you're using, not the page number on the document itself)
  • the typo/omission
  • what it should be
Posts like "Unit X is wrong" or "Unit Y is missing" are about as useful as sustaining with Grotz.
 Post subject: Re: NetEA Army List Compendium 2012 - 20120208
PostPosted: Wed Feb 08, 2012 5:36 pm
Hmm... I looked back through the previous thread, and it looks like my post was eaten somewhere. Carlos pointed it out, and I posted (or thought I did), a fairly extensive correction post (re-created below).
Army List Page 75
Thunderbolts 175 per pair.
Army Reference Page 76
Baron
- Add First Strike on Baron Lance
- Add Crit Hit Effect = Destroyed
Castellan
- Add SmallArms +1EAFF on Gatling Autocannon (minor, Gatling only spelt/spelled with one T)
- Remove Void Shield, reduce DC to 1.
- Add Knight Shield and Shock Lance.
Crusader
- Change FF to 3+
Errant
- Remove EA from Thermal Cannon Small Arms.
- Change MW to TK(1) on Power Gauntlet.
- Remove Indomitable.
Lancer
Paladin
Warden
- This is a change based on stats in the proper list not working as intended. Change FF to 5+, add +1EA Smallarms to Multilaser. It's the easiest solution to having the two multilasers add a single EA(with FF4+), to get the same effective result.
Morgan Vening
- KnightWorld SubChampion
PostPosted: Wed Feb 08, 2012 6:04 pm
Page 135 – Battlefortress Critical Hit Effect concludes as ‘Any units on board will survive on a roll of 6.’ And should read as ‘Any units on board will only survive on a roll of 6.’
Page 135 – Gunfortress Critical Hit Effect concludes as ‘Any units on board will survive on a roll of 6.’ And should read as ‘Any units on board will only survive on a roll of 6.’
Page 137 – Speed Freeks Warband Upgrades for clarity change ‘Nobz unit’ to ‘Nobz unit with a Trukk’ & ‘Replace any Nobz with Nob Warbikes’ with ‘Replace any Nobz and a Trukk with Nob Warbikes’
Page 138 – Remove Grotz from stats they are manning the vehicles
PostPosted: Tue Feb 14, 2012 5:10 am
p.156 (Alaitoc army list):
- The Aspect Warrior troupe is missing the indication of just how many units you get for your 225 pts - I'm guessing it's still 6?
- The Engines of Vaul troupe lists Void Spinners. These are in the Swordwind unit description described as Biel-Tan and a few other craftworlds only, being seen as an abomination by the other craftworlds. It appears in the 2010 army lists too, but I can't find the discussion leading up to that release.
{Edit} Discussion found. It seems the Void Spilnners is indeed a typo.
Let there be code.
PostPosted: Tue Feb 14, 2012 10:32 pm
P.168 (Iybraesil army list)
Part of the text in the Crone World Raiders Warhost entry seem to be missing, unless it's intended to be an option to take two free Heavy Weapon platforms =P
The text from the 2010 compendium appear complete.
{edit}
At the moment, the entry is:
Farseer unit and 5 Guardian units plus2 Aspect Warrior units in any combination from the following list:
Dire Avengers, Striking Scorpions, Howling Banshees, Fire Dragons, Warp Spiders, Dark Reapers, Swooping Hawks, Shining Spears.
Up to 2 Heavy Weapon Platforms at no additional cost
The text from the 2010 compendium; I think the green is missing in the new text.
If not, it's an option to take up to two units for free.
One Farseer unit, five Guardian units and two Aspect Warrior units chosen from the following list, in any combination: Dire Avengers, Striking Scorpions, Howling Banshees, Fire Dragons, Warp Spiders, Dark Reapers, Swooping Hawks, Shining Spears.
Up to two Guardians may be replaced with Heavy Weapon Platforms at no additional cost in points.
Let there be code.
PostPosted: Wed Feb 15, 2012 9:34 pm
P.174 (Fir Iolarian list)
The Revenant Titan host entry is missing an 'each' in the points cost.
Let there be code.
PostPosted: Thu Feb 16, 2012 2:54 pm
Hena wrote:
The special rules for Scions are still missing. Formation of ThTs can carry a formation and all infantry on table must have transports and there is no drop pod alternative.
Dobbsy wrote:
pg 16
Thunderhawk names changed in the Scions list. It's incorrect to have the same units named differently in different lists. Please return their reference sheet names to Interdictor and Bomber and correct their army list entries to Close Air Support and Saturation Bomber as per all other Marine lists.
pg33
Dark Angels list is missing the bottom box line for the Teleport Homers special rule.
PostPosted: Fri Feb 17, 2012 3:08 pm
Codex Astartes Siege Assault Vanguard
P. 42 "Predator Squadron" should be "Predator Tank Squadron"
"Vindicator Squadron" should be "Vindicator Tank Squadron"
"4 Thunderfire Cannon" should be "4 Thunderfire Cannons"
P.43 Dreadnought (Ironclad) should have FF4+ not FF3+
Dreadnought (Siege) is missing "Ignore Cover" in the notes section. As well as "(15cm) (Small Arms), Ignore Cover" can be deleted from the Heavy Flamer.
P.44
Thunderhawk Interdictor is listed but the list doesn't use it.
Land Raider Crusader is the last entry in the ref-sheet should be between Achilles and Prometheus. As well it is the generic Land Raider Crusader should be the Siege Assault Vanguard specific one.
PostPosted: Fri Feb 17, 2012 7:53 pm
Siegemasters reference (p51) Imperial Guard Commander unit has CC 6+. Should be CC 5+.
Imperial Allies (p90) Warlord Titan critical hit effect appears to have been copied from the Banelord Titan. Needs to be copied from, say, the Warlord data sheet on (p7).
Black Legion army list (p92) Under the core units for Black Legion Retinue, Black Legion Chaos Space Marine Terminators, Black Legion Bike Company and Raptor Cult, it says they include a "Chaos Space Marine Lord character". Under the Warlord entry in the Black Legion Upgrades section, it says the character may be added to ". . . a unit containing a Chaos Space Marine Lord". These two mean it is impossible to use the Sorcerer Lord or, if used, to be the supreme commander because Chaos Space Marine Lord is a specific character on the reference sheet. All instances on (p92), including in the Special Rule at the bottom of the army list, should be "Chaos Space Marine Lord or Sorcerer Lord character".
Black Legion army list (p92) Black Legion Decimators Cost "225 points". Should be "225 points each".
Stigmatus Covenant army list (p96) Special Rule - Arch-Heretic. Wording suggests unit is relaced by an Arch-Heretic. Should be "One Demagogue, Chaos Space Marine Aspiring Champion or Daemon Prince unit in the army must have an Arch-Heretic character added to it for free."
Feral Orks army list (p139) Special Rule - Feral Ork Warlord "If there is a tie, you may choose which Warband the Warlord will join". Should be ". . . you may choose which formation the Warlord will join", as Warband is the name of a specific formation and the previous sentence uses "formation", suggesting any formation with the most units can be chosen.
Feral Orks reference (p140) Reference page is missing the Ork Warlord character. Copy from second line on Ghazghkull's War Horde reference page (p135).
Feral Orks reference (p140) Steam Gargant Speed 12cm. Assume this should be Speed 15cm.
Feral Orks reference (p140) Steam Gargant critical hit effect "All units in 2D6cm suffer a hit." Should be "All units within 2D6cm suffer a hit." Compare wording with titan reactor explosions on (p7).
Last edited by Heavens To Betsy on Thu Feb 23, 2012 7:59 pm, edited 1 time in total.
PostPosted: Mon Feb 20, 2012 7:42 pm
Siegemasters reference (p51) Imperial Guard Supreme Commander is missing Supreme Commander ability in the Notes section.
PostPosted: Thu Feb 23, 2012 9:59 am
Scions of Iron - pg 15 - Should be a page break at "SCIONS OF IRON SPACE MARINE ARMY REFERENCE 2" and there will have to be a REFERENCE 3 as well.
Page 45 is blank.
Minervan Tank Legion - pg 51 - The Commissar rule seems redundant (if there's a difference I'm just not catching, then ignore me!).
War Gryphons Titan Legion - pg 75 - Hypaspist and Tech-Priests not listed at all; page break needed at "REFERENCE 2".
Red Corsairs - pg 115 - the last two lines got cut off (probably an A4 -> 8.5x11 issue).
Red Corsairs - pg 119 - the last line got cut off
Iyanden Eldar Craftworld - pg 172 - the last line got cut off
Scarab Conflict Necrons - pg 194 - Eques Maniple - it'd be much clearer (to me, anyway) if it said that Destroyers could be substituted by Heavy Destroyers "for free".
Thanks!
PostPosted: Fri Feb 24, 2012 7:26 pm
Death Korps of Krieg: Medusa Siege Gun's entry lists "Firepower: Medusa Siege Gun".
PostPosted: Thu Mar 08, 2012 7:18 pm
War Gryphons Titan Legion (pg 76) Warlord should be allowed to take Scout and Battle Titan weapons. (or, if it's intentional, then the Skitarii Warlord should be restricted in the same manner.)
PostPosted: Thu Mar 15, 2012 7:37 pm
Page 53,
Death Korps Engineers, weapon notes are missing "Gas Grenades, (contact), (assault weapon)"
Death Korps Grenadiers, are missing "scouts" in the unit notes.
Grenadiers also used to have "AND (15cm), Ignore Cover" in the notes for heavy the heavy flamer in the 2010 draft, which is missing now. They didn't have it in Siege though so I'm not sure which is correct with or without?
cheers
PostPosted: Fri Mar 16, 2012 12:00 am
Found another needed correction on DKoK
page 53,
Death Korps Quad Launcher has FF 6+, it's 5+ in siege.
