Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page 1, 2  Next
Converting Gargants
 Post subject: Converting Gargants
PostPosted: Tue Feb 17, 2004 2:31 pm
Greeting Gentleman, it's just the new kid fishing for ideas.
Feel free to mock or ignore.
Anyway, I've got a mrk3 great gargant off ebay, which I want to rework into the E:A statline. ?This means I need to add a lifta droppa and at least one twin soopagun, plus a base. I plan to take a LD from a mekboy dragsta and possibly a twin soopa gun from an exceptionally old (possibly space crusade) assualt cannon and lollypop sticks.
Ais there any advice you people could give me?
Suggestions and advice appreciated. ?:)
"Do not act incautiously when confronting little bald wrinkly smiling men!"
-- Rule One (Terry Pratchett, Thief of Time)
PostPosted: Tue Feb 17, 2004 4:41 pm
*waiting for Krooza to arrive* :;):
Cheers!
PostPosted: Wed Feb 18, 2004 7:46 am
Yep, Krooza is definitely "da man" when it comes to Ork (or almost any other) conversions.
However, some of my (not so humble) opinions follow.
The lifta-droppa needs IMO an "upper arm" plus an "elbow" joint to look good. Otherwise it will end up looking somewhat like a semaphore.  :;): I can't recommend any specific parts but anything which looks like heavy construction equipment is a good choice.
If you manage to make an ammo belt for the soopagun it'll be even more impressive.
Good luck with the conversion and don't forget to post pics!  :;):
PostPosted: Thu Feb 19, 2004 10:27 am
Quote (Mojarn Piett @ 18 2004 Feb.,06:46)
The lifta-droppa needs IMO an "upper arm" plus an "elbow" joint to look good. Otherwise it will end up looking somewhat like a semaphore. ?:;): I can't recommend any specific parts but anything which looks like heavy construction equipment is a good choice.
Good luck with the conversion and don't forget to post pics! ?:;):
Thanks, Piett, I've got something in mind for the arm, a gorka morka weapon mount I think.
oh, and I argee, Krooza's work is great. I loved the "Frosty da snowman" ?gargant.
PostPosted: Thu Feb 19, 2004 10:37 am
Well thanx for all the praise u guys but I realy dont have that much to say other than the best thing to do is brouse the net for as many Gargant pics u can find, your bound to find something that inspires you. Once u have a real good idea of what you want to do make sure you use the best parts possible for the job, making do with second choice parts will lead to you being unhappy with the end result no matter how much care n attention you put into your conversion.
You often find lots of good deals on ebay, resently there was some asorted Mega Gargant parts for sale.. I think they sold for about ?2 in the end.
Personly I like my gargants to have big arm mounted weapon. The Mk 1,2,3 and 4 all suffered from having tiny arms. You may find the SupaLifaDroper from an Ork Dragsta to be a bit on the small side.
Nuf Said.
PostPosted: Thu Feb 19, 2004 4:42 pm
Thanks man
PostPosted: Thu Feb 19, 2004 8:23 pm
I should also mention that you can use WH40K Ork parts to convert Epic Gargants so dont feel you have to restrict yourself to using souly epic bitz. All my Gargants use lots of WH40K parts, just think carefully about weather your chosen parts make convincing epic scale bitz and youll have no problems.
Nuf Said.
PostPosted: Thu Feb 19, 2004 8:33 pm
How about the BFG plastics?
I imagine that the various sensor masts would make for good bits. Nova cannons would be good big guns as would lance turrets with a little work.
I have some bits left over from a slightly hit an miss attempt at kill kroozas.
PostPosted: Fri Feb 20, 2004 10:36 am
If it looks good then use it...
Theres no set of rules stating what u can and cant use in ur conversions :;):
Nuf Said.
PostPosted: Fri Feb 20, 2004 10:56 am
Just remember the racial character and you'll be fine. Ork equipment tends to look like it was bashed together from any available scrap because usually it has been.  :p  That's why you can use just about anything except Eldar parts; these are too pansy for an Ork.  :;):
PostPosted: Fri Feb 20, 2004 12:57 pm
Quote (Mojarn Piett @ 20 2004 Feb.,10:56)
Just remember the racial character and you'll be fine. Ork equipment tends to look like it was bashed together from any available scrap because usually it has been. ?:p ?That's why you can use just about anything except Eldar parts; these are too pansy for an Ork. ?:;):
But you CAN use Ork parts for an Eldar conversion... :L
Back from oblivion (again)?
PostPosted: Fri Feb 20, 2004 1:27 pm
Quote (vanvlak @ 20 2004 Feb.,11:57)
Please elabourate.
PostPosted: Fri Feb 20, 2004 1:36 pm
Quote (Ork Dreadnought @ 20 2004 Feb.,13:27)
Please elabourate.
Here goes:
see here. Try the links referring to Firewings - the wings stuck on the old plastic Falcons are the cowcatcher blades from the MegaGargant - although I 'd admit the Mega-G is a rather particular ork model. :-:
PostPosted: Fri Feb 20, 2004 3:18 pm
I think the old firestorm AA gun would nook nice as an extremely shooty arm weapon for a gargant...
Cheers! :)
PostPosted: Sat Feb 21, 2004 1:15 pm
Quote (vanvlak @ 20 2004 Feb.,12:36)
Please elabourate.
Here goes:
Oh I see
Users browsing this forum: No registered users and 147 guests
