Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 144 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
NETEPIC GOLD DOWNLOAD LINKS - FINALIZED
 Post subject: NETEPIC GOLD DOWNLOAD LINKS - FINALIZED
PostPosted: Sun Oct 18, 2009 7:09 pm
Core rulebook:
http://www.netepic.org/uploads/3/4/2/0/ ... erules.pdf
Adeptus Astartes (Space Marines) Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... tartes.pdf
Ork Army Book
http://www.netepic.org/uploads/3/4/2/0/3420807/orks.pdf
Chaos Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... /chaos.pdf
Eldar (Eldar, Exodites, Harlequins, Dark Eldar) Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... /eldar.pdf
Adeptus Militaris (Imperial Guard) Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... itaris.pdf
Adeptus Titanicus (Titan Legions) Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... anicus.pdf
Adeptus Ministorum (Sisters of Battle) Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... storum.pdf
Slann and Necron Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... necron.pdf
Squat Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... squats.pdf
Tau Army Book
http://www.netepic.org/uploads/3/4/2/0/3420807/tau.pdf
Tyranid Army Book
http://www.netepic.org/uploads/3/4/2/0/ ... ranids.pdf
Furter play aids and NetEpic 5.0 available from the Epicentre at http://www.netepic.org
http://www.netepic.org/netepic.html
Last edited by Warmaster Nice on Tue Oct 16, 2012 7:05 pm, edited 3 times in total.
PostPosted: Sun Oct 18, 2009 9:36 pm
Hooraay!
All praise go to Warmaster Nice! And, of course, to all guys involved!
Thank you all very much. Your dedication and the result, this formidable ruleset, have been one of the reasons I started playing Epic again.
:agree:   :O  :agree:
PostPosted: Sun Oct 18, 2009 9:53 pm
:D
WOW! For once I'm...
My head is full of War...
PostPosted: Sun Oct 18, 2009 10:14 pm
Praise the Emperor (WarmasterNice and Stuff)
I am not available for that cognition on my part :D
PostPosted: Sun Oct 18, 2009 11:08 pm
There is no reference to damage in the hull location in the Gargants´ templates of the Ork Army Book
PostPosted: Mon Oct 19, 2009 12:05 am
Hi WMN,
Firstly, awesome news.....and fantastic work!!!!
However, so far I've also picked up an ommission or two in the Ork book.  Do you want them PM'd, emailed or put up here so people can see what's been detected so far?
Fire bad, tree pretty - Buffy
PostPosted: Mon Oct 19, 2009 12:07 am
Bugger :S
Probably better to post them here. That way this thread can work as a living eratta document where people can't miss them untill we have time to fix the errors.
So: If you find an omission/error, post it here along with the page number and roughly where on the page the error is found. If possible also post the eratta so people know what it will eventually be changed to.
PostPosted: Mon Oct 19, 2009 1:32 am
For the most part I think they should be relatively easy to fix.  What I have so far:
Adeptes Astartes:
1/ The description for the Drop Pods (P22) is incomplete.  It needs the following added to finish it:
"attacks and the pods have no further effect, but the models remain on the board and may be shot at and destroyed for Break Point calculations.
4) Place the Assault and Support Pods within 20 cm of the landing point and not touching any unit, and scatter them 2D6 cm. After placing them, point to each one and roll a D6. On a 3+ it opens. If it fails, try again in each Compulsory Movement Phase until it does open. Troops disembark on Advance Orders and lose the normal 5 cm of movement for leaving a transport. Support Pods that open deploy plasma gun platforms and always fire in the First Fire Phase.
Pods that land on another model (friend or foe) cause a hit with –3 TSM. The pod itself is unharmed if it lands on a Vehicle-class or smaller unit, and is destroyed by anything larger. If the target has active shields the pod knocks down one shield before being destroyed."
2/ The Desert Lions 11th company should have only 2 Robot Detachments (P32)
Orks
1/ The Steam Gargant is missing.  No description, no template, no army card, no statistics summary.
2/ The Blasta Bomma has a description, but no army card or statistic line.
3/ The Supa Stomper is the same as 2/
4/ The Following was added to the Notes section for each Gargant Template:
"Unsaved hits on Hull locations cause a fire on a 6 result.  Otherwise there is no effect."
This should probably replace the existing Note in the templates as I don't know where "must move toward closest enemy" came from.
That's it from me so far.  I'll try and fine tooth comb things once I stop going Oooo and Ahhh at the books!   :yay:
PostPosted: Mon Oct 19, 2009 2:55 am
I'm mighty glad to see them finally rolled!  :O
Definitely post errata here. Easier to track and access.
My favorite is the Ork book. Keep using the mixed format of color plates and such where appropriate, it makes the books look stunning!
My humble thanks to everyone whom has helped.
Enjoy the books guys!
PostPosted: Mon Oct 19, 2009 7:51 am
Having just read the orkbook some, I noticed 1 thing about weirdboys the 21-25 and 26+ Energy points are missing, are these gone or just missing?
(they are in the 5.2 Ork book on wikiwikiwar)
PostPosted: Mon Oct 19, 2009 8:02 am
Great work!  :yay:
I noticed:
NetEpic Gold Rule Book
- page 5: header "NetEpic [u]5.0[/b] Core Rules" -> Maybe it'stime to replace 5.0 by Gold ?
Fair players live longer
Epic40k.fr Techpriest
PostPosted: Mon Oct 19, 2009 8:49 am
Morning,
after hours of oozing over GOLD, I finally managed to gather myself again. So, let's get started with the bean counting  :laugh:
Adeptus astartes
Land Raider Company:
After a long and heated debate, there was an agreement to lower the cost to 700 points
Space Wolves Long Fangs:
The Long Fang's break point is 4, not counting the Rhinos. They have to be wiped out. The BP in Gold was identified as transcription error from NE 5.0.
Gold Rulebook
p.28: Description "Forest":
discard the following relict from NE4: "(or use artillery)"
it is not possible to shoot troops in woods with artillery anymore, sentence is misleading.
p.34: Anti-Aircraft Box:
Last sentence: "are consi_t_ered aerial targets."
in standard flyer rules:
we agreed to the following: Landing transports lose their + 25 cm bonus, since their not flying high anymore
p.34: Arc of fire box
Flyer rules state that flyers have an arc of fire of 180°, in the Arc of Fire box there is still the old value of 360°.
flamers:
a note that flamers on FF can shoot at charging enemies (as stated in NE4.0 FAQ, affirmed later for 5.0 as well)
from the NE 5.0 errata:
Page 17. Under the Floaters Special Ability #8, replace "while at high altitude" with "while in the air".
Page 17. Under the Fliers Special Ability #1, replace "other than bolters (or their equivalent)" with "other than
Point Defense".
Speaking of experience, some clarifications that were omitted in 5.0 would be nice for newbies to have again:
shooting out of close combat rules
are missing. (remember, the discussion with the pinning groups?)
Snap-Fire:
"Units cannot Snap Fire and make a pop-up attack. The unit must already have LOS in order to make use of Snap Fire."
Cumulative Damage on Titan Hit locations:
Would be nice to state that the damage roll bonus is permanent and dependent on the exact location.
That's it for now  :sleep:
PostPosted: Mon Oct 19, 2009 9:01 am
on Page 37, 38 Adeptus Astrates Book
Land Raider Crusader Stats the 2 different TSM are in one row
as some other stats are
PostPosted: Mon Oct 19, 2009 9:20 am
I forgot to say it looks AWESOME! I'm going to have to print em all at work =D
PostPosted: Mon Oct 19, 2009 10:36 am
Astartes Gold:
There are 2 entries in the statistic table for the land speeder (one standard and one with 6+f save + Elite).
Users browsing this forum: No registered users and 76 guests
