fow bases
 Post subject: fow bases
PostPosted: Sat Aug 01, 2009 5:39 pm
I saw a battle report the other day and the person was using fow (small bases) with epic infantry on them (they looked great) and just wanted to know if anyone else it doing that and how much does it change blast templates.
thanks
tim
PostPosted: Sat Aug 01, 2009 5:45 pm
I think the overall consensus is that base size and shape is pretty insignificant as long as it follows the overall guidelines given in the rulebook. Compact bases are less likely to be covered by blast templates but more difficult to have formations stretch out in larger zones of control. In game terms the pros and cons outweighs each other.
PostPosted: Sat Aug 01, 2009 6:04 pm
im thinking of rebasing mine, just did one and really like the look of it, but then again i also like the look of the circle base ive seen as well, the choses we have to make lol
tim
PostPosted: Sat Aug 01, 2009 6:20 pm
I highly recommend FOW small bases for Epic.
They are well within the size guidelines in the rulebook, and they have enough space for a 'realistic' squad formation, or to fit a tank on one.
PostPosted: Sat Aug 01, 2009 6:40 pm
Jeridian
Those are great looking. thanks for the pictures, going to have a lot of work coming rebasing mine, but im up for it. thanks again
tim
PostPosted: Sun Aug 02, 2009 3:18 pm
The one thing about FOW bases (and for that matter WH40k/WH bases): the beveled sides look nice, but they make it hard to actually grasp the bases.
I find that double-layer WM bases, or a 3mm litko base is much easier to grab hold of... which means I'm not grabbing the minis themselves.
PostPosted: Sun Aug 02, 2009 3:39 pm
what sizes are they if i were to order them from litko?
PostPosted: Sun Aug 02, 2009 7:25 pm
http://www.litkoaero.com/page/LAI/CTGY/FoW
1"x1 1/4": 25mmx31mm roughtly.
$18 for 100.
Dave had good luck countersinking minis into 1mm or 2mm Litko bases (with a magnetic base below it),
PostPosted: Sun Aug 02, 2009 11:15 pm
I easily side with Carrington on the con of FoW bases.
But I advocate 30x20 from renedra.co.uk and 40x30 from kallistra.co.uk (who also have antislip backing).
If you want to go pure fire teams (2-3 ppl) then renedra also have 20x15.
- Erik M
PostPosted: Mon Aug 03, 2009 5:42 am
What cost are the F0W bases? They seem superior to the warmaster base.
PostPosted: Mon Aug 03, 2009 7:22 am
The small ones - for infantry and most AVs are £6.50 for 54 - thats the rrp anyway though you can usually get them for about £5.50 at most stores.
Medium ones - suitable for SHTs, land raiders etc are £6.50 for 26
www.epic-uk.co.uk
PostPosted: Fri Aug 14, 2009 10:56 am
How do people sink the models in? Suitable sized drill bit and don't go to far?
PostPosted: Fri Aug 14, 2009 1:19 pm
The FOW base is a little thin for drilling.
I generally 'green stuff' (modelling putty) around the bases of models on top of the base- barely noticeable.
Users browsing this forum: No registered users and 91 guests
