Post new topic Reply to topic  [ 230 posts ]  Go to page 1, 2, 3, 4, 5 ... 16  Next
Land Raiders
 Post subject: Land Raiders
PostPosted: Wed Jul 08, 2009 9:06 am
Quote: (Hena @ 08 Jul. 2009, 06:59 )
Land Raider Redeemer
Armoured Vehicle; Save 4+; Speed 25cm; CC5+; FF3+
Frag Launchers; (base contact); Assault Weapons
Twin assault cannon; 30cm; AT4+/AP4+
2 x Flamestorm cannon; Range 15cm; AP3+; Ignore Cover
Notes: Reinforced Armour, Thick Rear Armour, Transport (1 Terminator or 2 other)
Possible changes that can be done depending on playtesting:
Redeemer. Upgrading range to 30cm on Flamestorm. Upgrading FF to 2+ (this would make it very good for Librarian).
Just to point out it is already the best place to put a librarian with the above stats (FF3+ with RA4+).
Do the redeemer guns grant FF IC?
Would the 30cm version be two shots or one?
Do you want links of past reports of Redeemer configs posted here?
Land Raider Crusader
Pair of Hurricane Bolters, Small Arms, Extra attack (+1)
If there was ever a model like the GW one of a dred with a hurricane bolter set up how would the above stats mesh with that? Grant half an attack, raise its FF to 2+ and make it the librarian dreadnought, something else? I ask because a lot of weapon stats are done with forwards capacity in mind.
PostPosted: Wed Jul 08, 2009 10:26 am
We'll get back to testing those Melta Crusaders tonight.
PostPosted: Wed Jul 08, 2009 10:40 am
A further point.
In the BA list you have the Baal Predator - twin assault cannon, 2 x Heavy Flamers
In the Sally list you have a weaker variant, pred incinerator - autocannon, 2 x Heavy Flamers
In both cases you are looking at a redeemer which is either 35 points more (Sallies) or 12 1/2 points more (Blood Angels). I think people should bear in mind redundancy and especially in the case of the blood angels relative worth (for 12 1/2 pints more I get RA and TRA, better flamers, cc and FF and transport 2 and speed 25 - the last two being down sides in the BA list) compared to the Predator annihilator and a land raider (which is I think the closest parallel in the list). For Sallies its a bit different as use of Land Raiders is an integral part of their viability as mechanised troops.
PostPosted: Wed Jul 08, 2009 3:49 pm
I still think the idea of a multimelta that only has half the rules of a normal multimelta is confusing and against the epic ethos.
PostPosted: Sun Dec 13, 2009 2:22 pm
Hena,
Could you add the LR Ares and Terminus to this list?
Thanx!
Honda
"Remember Taros? We do"
- 23rd Elysian Drop Regiment
PostPosted: Sun Dec 13, 2009 4:22 pm
Since the only list with a Terminus is mine:
Land Raider Terminus
Armoured Vehicle; Save 4+; Speed 25cm; CC6+; FF4+
3x Twin Lascannon; Range 45cm; AT4+
2x Lascannon; Range 45cm; AT5+
The Apocrypha of Skaros 1.1
Rogue Trader Expedition 0.4
The Horus Heresy 0.5
Night Lords 0.1
My Trade Thread
PostPosted: Sun Dec 13, 2009 5:29 pm
QFT
PostPosted: Sun Dec 13, 2009 5:59 pm
That's why you put "pintle-mounted" on it... voila!  It's now a new weapon!   :laugh:
PostPosted: Sun Dec 13, 2009 6:02 pm
The original reason people pushed for "pintle mounted" was an admisitrative one; so that the MW could be an extra attack rather than the basic attack of the model. The overall effect would be the same, but the profile much more readable.
Why exactly would the MM of a land speeder be able to shoot, but one on a land raider wouldn't? There's no reason at all.
Either cut the MM entirely or reinstate the shot, but don't leave it as this amateurish-looking half-way-house. I'm in favour of cutting it entirely; the crusader is currently the best LR by far.
PostPosted: Mon Dec 14, 2009 4:43 pm
The Land Speeder is a much more manouvreable firing platform? Instead of being stuck in a limited firning position between two oversized track units, the Speeder can zip to and fro, re-positioning itself to fire for effect with its one main gun.
All weapons are not deployed or used equally, just because they have the same theoretical capabilities. A differnce between two seemingly identical weapons does not have to come across as "amateurish" at all.
(Kinda in the the same way a power armoured eight foot super human with a selfloading heavy weapon can get off more shots per minute than an Imperial Guard gun crew having to push their weapon around...)
Either way, testing the Crusader without MW FF attacks might shed some light on the matter? It IS an excellent tank even with just "normal" attacks, as you say.
"Don't use finesse, if force will solve the problem."
- Lieutenant General Michael O'Neal
PostPosted: Mon Dec 14, 2009 4:52 pm
Yea but being pintle-mounted the Multi-melta has a 360° arc of fire. I guess a Marine could rotate it much faster than a Land Speeder could swing around.
Soin fact pintle-mounted is even better than on the Land Speeder  :laugh:
PostPosted: Mon Dec 14, 2009 5:00 pm
Fact is, the Multi-Melta is an optional upgrade for Land Raider Crusaders in Warhammer 40,000, and it having weird half stats in Epic makes little sense, decreases rules elegance*, and isn't particularly balanced in any case**.
* Which is supposed to be one of the hallmarks of Epic rules design.
** It was never the ranged shot that was causing problems for the Crusader, but its too-good FF power.
PostPosted: Mon Dec 14, 2009 5:09 pm
BlackLegion --> Well, I do believe otherwise, for the following reasons. The LR weapon cannot adjust its altitude. It cannot skim lateraly. It cannot fire from above the enemy at will. I'm not only talking about fire arc, but also of possible fire positions and rapid relocation of the firing weapon between them. On all these points a Speeder mounted weapon beats a ground tank mounted one, hands down. If you just look at the exact piece of hardware the weapon is physically attached to the vehicle with (the pintle mount), you miss the point of my reasoning. A weapon that can be adroitely handled in a fast paced fire fight, should be more efficient in FF combat imho. Weapons that are more "clumsy" but still have great fire power, should be represented by ranged fire instead.
(The part about the marine carried heavy weapon was a complete OT from my part. It's my reasoning why SM tacticals get more heavy weapon shots the IG infantry stands. Sorry for digressing.)
PostPosted: Mon Dec 14, 2009 7:02 pm
As E&C points out, the ranged MW shot was never a problem on the crusader, it is the MW FF that has always been the issue.
Actually it's the increased transport capacity that's the real problem, but that's pretty much fixed and can't be changed.
