Hello all!Lock on with pulsars
 Post subject: Hello all!Lock on with pulsars
PostPosted: Sun Sep 07, 2003 6:09 pm
Hello all!
I?m wondering if anyone knows if the eldar pulsar get to reroll all their 3 shots if they are on the special order "lock on"?
I play Imperial myself but i have only played the game 3 times and tomorrow i?m going up against eldar for the first time.
Thanks in advance.
PostPosted: Sun Sep 07, 2003 7:20 pm
I believe that they do, but they can only reroll each of the shots once. It is usually best to roll three dice at the same time, then pick and roll the rerolls, then apply any results.
PostPosted: Mon Sep 08, 2003 10:30 am
Yes, basically for each pulsar, roll the dice.  If you miss re-roll.
If you then hit, you get another shot.  This too can be re-rolled if you miss, and the same for the last shot if you hit again.
PostPosted: Mon Sep 08, 2003 11:11 am
Thanks for the help!
I?ll make sure to stay out of the way of them pulsars...  :)
PostPosted: Mon Sep 08, 2003 4:31 pm
It?s very rare for Eldar to lock on due to the vulnerability, on the other side there?s the bonus of almost certain hits.
So big results can be won for a brave (or stupid) Eldar commander...
PostPosted: Tue Sep 09, 2003 8:00 am
HI again.
I dont have a rulebok so can some one plz tell me how lockon is dealt with Eldar.You are not alowed 2 turn when you have lock on but may eldar tuen in the ordonance phase`?
I guess not,they have 2 remain locked on but i am not sure plz help.
And one very noob and basic guestion what is you allowed to measure?  If target is within range? Yes  Move ? I am not sure
Plz clarify this 4 me .
BRGDS MAGNUM.75
PostPosted: Tue Sep 09, 2003 8:19 am
you cannot turn when locked on (except for free turns from gravity wells, which Andy Chambers has indicated are a bonus from good strategic movement so should be rewarded). You can still change speed between the movement phase and the ordnance phase.
PostPosted: Tue Sep 09, 2003 9:49 am
Thx
