Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3, 4  Next
Proxy titans
 Post subject: Proxy titans
PostPosted: Thu Sep 02, 2004 11:10 pm
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
Hello all,
in my soon to be ordered onissian army (based on the IG, ordered as soon as I move to Brighton) I plan on having a pair of warhounds. However, as with most IG moels I don't really like the models. I was thinking about getting proxy models from other companies and game systems. The obvious choice would be battletech models I suppose, but they look a little bit large to me. My idea is to have them be "mechwarrior style", devises piloted with a single individual while the thing repoduces its movements.
Since I am planning on them bing warhounds I thought that having them in a dinalic position would look good. I already thid that with an eldar wraithlord in 40k (I have it kneeling down grasping a shuriken cannon as a regular trooper would fire a rifle in that position) and was thinking about a similar idea for the warhounds.
I have failed to see titans listed in Mksim's amazing 6mm site, so I thought I should be asking here :)
Any ideas of companies/models to use here?
Health and sixes,
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Thu Sep 02, 2004 11:33 pm
Battletech and related items are quite a large pool to pull from. However, others I would look towards:
CAV (Larger, but some would make good "Warlord" titans)
25mm/28mm lines such as void have robots that might be good to use.
I would also look toward some of the Victorian SciFi lines, some good "metal men" in them.
dafrca
              - Cities of Death, page 59
PostPosted: Thu Sep 02, 2004 11:43 pm
You like battletech style but do not like the Forgeworld Warhounds?
my 2cents,
iblisdrax
PostPosted: Fri Sep 03, 2004 12:08 am
I like the CONCEPT, of titans operated by a single individual, but not necessarily the models themselves :) In general i was looking for something more humanoid in appearence, with arms et al, carrying a weapon in their hands. I should have explained it better, sorry. Actually, i find the FW models to b quite good, but they do not fit my tastes completely. In general I dislike titans having a hunchback of notredame position, finding it quite ridiculous in some cases and this is why I was asking :) I will check dafraca's suggestions.
Cheers!
Xavi
PostPosted: Fri Sep 03, 2004 1:16 am
Quote (Xavi @ 02 2004 Sep.,16:08)
In that case, check out more of the Anime toys. They tend to be closer to the "Humanoid with gun in hands" style.
Watch the sizes as they can get big, but Gundam or Robotech for example would fit that kind of "robot with gun" style.
dafrca
PostPosted: Fri Sep 03, 2004 2:49 am
I use BT mechs extensively as proxies in the netepic slann armies. The scale and style of some of them mesh quite well with epic miniatures. I think you should be able to find something that suits you. :)
PostPosted: Fri Sep 03, 2004 7:15 am
I would recommend you first take a look at the CAV because the mechs are generally quite a bit smaller than the Titans. An Adeptus Titanicus Warhound is a bit larger than a BT Battlemaster.
PostPosted: Sun Sep 05, 2004 2:49 am
Quote (Mojarn Piett @ 02 2004 Sep.,23:15)
Except that if he is looking for the "humanoid with gun in hand" the CAV line may not fit his needs. That is why I am thinking some of the many Anime style toys. They are larger then the normal mech from battletech and most are the gun in hand style.
dafrca
PostPosted: Sun Sep 05, 2004 2:50 am
Xavi, don't forget to let us know what you do end up with. It is always fun to see/hear what others are using. :)
dafrca
PostPosted: Sun Sep 05, 2004 5:50 am
And, AHEM,
PICTURES!
PICTURES!
PICTURES!
Sorry, just had to do that.:D
my 2cents,
iblisdrax
PostPosted: Sun Sep 05, 2004 7:14 am
Hya there!
Well, actually I plan to have a picture of my starting force when I build it up. It is likely to end up formed with T-34/45 or M1A1 tanks for armour and other similar non-GW stuff for other things (man, how I dislike the leman russ :lol: ), so yup, pictures indeed. But you will have to wait a while for them, since I am no ordering and painting them until I move to Brighton (Sussex, UK) in a little bit more than a month :cool:
Thanks for the input. I will research those avenues. My fear with the regular anime things is that they look too "tau-ish" thanks to GW than invented the Plato followers of 40k (well, if taking the republic almost exactly can be considered "invent", that is)
health and sixes,
Xavi
PostPosted: Sun Sep 05, 2004 5:08 pm
T34/85s & M1s !  Nice !  :;):
PostPosted: Sun Sep 05, 2004 5:43 pm
Also ... Check out Brigade Models ... FM-148 Cronus ... interesting looking Mech/Titan ... :;):
PostPosted: Mon Sep 06, 2004 3:14 am
http://www.ghqmodels.com/store/n15..html
http://www.ghqmodels.com/store/r151.html
Those were the basde that I was thinking on use for the tanks. The advantage of the soviet ones is that they also have the tank hunter version (SU-2) that come along with these tanks! ( http://www.ghqmodels.com/store/r152.html ) Still, this is quite an investment when it comes to epic minis, so I might reserve it for the tank company. I simply cannot stand the regular leman russ, heh. Too big and ugly for my taste. I can look at it, but will not field one unless I must (like if I have to get some to get in epic tourneys ever).
regards,
Xavi
PostPosted: Mon Sep 06, 2004 5:09 am
GHQ does nice stuff ! ?But it might be a bit small for Epic ? ??? ?I'm not sure, I don't have any on hand to compare ? ?And a sidebar, a US Army M1 Co. only has one Hummer and no M577, Unless that has changed. ?M577s are usually found at Bn and Bde HQ levels. I think the Soviet Combat Team with the ISU 122s is kind of IG-ish !!! :;):
