i see 3K everywhere, throwing my project in disarr
 Post subject: i see 3K everywhere, throwing my project in disarr
PostPosted: Thu Oct 07, 2004 9:31 pm
Has anyone here been following the debate about the Skimmer rules over on the Offical board?
Just curious, if you have, what do you think of this new effort?
dafrca
              - Cities of Death, page 59
PostPosted: Thu Oct 07, 2004 11:27 pm
Hi,
I had a read through the last couple of pages of the thread and must say that I am in agreement with Jervis on the subject of abstract levels for terrain. Adding complex (and rather unnecessary) rules like that will slow down the gameplay, and no doubt cause more problems than they solve. I can see why people have suggested the 'level' rule, but I don't like it's "baggage".
I have no problem with using the '15cm' rule, as it represents a skimmer 'popping-up' (as it's supposed to, rather than flying (as some people fail to differenciate)), and rising above the terrain directly in front of it to spray fire onto enemy units just on the other side. If you want units that can attack anything on the board, use aircraft or artillery, that's their role, not that of skimmers. The 15cm rule is, in my opinion, easy to follow and makes better sense than some suggestions.
As always with the SG forums, a lot of the people want a way to make their army better than the others, rather than finding a way of resolving problems that come up in games. Possibly because a lot of the discussion is about tournament situations rather than non-tourney games. I would've rather seen the issue discussed either when the rules initially came out, or after the Swordwind add-on is released, as it seems that this is more of an argument over Eldar (and their players who want advantages over other armies), rather than the skimmer ability that all armies use in some manner.
Oh well, I have faith in JJ to make a suitable decision over the matter, as he seems to be really against adding complex rules.
Freshmetal
Blastmarker.com
PostPosted: Thu Oct 07, 2004 11:37 pm
We use a similar rule in netepic, although its higher (30cm I think).
I find it funny that a lot of Epic A discussions cover issues that netepic has dealt with years ago....
..just a thought..... :;): :D
PostPosted: Fri Oct 08, 2004 12:56 am
Quote (primarch @ 07 2004 Oct.,15:37)
It does not surprise me. When you think about it. More then half of those who are doing the talking on the SG board are under 30. In fact, quite a few have said they were younger.
They have not been through the SM/Epic40k wars. They have not had the time to formulate the ideas nor do they have the past experiences that would show them the way.
Netepic has the advantage, in my opinion, of many people who combined have a lot of experience. With EA there is Jervis and a few old timers, then the bulk are newer players.
dafrca
PostPosted: Fri Oct 08, 2004 3:12 am
Point taken.
While I peruse the Epic A lists and seldom post, I am sometimes tempted in commenting and recommending reading over some of the netepic books for solutions to some problems. The debate of the Tyranid list is a case in point. I think they would benefit in the solution we gave the original rules shortcoming and perhaps tailor them to solve the current ones.
I dont do so beucase perhaps it would be interpreted the wrong way. On some forums thats all too easy... :;):
PostPosted: Fri Oct 08, 2004 3:25 am
Quote (dafrca @ 08 2004 Oct.,09:56)
Not only experience with Epic, but wargaming experience in general.  Many just getting into EA havent the experience some of us have had with board wargames and other miniatures games because of the rise of PC and XBox etc.
Tas
PostPosted: Fri Oct 08, 2004 4:28 am
We treat skimmers, based on the old SM2 rules. ?We look at skimmers like modern helicopter gunships. We let them "pop-Up" over all terrain. Buildings being generally the highest piece of terrain on the board. ?A chopper (skimmer) hovering just above the ground behind an AT/SM1/SM2/TL/E40K structure could easily pop-up and fire. ?So the actual height of the pop-up is irrelevant. ?Jump pack troops, can only jump over an obstacle no higher than 8cm (SM1 rules).  Just the way we do it ! ?:;):
PostPosted: Fri Oct 08, 2004 5:06 am
Quote (Tas @ 07 2004 Oct.,19:25)
Not only experience with Epic, but wargaming experience in general. ?Many just getting into EA havent the experience some of us have had with board wargames and other miniatures games because of the rise of PC and XBox etc.
Good point. Many of the GW follower's experiance with "wargames" is limited to 40k. There is little tactics in reality in 40k that they often do not know how to handle a game that does not have a "Herohammer" feel to it.
Note, I am not trying to slam them, I too had to start somewhere. :cool:
dafrca
PostPosted: Fri Oct 08, 2004 5:18 am
IMO, there are NO tactics in 40K with their current and past (silly) rules !!!  :;):
PostPosted: Fri Oct 08, 2004 5:59 am
Quote (Legion 4 @ 08 2004 Oct.,04:28)
We treat skimmers, based on the old SM2 rules. ?We look at skimmers like modern helicopter gunships. We let them "pop-Up" over all terrain. Buildings being generally the highest piece of terrain on the board. ?A chopper (skimmer) hovering just above the ground behind an AT/SM1/SM2/TL/E40K structure could easily pop-up and fire. ?So the actual height of the pop-up is irrelevant. ?Jump pack troops, can only jump over an obstacle no higher than 8cm (SM1 rules). ?Just the way we do it ! ?:;):
So you give unlimited LOS to popped up skimmers same as the current EA rules?
PostPosted: Fri Oct 08, 2004 6:11 am
Quote (Freshmetal @ 07 2004 Oct.,23:27)
Hi,
Freshmetal
Agreed  :D
PostPosted: Fri Oct 08, 2004 7:16 am
We treat skimmers, based on the old SM2 rules.  We look at skimmers like modern helicopter gunships. We let them "pop-Up" over all terrain. Buildings being generally the highest piece of terrain on the board.  A chopper (skimmer) hovering just above the ground behind an AT/SM1/SM2/TL/E40K structure could easily pop-up and fire.  So the actual height of the pop-up is irrelevant.  Jump pack troops, can only jump over an obstacle no higher than 8cm (SM1 rules).  Just the way we do it !  :;):
Interesting. In the (VERY slowly progressing) Hammer Head (Epic -> MSH conversion) I decided to treat Skimmers just like that: use the MSH helicopter rules nearly as is.
Now what was it they say about great minds and how they think...?  }:)  :laugh:
PostPosted: Fri Oct 08, 2004 7:58 am
Quote (Legion 4 @ 07 2004 Oct.,21:18)
IMO, there are NO tactics in 40K with their current and past (silly) rules !!! ?:;):
Not to be argumentative, but there is at least one tactic.
Line up with your most powerful leader in front, charge the enemy, fight until they or you are dead.
It is a tactic, not a good one, nor a sane one, but it is a tactic. ?:p ? ?:laugh:
dafrca
PostPosted: Fri Oct 08, 2004 1:24 pm
Hi,
Was thinking about this a bit more last night, trying to think of which method of play would be both representative of the current E:A rules and remain flowing gameplay-wise. Here are my musings, I don't want to start any arguments or discussions over specifics, I just wanted to put the method I was considering into writing. Enjoy:
* Pop-up attacks are exactly that, they are not flying attacks. The skimmer unit pops-up, fires, and drops back to ground level all within the period of one turn. ie: it must pop up every turn if it wants to fire over the terrain, it cannot "float" hundreds of feet up in the air. (although some skimmers represent helicopters which should be able to do so; to help game flow, all skimmers are regarded as ground-level "hover-ers".)
* A pop-up attack is a special action that can be chosen in the action phase. (ie: rather than an advance, engage, etc.) Units popping-up must therefore take an action test and are affected by the -1 for retaining initiative, etc as per normal.
* Units that pop-up don't receive a sustained-fire bonus for remaining still, the pop-up advantage cancels it out.
* Units that pop-up trigger Overwatching enemy units the moment they pop-up. Resolve overwatch fire before resolving fire from the unit popping-up.
* Shooting:
The shooting player draws a line from his up-popping unit to the intended target (shortest line possible between the two formations). The shooter may then fire along that line disregarding any terrain that starts within 15cm of his position along this line. Therefore any terrain that is between the two units that doesn't start within 15cm of the shooter is treated as normal (NO MATTER HOW TALL IT IS).
EXAMPLE: An infantry formation stood partially in cover of a low ridge is targetted by a skimmer unit 30 cms away, however the skimmer is directly behind a building. The attacking player announces a pop-up attack and measures the range from his position to that of the infantry formation. He is within range and can therefore fire.
As the building is within 15cm of the skimmer making the pop-up move (and directly between the two formations), the skimmer may disregard it (and it's LOS-blocking properties) to fire at the infantry freely. (It would NOT matter how close either formation was to the terrain piece being popped-over, as long as the firing unit is within 15cm. This will avoid the problem of out-of-scale terrain and "terrain shadows", etc. May not be realistic, but is quick, easy and keeps the game flowing.)
However, the ridge that is partially covering the infantry unit begins 25 cm away from the skimmer. Therefore, even though the ridge is physically shorter than the building being popped-up over, the infantry still receive the cover save it would normally. (Unless the skimmer chooses to only target those troops not in partial cover.)
* If the skimmer rules are to remain fluid and easy to follow, you MUST consider terrain, etc in a slightly abstract manner. Putting too much detail into the physical dimensions of shooting will simply slow down play and annoy people. If a complex rule is introduced, I can see people using a house-rule in it's place. This should be the other way around. A simple rule such as this should be used, and anyone who wants a "technically-correct" version can use their own house rules (as with the current E:A rules). This would also keep tournament games flowing to retain their time limit. Although I don't play tourney rules most of the time, I know a lot of people do, and these rules help them.
* These rules remove not only the problems inherent with "terrain shadows" and varying scale terrain (including flat terrain), but also remove the need for "pop-up" markers.
*I see pop-up attacks as a tactical decision rather than a "sit behind a wall and fire from safety turn after turn" thing. Pop-up attacks need to be planned and considered just like every other move, and so should have some disadvantages to mirror it's advantages.
These are just my musings from last night, so don't read too much into it. I simply wanted to explain how I think it should work (more for my own benefit than others :p ), and was wondering how others would 'like' to see it done.
Freshmetal
Blastmarker.com
PostPosted: Fri Oct 08, 2004 3:01 pm
In netepic we give them 30cm striaght up, but terrain does block LOS. Whatver the skimmer sees at that hieght it can target and what it cant, it cant fire at. Units eligible for snap fire (overwatch) can hit them before they fire or disappear.
In that sense its very much like what Freshmetal has said. This has been in place for netepic for 7 years. Highly playtested, rock solid rule.
Users browsing this forum: Google [Bot] and 119 guests
