Legion of Balmung
 Post subject: Legion of Balmung
PostPosted: Fri Dec 28, 2007 6:44 pm
Hello out there,
This is a writeup for the Chapter I created when Rogue Trader first came out and I have played it off and on as various editions changed the game.
This is how I saw it in Epic, with only a few changes from a standard Maine list, I have tried to keep it to the format of Net Epic 5.0.
The key one is the use of Jet Bikes (I have a companies worth in both 40K and Epic scale).
Any comments/critiques are appreciated.
Ray,
Legion of Balmung
Originally part of the 2nd Founding, this Chapter was thought lost until reports reached the Nibelungen III system governor of a suspected Eldar pirate outpost being attacked by an unknown Space Marine force.
Follow up investigations revealed the identity of the force as belonging to this lost chapter.
The Legion of Balmung made contact with the appropriate Imperial Authorities and presented records of a prolonged fight and campaign against Ork and Dark Eldar groups during their centuries of absence.
Part of these records was proof of a lost Adeptus Mechanicus template for experimental Jet Bikes.
Though pleased to have one of the missing chapters back, the inquisition was disturbed by some of the changes the centuries of isolation from the Empire had caused.
Though given a new world to call their own the Legion of Balmung is being watched and evaluated to see if their lengthy absence and proximity to corrupting influences have weakened their loyalty and purity to the Emperor.
Company Type
First Terminator or Veteran
2nd Battle
3rd Battle
4th Battle
5th Battle
6th Tactical
7th Tactical
8th Bike or Jet Bike
9th Devastator
10th Scout
Special Rules
1) Mounted Company: ?In place of the normal 9th Assault Company the Legion of Balmung has the Eisen Blitz Company composed of all mounted marines either in jet bikes or standard bikes. ?This Company can only take support and special cards with a movement of 25 cm or more ?
2) Faith and Destiny: ?The Bike/Jet Bike Apothecary and Bike/Jet Bike Medic may only be taken as a Special card for the 9th Company and must use the same Bike type as the Company. ?
Prohibited Cards
None (Exception, see Special Rule 1)
Codex Cards
All Standard Adeptus Astartes cards (Exception, see Special Rule 1)
New Units
Eisen Blitz Company: Space Marine Company mounted on fast-attack 1 Man skimmers similar to standard Marine Bikes
Space Marine Apothecary Bike: Space Marine Medic mounted on a motorcycle to support fast-attack formations
Space Marine Apothecary Jet Bike: Space Marine Medic mounted on a 1 man skimmer to support fast-attack formations
Space Marine Chaplain Bike: Space Marine Chaplain mounted on a motorcycle to support and inspire fast-attack formations
Space Marine Chaplain Jet Bike: Space Marine Chaplain mounted on a 1 man skimmer to support and inspire fast-attack formations
Space Marine Jet Bike: 1 Man fast-attack skimmer armed similar to a standard Space Marine Bike but with added maneuverability
Space Marine Jet Bike HQ: The Command unit for a Space Marine Jet Bike Company. ?They are command, Elite, HQ units and have the Inspirational ability.
Company Cards Contents Break Point Morale Victory Points Cost
Jet Bike Company * Marine Jet bike HQ
3 Marine Jet bike Squads 8 2 6 550
Special Cards
Apothecary Bike * Stand - 1 75
Apothecary Jet Bike * Stand - 1 100
Chaplain Bike * Stand - 2 100
Chaplain Jet Bike * Stand - 1 125
Support Cards
Cavalry
Jet Bike Squad * 5 Marine Jet Bikes 3 2 2 175
Troop Type Move Save CAF Weapons Range Attack Dice To-Hit Rolls TSM Notes
Special
Apothecary Bike 30 cm 5+ +3 Bolter 15 cm 1 5+ 0 HQ, Medic
Apothecary Jet Bike 30 cm 5+ +3 Bolter 15 cm 1 5+ 0 HQ, Medic, Skimmer
Chaplain Bike 30 cm 5+/6+f +5 Bolter 15 cm 2 5+ 0 Combat Leader, Command, Elite, HQ
Chaplain Jet Bike 30 cm 5+/6+f +5 Bolter 15 cm 2 5+ 0 Combat Leader, Command, Elite, HQ, Skimmer
Cavalry
Marine Jet Bike 30 cm 6+ +2 Bolter 15cm 1 6+ 0 Skimmer
Marine Jet Bike HQ 30 cm 6+ +3 Bolter 15cm 1 5+ 0 Command, Elite, HQ, Inspirational, Skimmer
Well, Except for the Monkeys
PostPosted: Fri Dec 28, 2007 6:55 pm
Interesting. I like how you have characters mounted on Bikes and Jet Bikes.
Since you have written this for NetEpic, you might want to have the thread moved from EA Adeptus Astartes, which is for Epic: Armageddon rules.
PostPosted: Fri Dec 28, 2007 7:44 pm
If that is where it should go (uhmmm how do I move i).
I placed it here as this was listed as the adeptus astartes section and I though this is where it would be appropriate
And what exactly is Epic Armaggedon (as opposed to Net Epic)?
I stopped playing Epic right around Epic 40,000 and only got back into it earlier this year (with my son who wanted to know what all the stuff was in storage)
Having given it a quick once over, do the stats and costs for th Jet Bikes and the Chaplain or Apothecary seem balanced?
They used to offer both types of characters on bikes and jet bikes so it seemed that they should be special cards available for the company.
Ray
PostPosted: Fri Dec 28, 2007 8:58 pm
Epic: Armageddon is the current edition of Epic. The rules are almost completely different from NetEpic, which is based on Space Marine/Titan Legions. PM Cybershadow to move this thread to its proper home.
I'm glad to hear that you've returned to the Epic fold, especially if your son is interested.
At first glance your stats seem okay, but they'll probably need some playtesting to  verify them.
PostPosted: Fri Dec 28, 2007 9:08 pm
Indeed it is good to have your children begin an interest in something you enjoy.
He has latched on to the Squats but also wants to run them in 40K
But his seconday army is Space Marines of which I have plenty (in both scales).
So is Armageddon basicly Epic 40,000 wiht more updates?
Ray
PostPosted: Fri Dec 28, 2007 9:15 pm
Not quite, EA isn't as abstract as Epic 40k.  It differs from SM/TL in that there are fewer special rules and more stream lined mechanics.
You can take a look at all the rules free here:
http://specialist-games.com/epic/rulebook.asp
For rule updates take a peak around these forums.
PostPosted: Sun Dec 30, 2007 1:45 am
(ArcadiaSSX @ Dec. 28 2007,20:08)
Armageddon will remind you of E40K a lot :).  It is less bland though.  Kinda hard to compare to SM2/TL as its lineage and mechanics are totally different.
Your new Marine Chapter looks fine.  I think the Jetbike Marines compare pretty well to the equivalent Eldar unit and are costed appropriately.  However I'm not sure why the Apothacary and Chaplain on Jetbikes are cheaper than the bike riding equivalents.  I'd make the Bike versions 75 and 100 and the Jetbike ones 25 points more....and perhaps even 25 points more all round if you play the normal Command rule.
Fire bad, tree pretty - Buffy
PostPosted: Sun Dec 30, 2007 6:19 pm
Somehow the costs for the Chaplain amd Medic Bike/Jetbike units got switched, I have it corrected now.
They should be:
Medic Bike 75, Medic Jet Bike 100
Chaplain Bike 100 Chaplain Jet Bike 125
When you say possible 25pts more do you mean just the Jetbikes or the mounted Medic, Chaplain in General.
Thanks for the comments.
Ray
PostPosted: Tue Jan 01, 2008 12:43 am
On reflection, perhaps an extra 25 for just the mounted Chaplains.  The standard version of Command with such large movement is very powerful.  If you play the optional rule for Command (we all do down here) then it is not so overpowering.
