Basing
 Post subject: Basing
PostPosted: Fri Aug 10, 2007 7:05 pm
What is the best for flocking bases? i use static flock in 40K and WFB but how would that work in Epic anyone have pictures? Is it too long for epic infantry bases?
Hibernian 22nd Imperial Infantry
"Grunts"
PostPosted: Fri Aug 10, 2007 7:15 pm
Anything goes - I personally prefer a blend of these; some feel that sand is a bit too large and looks like Easter Eggs (of all things!) in Epic scale, or that static grass is too long, although I like the lost in a grassland look.
Pepper looks very much like a dark gravel and is excellent , and it does not degrade. And clay-based (Fullers earth) cat litter looks like large bits of rubble.
Here's a sample showing the undesirable 'Easter egg' sand.
Back from oblivion (again)?
PostPosted: Fri Aug 10, 2007 7:16 pm
Static grass.
PostPosted: Fri Aug 10, 2007 7:18 pm
Static grass looks better with large models and tree trunks made out of sticks add contrast.
PostPosted: Fri Aug 10, 2007 7:20 pm
Part-covered base.
PostPosted: Mon Aug 13, 2007 12:08 pm
Nice!! Doesn't seem mad out of scale. I am really worried for the infantry but I might try a mix. Any one else with any suggestions? Whats good for Water? I want to put a little bit in a crater but I am not forking out for the water effect from GW!!
"Grunts"
PostPosted: Mon Aug 13, 2007 12:16 pm
I haven't tried it yet, but I believe 2-part polyester resin does a grand job.
Sand works well for me, I have various grain sizes from fine to coarse and mix and match depending on the size of the model.
For water leave a patch of the base uncovered and just apply several layers of ink. ?At Epic scale the shine will end up making it look like water
PostPosted: Mon Aug 13, 2007 1:43 pm
Just about any glossy varnish will work just fine for Epic scale water. Apply several layers if you want a depth effect.
PostPosted: Mon Aug 13, 2007 2:35 pm
Thanks, never tought of Gloss Varnish!! Doh!
"Grunts"
PostPosted: Tue Aug 14, 2007 6:17 am
I use flock and sand or both ... :D
PostPosted: Sat Aug 18, 2007 2:09 pm
I have some decomposed granite that I've been using for 15 years now....very fine mid brown.  These days I mix it 50-50 with GW static grass.  Nice effect IMO, though not so durable.
Fire bad, tree pretty - Buffy
