Space Marines vs Tyranids @ 2000 p.ts
 Post subject: Space Marines vs Tyranids @ 2000 p.ts
PostPosted: Fri Mar 17, 2017 5:48 pm
I'm trying to get a friend into Epic Armageddon. He's set on Tyranids, while I'm going to go with Space Marines.
I've tried to draft up two lists (2000 p.ts) with the aim of having them roughly balanced between themselves (and functional enough to be considered "competitive"), but as I'm very inexperienced I'm totally unsure if they're any good. I'd appreciate any feedback you care to throw my way.
2000 POINTS Codex Astartes (NetEA Tournament Pack 2015) wrote:
TERMINATOR [400]
4 Terminators, Chaplain
THUNDERHAWK [200]
1 Thunderhawk gunship
TACTICAL [300]
6 Tacticals plus Transport, Razorback
PREDATOR [250]
4 Annihilator
LAND SPEEDER [200]
5 Tornado
LAND SPEEDER [200]
4 Landspeeder, 1 Tornado
LAND SPEEDER [200]
MARAUDER SQUADRON [250]
2 Maurader bombers
Main questions are:
- Does the Thawk-transported Termie formation pack enough punch (assuming supported by at least one of the Sppeder formations)?
- Are Speeders even the "right" choice to support an assault? How about Bikes?
1995 POINTS Tyranids (Tournament Pack 2016-01-21) wrote:
TYRANID SWARM [570]
7 Termagants, Hive tyrant, 4 Carnifex, 3 Haruspex
TYRANID SWARM [240]
4 Termagants, 4 Hormagaunts, 2 Tyranid Warriors
TYRANID SWARM [300]
3 Termagants, 3 Hormagaunts, 2 Tyranid Warriors, 4 Zoanthrope
EXOCRINE SWARM [275]
5 Exocrine
GENESTEALER SWARM [150]
6 Genestealers
HARRIDAN SWARM [230]
Harridan, 4 Gargoyles
Main questions are:
- Am I bringing enough AA? Is plonking it all in a single squad as not to slow down the others a sound decision?
- Are the Gargoyles useful support for the Harridans, or am I better off fielding them alone and using those 160 p.ts for an additional formation?
 Post subject: Re: Space Marines vs Tyranids @ 2000 p.ts
PostPosted: Fri Mar 17, 2017 5:58 pm
Definitely.
Speeders are excellent at prep fire and support FF.
Other comments:
- I'd swap the Marauder for something else; Perhaps TBolts and upgrades. It's probably very good against Tyranids, but not against much else.
PostPosted: Fri Mar 17, 2017 6:40 pm
How about dropping the Razorback and swapping the Marauders for a Warhound?
PostPosted: Fri Mar 17, 2017 6:49 pm
could swap the third set of speeder to being scouts, then use the 50pts to change the second set of speeders into devastators (more variety, and probably a stronger build)
Swapping marauders to tbolts gets you some air cover. Swapping the marauders for warhounds will be stronger on the ground in many cases, but only if you know you'll never need AA.
PostPosted: Fri Mar 17, 2017 6:55 pm
Assuming you can get the THawk down without BMs it's a good assault formation loaded with just about anything. Failing that, landing, shooting and then supporting with Termiantors is useful as well if you have a ground formation without assault range.
Bikes and Speeders are in most of my SM lists. The former I tend to assault with and the latter I support with. They're both good for late game objective grabs but Speeders are that much more annoying with Scout, hence why I don't tend to engage with them.
I usually have 2 Zoanthropes and a Dom in a 3k game, so 4 Zoanthropes in a 2k should be good enough. I tend to hop the small swarms from cover to cover, so the 15cm Zoanthrope move doesn't slow them down all that much. They're usually able to get into a FF position when egaging turn 2 or 3.
Gargoyles are handy for the extra FF. You need to make sure they're further from the enemy than the Harridan when engaging though, so you're not giving the opposition easier kills.
Where are you located?
PostPosted: Fri Mar 17, 2017 7:38 pm
Thanks for the pointers, everybody. I'll try to work them into a list.
Italy. Unfortunately the chance I can get involved with the UK community irl is pretty tiny.
PostPosted: Fri Mar 17, 2017 9:49 pm
Sounds like a good case for some vassal games! ;)
