Steel Legion robustness
 Post subject: Steel Legion robustness
PostPosted: Sun Oct 09, 2016 12:56 pm
I'm thinking of dropping sentinals (100 points) & using the points to bulk out the HQ Mech Inf with extra Chimeras
army list -
http://traitor-legion.appspot.com/chooser.html?list=IG_steelLegion_NETEA&force=Incompertus~512~35x1~32x1~26x2~514~35x1~32x1~26x3~514~35x1~32x1~26x3~502~41x1~502~41x1~509~519~519~520
Thoughts & comments appreciated
 Post subject: Re: Steel Legion robustness
PostPosted: Sun Oct 09, 2016 2:12 pm
why bassi over manticores?
PostPosted: Sun Oct 09, 2016 3:37 pm
Started using them over Manticores for 2 reasons:
Due to SR they normally would get taken out first, Basilisks 5+ opposed to 6+ armoursave
Dont like their Slow firing rule
worked out quite well for me
PostPosted: Mon Oct 10, 2016 4:30 am
Pretty sure extra chimeras can only be taken to transport infantry. You can't just take empty ones.
My steel legion PDF might be a bit old, but I suspect that hasn't changed.
PostPosted: Mon Oct 10, 2016 1:06 pm
Yeah as far as I know (off the top of my head) the only way you could get 2 extra Chimeras into your HQ for 100 points is 2 stands of Ogryns and 2 Chimeras for 100 points. It's not something I've tried before as I would normally lean towards the Sentinels because I'm usually struggling for activations. In 4000 points it's definitely something I've considered although usually for my BTS to deter Air Assault
PostPosted: Wed Oct 12, 2016 10:20 am
I did have that niggling thought in my mind that you cant take more transports than units - which is a shame imho. Will investigate more, but wonder why the option to keep adding them is a viable option in the app.
PostPosted: Wed Oct 12, 2016 10:54 am
Do you know the force your opponent will be fielding? Not the exact list as such, just the race?
PostPosted: Wed Oct 12, 2016 11:11 am
no its for tourny, so expecting SM/ork/eldar
PostPosted: Wed Oct 12, 2016 11:36 am
my thinking is on this ; 25 points for a chimera which adds an autocanon, bolter 5+ save and extra bm resiliense, by removing say sentinels I can get 3 griffons plus 2 chimera for a mech inf coy. Issue is on traitor app once you purchase an upgrade it greys out, not so with the purchase of transport, which in theory means i could buy 10 extra for the mech coy for 250 point making it harder to break. I found the 1.7.5 rule but doesnt clarify if I can buy the chimeras in excess of the stands it can transport
PostPosted: Wed Oct 12, 2016 11:47 am
found the answer - http://www.tp.net-armageddon.org/army-l ... egion.html states in the army list no more than stands or there abouts
PostPosted: Wed Oct 12, 2016 11:55 am
Check the army list for confirmation . Uprades marked with * when chosen allows the option to take chimeras and only to a maximum of 1 per unit. Griffons are not marked with an * so do not allow chimeras to be chosen as upgrades.
from te netEA list
* These upgrades may add up to one Chimera per each of their units for +25 points each. All infantry units in the formation must be transported in Chimera if any are taken but you may not take more than one Chimera per unit in the formation.
