Space Marine Razorback use?
 Post subject: Space Marine Razorback use?
PostPosted: Fri Dec 13, 2013 4:04 pm
I'm thinking of converting some Rhinos into Razorbacks and I have a couple of questions. If you use Razorbacks (or any alternative transport to Rhinos), are the units Rhinos kept or replaced?
Tips or strategies using Razorbacks?
 Post subject: Re: Space Marine Razorback use?
PostPosted: Fri Dec 13, 2013 4:19 pm
rhinos essentially 'top up' the transport slots, so pick all your upgrades, add razorbacks, add land raiders, then 'fill up' the remaining transport slots with the minimum number of rhinos
for example, 4 stands of devs, add a razorback, and then add 2 rhinos.... if you added 2 razorbacks, you could only add a single rhino
most people use them to increase formation size, and give them a handy AT or AP shot, scouts with Las razorbacks are nice garrison troops
PostPosted: Fri Dec 13, 2013 4:25 pm
Agreed Kyuss. Note people usually buy odd numbers of RBs to leave a small transport excess (one unit).
I don't think there are any formal tactics on their use of BBs, except perhaps to keep one in the front, so that if it is destroyed by long range AT fire, the formation does not automatically lose its mobility.
PostPosted: Fri Dec 13, 2013 8:11 pm
I find them handy as adding firepower to Dev unit.....
PostPosted: Fri Dec 13, 2013 8:14 pm
I was considering this. Which type do you use?
PostPosted: Fri Dec 13, 2013 10:00 pm
Very much depends on the enemy I face. If it's a tank heavy enemy I go with AT (obviously!) I also sometimes add a couple to a tactical squad and park them on my blitz with on over watch
PostPosted: Fri Dec 13, 2013 10:09 pm
If you've only got a spare 25 points to eat up and can't afford a dread sometimes they can be handy to add ommph to a scout garrison. Another approach that can make for a nasty little nut to crack is with devestators (4 on 4 razorbacks). Usually in 3k points other things are more needed (Thawks) but above that that can be a handy reaction force and objective grabber.
PostPosted: Fri Dec 13, 2013 11:21 pm
Ginger wrote:
Note people usually buy odd numbers of RBs to leave a small transport excess (one unit)...keep one in the front, so that if it is destroyed by long range AT fire, the formation does not automatically lose its mobility.
This is very true and good advice. If I have the points I add a single Las Razorback onto some to all of my Tactical, Devestator or Scout formations. I never normally add more than 1 to a single formation.
Generally in Epic AT fire is more valuable than AP fire. I take a Lascannon Razorback over a Heavy Bolter one 95+% of the time.
PostPosted: Sat Dec 14, 2013 12:14 am
Yep single razorback to a formation here or there, though a mate also has also used full razorback transport to good effect.
PostPosted: Sat Dec 14, 2013 12:56 am
usually for the extra transport and the additional AT shot (without landraiders somewhat lacking in the spacemarine lisst). They are a solid filler.
- No plan survives contact with the enemy -
Imperial Guard
Space Marines
Eldar
