The care and feeding of Leman Russ Conquerors
 Post subject: The care and feeding of Leman Russ Conquerors
PostPosted: Sun Dec 02, 2012 10:04 pm
Just like the title says, what are your recomendations and tactics for leveraging conquerors in your tank lists?
thanks!
 Post subject: Re: The care and feeding of Leman Russ Conquerors
PostPosted: Sun Dec 02, 2012 10:27 pm
Which ones? Ulanii or Minervan? Minervan I'd form them into platoons and use them as objective grabbers and scout killers 4+RA and 35cm move is killer, let alone the gun. Ulanii Conquerers would have much the same use, but are far more fragile.
PostPosted: Sun Dec 02, 2012 10:44 pm
not to mention much slower too...
PostPosted: Sun Dec 02, 2012 11:32 pm
Minervan. Yeah stumbled onto 12 of them for $20 (total steal) and needed to figure best way to swing them. You'd suggest a platoon per what point size? 6 units per 3k? More? Less?
PostPosted: Sun Dec 02, 2012 11:38 pm
Honestly? They seem totally spammable. I don't own enough to field effectively myself, but two squadrons in 3k seems like it wouldn't be a bad bet. Play with it a bit - I'm interested in your results.
PostPosted: Mon Dec 03, 2012 9:18 am
Hmm, I would take LR-Coys, when I want to field my three Companies at 3k. One with normal Layout (2xVanquisher, 8 LR, Hydra), one with 10 Exterminators and one Hydra and then the third would be one Conqueror-Coy with Hydra. Tank Platoons are not taken by myself because I primary field two LR-Coys. Enough LR, other things are more important (artillery, scouts, AA, Flyers).
PostPosted: Tue Apr 07, 2015 11:16 pm
Add a platoon of 3 of them to your salmanders in your scout companies along with a platoon of 3 griffons and four vultures as air recon scouts. Also add a platoon of mechanized infantries in chimeras along with a fire support platoon. In other words, an armored cavalry company.
PostPosted: Tue Apr 07, 2015 11:20 pm
continued..don't forgot the four sentinels. Used it as a spearhead for a combined arms battalion, which consist of two tank and two mechanized infantry company.
PostPosted: Mon Apr 13, 2015 9:08 am
Would be nice to see. But it doesn't work, because Companies are required. And Minervans doesn't have Scout companies.
