Titan Legion 3000
 Post subject: Titan Legion 3000
PostPosted: Sun Mar 20, 2011 1:19 am
since the AMTL PDF force changed to the point where i cant run it without major changes, ive opted to try out the Titan Legion.
Reaver Titan
- Legate
- Carapace Multi Lasers
- Quake Cannon
- Quake Cannon
- Carapace Landing Pad
Reaver Titan
- Veteran Priceps
- Laser Blaster
- Laser Blaster
- Laser Blaster
Warhound
- Mega Bolter
- Plasma Blastgun
Warhound
- Mega Bolter
- Plasma Blastgun
Warhound
- Inferno Cannon
- Turbolaser
Warhound
- Inferno Cannon
- Turbolaser
4 sentinels
4 sentinels
8 activations is a bit low, but titans are pricey. i think i have most of my bases covered. thoughts?
 Post subject: Re: Titan Legion 3000
PostPosted: Sun Mar 20, 2011 12:32 pm
It's a fun list to play, too :)
thoughts?
I suggest exchanging one or two warhounds for airpower, at least two pairs of TBolts; Air support is really useful to finish off broken units that are hiding outside the Titan's LOS; the artillery Titan usually has more important things to do. It also ups your activation count, which is always a concern for AMTL.
PostPosted: Sun Mar 20, 2011 3:29 pm
From experience, Single warhounds die fast as do the sentinels. 2x sentinels is a good and useful choice as it gives you a good screen for each of your battle titans. Having two warhound singles and one warhound pack would give you a bit more use at the cost of an activation.
at the very least I'd combine two of the warhounds into a pack and swap one sentinel for a Tbolt formation. The extra Air will help you out quite a bit. If you didn't want to lose activations you could probably do the same by dropping the CML on your LasBlaster reaver and the vet princeps and combine two of the warhounds into a pack. THat should free up enough points to take the thunderbolts and keep the two sentinel formations.
-Vaaish
PostPosted: Sun Mar 20, 2011 4:01 pm
i decided to drop one of the turbolaser/inferno cannon warhounds for 2x2 tbolts.
