Post new topic Reply to topic  [ 106 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
How would one defend against an air assault
 Post subject: Re: How would one defend against an air assault
PostPosted: Mon Jan 30, 2012 11:47 pm
Jaggedtoothgrin wrote:
for reasons unknown, it was decided that aircraft approach moves do not trigger overwatch, despite there being nothing in the rulebook to this effect
I think Neal deals with that in his earlier post
PostPosted: Tue Jan 31, 2012 12:34 am
the "reasons unknown" refers to the fact that when you have a leaking drainpipe, you dont blame the clouds. and now the drainpipe in thes metaphor is fixed anyway, so there is no reason to continue to mis-rule regarding the clouds.
PostPosted: Tue Jan 31, 2012 1:25 am
nealhunt wrote:
Guys, as with the other thread, once we clarify that the intent of the "screen from behind" FAQ is in relation to non-intermingled units, I think this is pretty clear. Geometrically speaking, there must necessarily be some way to enter the target ZoC prior to entering the ZoC of any non-intermingled scout unit. Doing so effectively puts the scouts in the "screen from behind" position.
If the screening formation can be intermingled (or any other formation, for that matter), they must be intermingled in order to enter their ZoC.
If the screening units cannot be intermingled, the target can be attacked by CC, including aircraft landing on them.
This is how we have played it and will continue to play it here in Western Australia.
Planes are complicated things... ::)
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Tue Jan 31, 2012 10:24 am
Personally I think this interpretation is a massive change from what is played and I strongly disagree - as with disrupt hits causing BMs on holofields. If I'm reading it correctly then you are saying that a scout screen cannot be used at all.
www.epic-uk.co.uk
PostPosted: Tue Jan 31, 2012 11:59 am
I don't think that is what he is saying. Consider these examples.
In the first diagram, the scouts and target cannot be considered intermingled. However, because they are far enough apart so as not to be intermingled, that means it is possible for the attacker to enter the ZoC of the target without entering the scout ZoC first, by going round to the left. The FAQ says that if the attacker does this, he must try to get into base contact with the target, not the scout. Even if he has to enter the scout ZoC in between. The FAQ therefore solves a problem with the rules where the attacker can enter the ZoC of the target but is prevented from getting into base contact due to the ZoC of the scout. Otherwise it would actually be possible to make it so the attacker cannot get into base contact with either formation.
In the second diagram, the scout's ZoC extends entirely over the target's ZoC such that it is impossible to enter the target's ZoC without first entering the scout's ZoC. This means that the attacker is not allowed to get into contact with the target because he must contact the scout first. However, because the scout is close enough to the target for this to be the case, the attacker can treat them as intermingled if he wishes. Thus the defender has been able to screen the target, but cannot do so without risking the target entirely.
PostPosted: Tue Jan 31, 2012 12:27 pm
Of course, what I would now like to know neal is, what happens with an air assault in this example:
PostPosted: Tue Jan 31, 2012 12:58 pm
Not to mention that the same thing could be done with a single, broken, scout unit, if the target formation is in a table corner.
PostPosted: Tue Jan 31, 2012 1:16 pm
Fire fight them.....
PostPosted: Tue Jan 31, 2012 1:23 pm
Find out whose birthday is closest? ;D
PostPosted: Tue Jan 31, 2012 3:11 pm
Edit: I'm not following how you are reading it.
A scout screen has to be interposed to be effective. Using a scout screen against aircraft is practically impossible because of the mobility of the aircraft allow it to approach in a way where the scouts are not interposed. Against anything else it works just fine.
Is that what you meant?
PostPosted: Tue Jan 31, 2012 3:26 pm
Your problem example is a formation of 1 unit being air assaulted out of the center of a scout formation? That's beyond theoretical, but in any case, that's the exact situation covered by the "screen from behind" FAQ - a screening formation that cannot be intermingled projects its ZoC over the intended target. If the screening formation cannot be intermingled, then the target formation can be approached despite the screening formation's ZoC.
PostPosted: Tue Jan 31, 2012 3:36 pm
I'd handle it in one of two ways:
1) The AC/WE barges the lone stand, everything disembarks and charges the closest Scouts from where it disembarks but stops just shy of base-to-base or at it's full disembark move (whatever happens first). Since the Scouts weren't intermingled you can't BtB them.
2) The AC/WE lands and the first stand to disembark charges and BtBs the lone stand, the rest of the stands charge the Scouts as above.
If you find yourself in ZoC and assault you have to charge (or counter-charge for that matter) the closest enemy stand not in CC regardless of what formation it belongs to. Whether or not you can actually BtB it though is determined by the formation it belongs to or intermingling.
PostPosted: Tue Jan 31, 2012 4:07 pm
I believe that at least part of the answer is implied in Kyrt's diagrams and description. However, I would like to see the "troublesome" FAQ replaced with something like this, to answer the various questions being posed.
Q. I want to assault a target formation that has interlocking Zones of Control from other enemy formations around it. Can I enter more than one Zone of Control?
A. Each assaulting unit may only enter the Zone of Control of a unit in the target formation. If you cannot do this, you must either stay outside the enemy Zones of Control and firefight, or declare other formations intermingled. A unit may not simultaneously enter the Zone of Control of two enemy units. Once within the Zone of Control of an enemy unit, the assaulting unit must avoid the Zone of Control of enemy units from other formations, but may ignore enemy scout Zones of Control.
PostPosted: Tue Jan 31, 2012 4:36 pm
I'm not sure that it does Neal; people are erroneously confusing the "screen from behind" FAQ with the situation where the THawk lands between the scout and target and both enemy are more than 5cm apart. (This actually applies to any two enemy formations that are close but not intermingled). The issue being that some are arguing that this FAQ allows the air-transport to be placed in multiple ZoC for an assault.
PostPosted: Tue Jan 31, 2012 5:08 pm
i said they cannot possibly barge without first having landed (because until that time they are aircraft, and aircraft ignore all units, which means they cannot move over them, a prerequisite for barging) and then, having landed, they become a 0cm move unit that cannot possibly move over an enemy unit with which to barge them.
Wow. I had typed out a really long response and then I realized that you are sometimes using "move over" to mean establishing base contact rather than just in the sense of "positioned on top of."
It's clear aircraft can be positioned over enemy units. That's not base contact, just flying overhead, ignoring everything on the ground. 4.2.1:
Aircraft are assumed to be travelling high enough above the ground to fly over terrain, zones of control, and other units (in other words they ignore all three things!)
If an air transport ends its approach move directly over an enemy unit and lands, that converts the aircraft to a ground unit, which is now in base contact with and on top of the enemy unit. They don't have to "move over" an enemy unit after landing because they are already on top of it before they change to a ground unit.
Your last assertion above seems to be that the aircraft has to "move over" (make base contact with) the enemy only after it becomes a ground unit because that is how the 3.3.1 barging rules apply ground-move WEs. However, the air assault rules provide the landing process in place of on-the-ground movement. They refer to the aircraft landing "as if it were charging."
Air Assault: Transport aircraft may choose to land as
described above, and then it and any units that disembark are
allowed to fight an assault instead of shooting. If this option is
chosen then the aircraft ... may enter
enemy zones of control as if they were charging.
If it lands on top of an enemy unit, then "as if it were charging" would include barging effects.
This inclusion of barging effects as part of the "as if it were charging" idea in addition to the explicit ZoC entry is the only extrapolation in the FAQ. That contradicts no rules or other FAQs.
there is absolutely nothing to say that they can only barge units they directly stop on top of, that is certainly not a part of the regular barging rules, so why would it apply to aircraft?
I agree that the regular barging rules don't have any "only when they stop on top" limitation. That restriction applies to aircraft because it's part of the aircraft rules, not the barging rules.
I also agree it's not explicitly stated as a limitation in the aircraft rules. It's the result of applying the aircraft movement and landing rules. The aircraft does not become a ground unit until after the end of the approach move, when all movement has stopped. The result is that with no remaining move, only units the aircraft land on top of can be subject to barging effects.
so what is to stop a thunderhawk from flying across the table, grabbing the enemy supreme commander and two other friends
This is what made me realize you are conflating "moving over" as an aircraft with "moving over" as a ground WE. "Moving over" as an aircraft obviously has no base contact and no barging.
We can beat on the OW/aircraft rules elsewhere, but whether the FAQ is OW-specific or because it shouldn't exist at all, we both agree it is not relevant to the barging rules.
