Post new topic Reply to topic  [ 158 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
Siege of Terra - Dreamlike Gaming December 30th
 Post subject: Re: Siege of Terra - Dreamlike Gaming December 30th
PostPosted: Fri Dec 20, 2013 9:35 am
Also I believe we are leaving destroyed war engines on the table as cover, I'm making flame markers to mark destroyed war engines
PostPosted: Fri Dec 20, 2013 9:42 am
One more thought, are we allowed to move flying units between tables?
PostPosted: Fri Dec 20, 2013 10:55 am
Steve54 wrote:
Imperials
Mark p+Erin - 5k each - only 1 loaded thunderhawk per player, no spacecraft, only 1 teleporting formation per player. Mark can bring Jonson if he wants as SC on top of the 5k
Oh holy hell, I think I've got some painting to do, even with upgrading detachments to the hilt ;D
Will go digging through my bits and pieces tonight to see what I can whip together to bump my force up a bit.
Quick daft Q, was a decision made on whether to use the BA list or codex marines list for BAs?
Web Designer / Developer type | erinfreeman.co.uk
Harass me on twitter!
PostPosted: Fri Dec 20, 2013 10:57 am
BA/codex entirely up to you.
If you need more points let me know what and I'll bring my Marines for you
www.epic-uk.co.uk
PostPosted: Fri Dec 20, 2013 11:08 am
Ok, cool, I don't mind getting a few more bits and pieces painted up but I'll let you know if I need any extras once I've had a dig through my sprues to see what I can get sorted. I have so many unpainted marines knocking around I should be able to bump it up enough though :)
...three land raider detachments should do the trick, right? ;D
PostPosted: Fri Dec 20, 2013 11:27 am
Steve54 wrote:
Imperials deploy on, and behind, massive walls and in fortifications in front. Chaos deploy up to and in small walls.
Steve, just to check on which sort of wall is which – are the massive walls the meter long palace facade and the small walls my old ones as used at the campaign weekend? If so, not sure how easy it will be to deploy behind the palace block as it's not an entire palace, just the front section of a far vaster building (which i cba to build and would take up entire tables on its own etc). Palace is also going to be one lump not sections.
Or, are the massive walls the ones from the campaign weekend, in which case all is good ;)
Similar thinking to me! 19 chaos LR ;D
PostPosted: Fri Dec 20, 2013 11:29 am
Well I'm bringing a bit of everything.
Actually I'm brining it all, so I'll have lots of reserves ready to bring on.
PostPosted: Fri Dec 20, 2013 12:38 pm
Erin, I have blood angels stuff you can borrow. My marines may be doubling up as traitors if I don't have enough bits in my BL force.
@MephistonAG for all sorts of twitter madness
PostPosted: Fri Dec 20, 2013 4:17 pm
Apoc, no the massive walls are the ones you're doing now, the walls we used at the campaign weekend are the smaller set that run across the table
PostPosted: Fri Dec 20, 2013 4:19 pm
I'll edit the placement of the new walls and table 1 (thanks for the info Matt) add the WE wrecks rule and tweek the teleports
www.epic-uk.co.uk
PostPosted: Fri Dec 20, 2013 5:14 pm
Ok one question, what time are we aiming to start this extravaganza?
PostPosted: Fri Dec 20, 2013 5:16 pm
Someone needs to web cast this game live.
PostPosted: Fri Dec 20, 2013 5:22 pm
If I get chance/remember/don't freeze solid I'll tweet about it all day.
PostPosted: Fri Dec 20, 2013 5:29 pm
9
www.epic-uk.co.uk
PostPosted: Fri Dec 20, 2013 5:50 pm
I'm hoping to pick Apoc up on the sunday and get set up ready to start early on monday, so we should be able to get stuck in right away
