[NetEA] Imperial Navy Section - DRAFT 2010
 Post subject: [NetEA] Imperial Navy Section - DRAFT 2010
PostPosted: Mon Dec 13, 2010 4:57 am
Greetings from the NetERC and the NetEA Project!
Please find attached the 2010 Draft of the Imperial Navy section of the NetEA Army Book. Please examine this document for typos, inconsistencies, and unclearness, or any other issues you may feel need to be resolved before final release.
Thank you!
This section includes the following armies:
No armies at all! Only Imperial Navy Allies units.
2010 - NetEA-ArmyCompendiumS1.3 - Imperial Navy.pdf [43.6 KiB]
Downloaded 805 times
 Post subject: Re: [NetEA] Imperial Navy Section - DRAFT 2010
PostPosted: Mon Dec 13, 2010 10:34 am
Maybe the empty experimental section should have the text '[Empty]'.
An online epic force creator:
Armyforge
PostPosted: Mon Dec 13, 2010 2:22 pm
Where did the lightning stats come from? Must say highly unimpressed doesn't fully sum up my response.
PostPosted: Mon Dec 13, 2010 2:40 pm
The Elysian's list, the only list that I'm aware they're in.
PostPosted: Mon Dec 13, 2010 2:43 pm
They're in the Sisters of Battle list too IIRC?
PostPosted: Mon Dec 13, 2010 2:46 pm
Which hasn't been submitted to me so I haven't looked at it; how do the stats differ?
PostPosted: Mon Dec 13, 2010 2:47 pm
Can't remember, ask Zombo.
PostPosted: Mon Dec 13, 2010 8:48 pm
Call it Imperial Battleship and Imperial Cruiser.
Ditch the class names. It doesn't do justice to BFG. ;)
Light at the Horizon.
Warp Rift
Project Distant Darkness
Eldar MMS
GothiComp Hall of Fame
PostPosted: Tue Dec 14, 2010 1:28 am
Code:
Imperial Navy Lightning Fighter
Type      Speed    Armour     Close Combat    Firefight
Aircraft  Fighter     -       N/A             N/A
Weapon                     Range     Firepower            Notes
Long Barreled Autocannon   45cm      AP5+/AT6+/AA6+       Fixed Forward Arc
Twin Lascannon             30cm      AT4+/AA4+            Fixed Forward Arc
PostPosted: Tue Dec 14, 2010 3:17 am
"Such formations use the Strategy Rating and other special rules of the army they are allied with."
Most lists I've seen specify the stratergy rating of allied formations as well as the main armies (and they're often different)
could the wording of the 2nd part of the sentence cause confusion? I'm not aware of any Imperial lists with army wide special rules, but for future prooofing?
PostPosted: Tue Dec 14, 2010 3:40 am
No army has different Strategy Ratings for different formations, not sure how that would even make sense; there are differing Initiative values which are, or should be, specified on an army by army basis, that's what the rule is indicating.
PostPosted: Tue Dec 14, 2010 10:44 am
The Armageddon Steel Legion PDF also uses both Lightnings. I took the stats from the Elysians.
PostPosted: Tue Dec 14, 2010 2:16 pm
Anyone know who actually wrote the various stats for the Lightnings?
T_R_C, you expressed disappointment in the stats, what do you think they should be like?
PostPosted: Tue Dec 14, 2010 2:30 pm
Zombo wrote his own for the Sisters list, as the stats in the Elysian list deviate somewhat by making up new weapon names/types I guess.
PostPosted: Tue Dec 14, 2010 4:24 pm
That, and as TRC said, the Elysian versions are rubbish. I also made them have no save as they're supposed to be much more lightly armoured than thunderbolts.
I really like the stats I came up with, as they provide an excellent interceptor that's relatively weak on ground attack, much as they should be.
