Post new topic Reply to topic  [ 172 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 12  Next
Stubborn development thread
 Post subject: Stubborn development thread
PostPosted: Sat Jun 07, 2008 8:35 am
(nealhunt @ Jun. 06 2008,23:58)
rpr: ?I think messing with assault resolution in such an extreme way is a bad idea in general. ?It is going to do a lot of weird things, including the squats wanting to lose if it's due to a bad roll.
"I'm at +3 and... I lost! ?Awesome! ?Now I get to stand around and crush even more of the enemy."
But as there is nothing optional in those rolls, that is only mental.Yes, it might be drastic, but Eldar and Necron have drastic rule changes.
Or do you assume that perhaps they start to pick up their casualties that way?
@E&C: 3 rule changes does not sound completely 'simple' for me :] The demiurg '+1 attack resolutions' is far simpler.
PostPosted: Sun Jun 08, 2008 3:52 pm
Testing Stubborn: a series of twelve 1,200 point matches using fairly standard infantry formations. An additional 100 points was given to each army for upgrades
As all of the lists were used to test variations on an assault or morale mechanic, as such, neither combined arms nor min-maxing was used. Overall the tests took a long time to resolve I was playing armchair general for about 15 hours?(ugh)
Space Marines:
2 tactical squads w/ rhinos +1 captain
1 devastator squad w/rhinos
2 Assault Squads +1 chaplain
Imperial guard:
3 Mechanized Infantry Companies +2 ogryns each for two companies
Orks:
1 ?uge Warband Mob +2 Kommandos and Warlord
2 Warband Mobz+ 1 boyz/grots each
2 Stormboyz Warhorde
Eldar
1 Warpspider Warhost +2 exarchs
1 Fire Dragon Warhost
1 Shining Spear Warhost +2 exarchs
1 Dark Reaper Warhost
Demiurg:
1 Iron-Breaker League Brotherhood (warriors) + trade factor (leader) +rhinos
1 Allied Sappers Guild Brotherhood (berserkers) + (trade factor)
1 Federated Master-Craftsmen Brotherhood (heavy weapons)
1 Merchant Service Journeymen Brotherhood (bikes)
1 Lineholder Grand Battery Brotherhood (tarantulas)
Both sides fought to control two of three objectives along the center of a 4? x 4? board
Dice rolls were tracked over each match averaging approximately 300 dice rolls, with the following average rolls: 1 (15%), 2 (17%), 3 (15%), 4 (18%), 5 (19%), 6 (16%).
The Stubborn options were tracked simultaneously with notes tacked onto the board at each event.
Basic conclusions: when faced with near equal numbers (Space Marines, Eldar) the Demiurg have a clear advantage in ranges attacks while still having enough assault units when they need to engage. This is always mitigated by the enemy having a higher Strategy Rating and better Initiative.
When faced with opponents that outnumber them (Imperial Guard, Orks), but with similar Strategy Ratings and Initiative the kill ratio generates two different strategies Overall the Orks were near impossible to wear down.
Observations
Space Marines: as expected the Marines low numbers per formation are always a management problem. ATSKNF helps a great deal; but in a straight up fight the Demiurg are a near statistical match for the Marines in all most every test. Demiurg averaged 2: 1
Imperial Guard: this yielded the most balance results as the firepower initially favors the IG, but the toughness of the Demiurg blunt much of their fire, and the activations and casualty rate eventually get the better of the IG. Taking three foot slogging companies and three Rough Rider platoons would have been more a of tactical challenge and given the IG more options. Demuirg averaged 3 - 0
Orks: the Demiurg need to keep the range open and fight for the objectives as almost a secondary strategy. Whittling away the formations supporting the large mass of troops yielded the best result, but they eventually found themselves overwhelmed by the number of units. Clearly their toughest opponent in this test. Demiurg averaged 0 - 3
Eldar: the specialization and lack of ranges shooting make the results a mixed bag, when they combine on a single target they eliminate it, but leave themselves open to counter-fire. As the victory conditions created a lot of close quarters bashing; Eldar speed and maneuverability could not be used to full effect. Overall the Eldar won most assaults but were cut down and wiped out frequently by the Demiurg shooting. In normal games they typically produce more balanced results. Demiurg averaged 2: 1.
Option Evaluation
Space Marine ? The infantry could re-roll any close combat dice with a score of one, against Orcs it was a one or two.
Result: this creates heartache for the opponent as the re-rolls give the Demiurg a huge boost force more save throws. Against a near equal force, the Demiurg nearly double their assault wins due to boosted casualty rates.
Conclusion: this option cannot be used. ?
Epic 40,000 - The infantry could be upgraded to Veterans, making them Stubborn which allowed them to re-roll leadership tests.
Result: Similar to The Thurgrim Stronghold option, this result gave the Demiurg very good results in the rally phase after getting knocked back or roughed up. The formation sizes, composition and points costs in The Demiurg are somewhat different, and impact may be different in large formations, but the number of victories were only marginally better than the average
Conclusion: This is an option that stays in the hopper
Assault and Morale combined Variant:
Thurgrim?s Stronghold ?
Squats are stubborn and are hard to break in assaults, and will rally quicker then other troops to get back into the fight and the following two rules represent this.
(1) Squats roll 3D6 in the final assault roll off, picking the single highest number rolled.
(2) Squats roll 2D6 for rallies picking the highest single number rolled.
Results: As noted the rally phase was not overly powerful regardless of the re-roll or 2nd (same odds). As for assault, more often than not the Demiurg topped the Marines and Guard, less well with the Eldar, and it only helped with the smaller Ork formations. Victory conditions overall favored the Demiurg (9 out of 12)
Conclusion: as stated earlier the Rally roll was fine, but the assault variation gave the Demiurg a big boost in assaults. I will test this again in a larger context.
Assault variants:
Demiurg Consortium ? All Demiurg are noted for their intractable nature. To represent this characteristic all Demiurg formations, except Autonom Cadres, are considered to be Inspiring and always add a +1 during each round of assault resolution. Note: A formation with a Merchant Prince will have a +2 modifier (+1 for the formation?s Stubborn attribute and +1 for the Merchant Prince?s character profile).
Results: this helped in marginal contests when the Marines or Elder rolled poorly. It was of little or no impact when faced off in FF with IG or CC with Orks.
Conclusion: this does not have a game winning feel to it as it only change the result of 1 game against the Eldar. This stays as a possibility.
Suggestion #1? The squat may choose to fight another round of combat instead of performing the resolution step.
Results: against Marines and Eldar this was a mistake and got the Demiurg killed (a lot!). It punished the IG and was only effective against small Ork formations.
Conclusion: Although it sounds like a good idea and seems to have a stubborn quality to it, the Demiurg died like crazy. This one has to go.
Suggestion #2 ? In Close Combat the Squat opponent does not gain the bonus for out numbering and out numbering by 2:1. OR the opponent does not get the bonus for out numbering, but does get the +1 bonus for outnumbering by 2:1
Results: fiddled with both variations, the first one was overwhelmingly bad for the opponent and I stopped playing it after the first game against Marines (they lost every assault!). The second one garnered results similar to the current Demiurg option, but showed up as a real advantage against intact IG companies and as suspected Orks.
Conclusions: The first variant is a no go. The second seems like it holds promise, but in larger contests where many of the Demiurg formations will be smaller, this becomes a huge disadvantage to horde units as their built in advantage disappears. This one gets crossed off.
Morale Variants:
Suggestion #3 ? Squats ignore the -1 modifier for enemy formations with 30cm during the Rally phase.
Results: pretty mild impact, still needing 2+ and 4+ to rally. Less useful than a re-roll.
Conclusion: this stays in the mix.
Suggestion #4 ? Give the Squats access to more than one Leader per formation.
Results: See #5
Conclusions: As initially suggested this is a dangerous ability, giving a nod to Fredmans, ?I will test a variation of multiple leaders with larger brotherhood formations.
Suggestion #5 ? The Squats are given the Leader ability as a Formation Ability. Additionally they would be able to add Leader stands to the formation.
Results: Only make the small formations more formidable. Tried this mix in the first game against marines, and rallied formations were unscathed at the start of each turn. The Marines were getting whittled down and the Demiurg kept coming on stronger.
Conclusions: this would require a review of formation size and point cost as it makes smaller formations and non-infantry formations more powerful. This is off the table.
Blast Marker Variants:
Suggestion #6 ? a toned down version of ATSKNF
- count 1 less BM for suppression
- count 1 less BM for assault resolution (minimum of 1)
- count 1 less BM for breaking
Results: this variation gave the Demiurg a lot of advantages against SM, Eldar and Guard, but was of little help with the Orks (or so it seemed) similar to #9.
Conclusion: the idea shows promise, but larger formations might break its back. This one is still in the mix.
Suggestion #7 ? Squat formations remove d6 Blast Markers during the Rally Phase.
Results: in these tests I ended up with results similar to #5. Smaller formations were free of BM every turn.
Conclusion: as per #5 this would make small formations nightmarish and give mixed results to large formations. It?s not workable IMO.
Armor Save variant:
Suggestion #8 ? The Squats are allowed to make Armor Saves against automatic kills during Assault Resolution and when shot at while Broken.
Results: given the decent armor saves the Demiurg enjoy this makes them even tougher giving them an ability similar to ATSKNF although it does require a saving throw. It allowed the Demiurg the chance to get back in the fight, but the formation doesn?t suffer the effects of losing assaults as intended by the rules, it watered down the victory for the opponent and preserves the strength of the Demiurg. SM, Eldar and especially IG and Orks suffered enhanced casualties due to surviving Demiurg.
Conclusions: Survivability does not really cover stubborn. This gives them toughness that is too similar to Marines. Given their overall numbers it minimizes assault results. I don?t think this will work for them.
Suggestion #9 "Each game turn, Squat/Demiurg formations ignore the first Blast Marker place on the formation, all other effects, such as Hold Actions, extra Barrage BM, losing Assault resolution and casualties are applied as normal."
Results: this is similar to #6 in terms of game effects. The key difference was that in a failed activation roll. They got no BM, which aided them in a few assaults.
Conclusion: this on comes off as it caused odd results. # 6 seems like a better way of representing the same mechanic.
Suggestion #10 An extra D6 when Regrouping (rolling 3d6). Either on a Hold-Regroup or Marshall action.
Results: really helps the odds and makes regrouping a decent choice for the Demiurg. Small formations are revitalized almost automatically. It works with stand off tactics. It was helpful in every game and gave everyone but Orks a heard time.
Conclusions: I don?t think this is a best case for the Demiurg, as it promotes static gameplay and the units most likely to use it, such as War Engines, would benefit unduly. Additionally the formation sizes rarely go above 10 units so even infantry could use this to minimize the game effects of BM.
Suggestion #11 With the Demiurg possibility of boosting the size of the unit, an upgrade to a second leader unit could come along with increasing the size of its formation. 2 leaders for an expensive 14 unit formation would not be over the top, would it?
Results: Did not test this, but I want to consider this. From Fredmans.
Suggestion #12 Here?s something else, again a part of ATSKNF. Squats take twice as many BM's to suppress/break. Just that bit of the rule. That makes them tenacious, whilst leaving them to die like dogs in a failed assault and not shift BM easily.
Results: Did not test this With formations averages of 10 it would take a lot of effort to break when and if they are in an assault they would be likely to start assault resolution with a -1, too much of a trade off IMO.
Suggestion #13 If you want a bit odder, twice as many just to break, so one BM, one suppression still, but entirely suppressed formations don't break as quickly as other armies.
Results: Did not test, formations that are fully suppressed with extra BM would be very hard to make combat effective.
Suggestion #14 One thought on the subject would be to allow the Squats to re-roll any dice that comes up as a "1" in the assault roll off. Thus allowing them to never suffer the negative of a pair of ones, but allowing a better chance for a pair of twos.
Results: Did not test. This bears more thought. It is similar odds wise to the Thurgrim rule, but only comes into play if a 1 shows up, I like it!
Squat/Demiurg Army Co-Champion (in cahoots with Jaldon)
PostPosted: Sun Jun 08, 2008 3:58 pm
At this point the options (or mix of options) that appear viable are:
Thurgrim?s Stronghold ? Squats are stubborn and are hard to break in assaults, and will rally quicker then other troops to get back into the fight and the following two rules represent this.
Suggestion #11 - With the Demiurg possibility of boosting the size of the unit, an upgrade to a second leader unit could come along with increasing the size of its formation. 2 leaders for an expensive 14 unit formation would not be over the top, would it?
Suggestion #14 - One thought on the subject would be to allow the Squats to re-roll any dice that comes up as a "1" in the assault roll off. Thus allowing them to never suffer the negative of a pair of ones, but allowing a better chance for a pair of twos. (editors note: as this idea comes from Jaldon, I would suggest this be considered as a toned-down version of the original Thurgim?s assault resolution rule)
Based on Jaldon's tests and my thread above does anyone else have any reactions, opjections or considerations?
Keep in mind he and I are were sort of split on #8, but our tests seem to concur on a lot of the others.
PostPosted: Sun Jun 08, 2008 6:54 pm
That was some intense testing. A great big thanks for that effeort on behalf of all us squat commanders!
I sat down and looked at this stubborn thing.
With AR 5+ I'd say that the rest of being Stubborn shouldn't be much. Some small addition to this would be quiet enough.
Personally I feel a 5+ or 6+ save against first BM would be an ok addition.
That is... Keep the head down and move on. That's stubborn to me.
Background thinking:
Imperial Guard and Eldar Guardians have no save at all, but either lots of soldiers or some hefty special rule.
Orks are tough customers and have some nice specials too.
Space Marines are hard nuts to crack, hefty special rule and cost a furtune.
Squats are somewhere between all this.
They are resilient and do carry armour, atleast more than IG, Guardian and Orks. They are few and expencive. But not as much as Marines.
Tuned up IG, tuned down Marine, allmost an Ork... And I don't want to keep track of another thing. Thus good 5+ armour and a "inv" save for first BM.
But I'm ranting, but then again I don't think I saw this in the testing.
Only a save towards those dratted "we're as good as dead lads" extra kills.
- Erik M
PostPosted: Mon Jun 09, 2008 3:32 pm
(rpr @ Jun. 07 2008,08:35)
rpr:  I think messing with assault resolution in such an extreme way is a bad idea in general.  It is going to do a lot of weird things, including the squats wanting to lose if it's due to a bad roll.
"I'm at +3 and... I lost!  Awesome!  Now I get to stand around and crush even more of the enemy."
Assaults are devastating in the game and frequently decisive.  It's intended to work that way.  Ignoring about half the losses is a huge change.
Basically, it's going to emphasize kills over non-kill modifiers and it's going to make assault results more extreme, either because a bad-luck loss for the Squats turns into a slaughter or because the Squats can't break and run when the enemy is winning and have to stand there and be crushed.
From epilgrim's description of the testing, it certainly sounds as if that's exactly what they observed.
PostPosted: Mon Jun 09, 2008 3:59 pm
A lack of viability to me doesn't seem apparent, only a lack of interest in re-tooling the point values which you will need to do anyway if you remove the +1 inspiring rule.  Regardless of what you and Jaldon decide, any change will require a review and possible change of point values and formation sizes.
But going back to the re-roll on rallies, I suppose that could be stomached if the other abilities (+1 inspiring, re-rolling in assaults) were removed.
PostPosted: Mon Jun 09, 2008 4:36 pm
Moscovian @ Jun. 09 2008,15:59
Seeing as no one wanted to tackle re-costing the Eldar to incorporate Spirt Stones, I certainly don't need the headache ;)
Regardless of which option we settle on there may be some changes in cost or composition, but as the formations that are most likely to benefit from a Spirt Stones type rule seem to be significantly enchanced by its use, I am inclined to pass on the option and explore other less dramatic effects to illustrate stubborn.
Lastly, I am looking for a best fit option, not a group of rules. If another rule does a better job than the rule currently used by the Demiurg, then my original rule would be discarded.
If in fact the Spirit Stones effect was the best way of showing Stubborness, we can always go back to it. For now I intend to refine the focus to play test only a few options.
PostPosted: Mon Jun 09, 2008 4:49 pm
Suit yourself.  I like the Demiurg list as is.  I only agreed that the inspiring doesn't fit thematically with being stubborn.  If they were the Pilgrim list fighting in their Mayflowers and shooting corn guns then the list would be perfect.  It's all in a name. :devil:
PostPosted: Tue Jun 10, 2008 11:51 am
(Moscovian @ Jun. 09 2008,16:49)
A project for another thread perhaps  :p
PostPosted: Tue Jun 10, 2008 12:15 pm
Played a game against the squats at the weekend. I was using a hastily constructed LaTD list (tzeentch) with no forethought into how I would possibly summon a greater daemon with no augmenting!
Anyway, my opponent was using the new list (don't know which version but I'll find out - Thorgrims Stronghold) and had leviathan,colossus, 2 goliaths, thunderfires and thudd gun batteries along with berzerkers, brotherhood, hearth and exo suits.
The 2 / 3 dice roll for morale/ engaging seemed to do the trick of having them either stay and win the combat or if losing, not by much and the end phase removing BM really worked well for him.
Since our last game he had multiple smaller units that easily out manoeuvred me and he won convincingly in 3 turns - all I had left that wasn't routed was my super heavies!
The war engines were excellent and only took a beating from serious sustained firepower from my tanks. He noted that he would try giving his berzerkers transports for next time.
Anyway, hope this helps list development.
Epic:Armageddon... Like Apocalypse but for grown-ups.
[b]Bearded Dice[/b]: [url]http://bearded-dice.co.uk[/url]
PostPosted: Tue Jun 10, 2008 12:39 pm
every comment helps!
would you happen to remember if your side won any of the assaults, or if the squats ever failed to rally?
What would you say was the most likely reason you lost?
PostPosted: Tue Jun 10, 2008 12:51 pm
Squats never failed to rally, hearth guard bikes were broken by leman sqdrn and fled but rallied immediately.
2 engagements - my mech coy w/ hydras, hellhounds and D. Prince assaulted a lone overlord and drove it back with 1 damage (shocking really!). My garrisoned infantry were assaulted by berzerkers and exo suits and they lost and fled.
Not much else happened. D Prince + squad after assaulting overlord were utterly routed by colossus and never came back.
Reasons why I lost: pretty much my list was thrown together to see how it plays (never failed an activation with my tzeentch themed guard), too few activations (coven,coven, leman russ, baneblade squad, doomwings, 3 firelords). When I could engage I did and did so on mostly my terms. There were just too many opposing units to take out. I managed to damage the leviathan transporting the brotherhood but unfortunately the transported had already disembarked so my critical did not much.
The only things I was scared of in the army were the thudd gun battery and the anti air bubbles from the squats. Is there a fluff reason why the guns are 60cm AA?
D.
D.
PostPosted: Tue Jun 10, 2008 2:03 pm
It's the 40K universe there are fluff reasons for everything!
I agree that low activations can make any alternating sequence game a challenge.
With regard to the thunderfire AA gun, if I remember correctly, prior to the Space Marine hunter, Eldar Fire Prism and Necron pylon the thunderfire was the pinnacle of AA technology both in range and firepower.
As it stands (IMO) the thunderfire is tied for third in range with the hunter, and tied for second in effectiveness with the hydra.
Thanks again for the game details, if you play against them check in and let us know how it went.
PostPosted: Tue Jun 10, 2008 2:31 pm
No worries. My regular opponent loves his l'il stunties and he is itching to get another game soon however it's Bloodbowl tomorrow so it will have to wait til next weekend.
I'm dying to try out a few nid armies but waiting for some models.
D.
PostPosted: Wed Jun 11, 2008 4:49 am
Going to put together a couple of flash games to test the proposed ideas mostly modified ATSKNF
BUT I am also going to put together a 3,000 point Squat Thurgrimm/OrkGhazgkull battle against my old foe Choorok, pesky greenskin :alien: Straight fight no changes.
Anybody up for a batrep with maps to pick Thurgrimm's list apart with?
Jaldon :p
Tyranid AC
