Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Demiurg v4.0 the short version
 Post subject: Demiurg v4.0 the short version
PostPosted: Tue Oct 27, 2009 12:10 am
Quote: (Hena @ Oct. 26 2009, 17:53 )
Quote: (Moscovian @ Oct. 26 2009, 15:48 )
Gorgon.  Frogbear actually agrees with me on this.  I felt that the walker ability should be used (not for the same reasons as he used but) because it eliminates a special rule.  A 1/36 chance is very close to zero and almost any chance to get rid of special rules should be considered.
I've lost countless of Carnifexes with walker before the special in Tyranids. I used to call forests Carnifex killers :smile:. That said I agree with you and frogbear. Walker is for this and removal of special rule.
Hena,
I am very familiar with Moscovian's position on Special Rules and on this particular unit, however, I am not entirely sure I understand your reasoning. You think the rule for the Gorgon should be removed, but it is ok for Tyranids to have the same rule?
Why is Walker unsuitable for Tyranids, yet fits this unit better?
Squat/Demiurg Army Co-Champion (in cahoots with Jaldon)
PostPosted: Tue Oct 27, 2009 12:30 am
Quote: (Hena @ Oct. 26 2009, 17:47 )
Quote: (epilgrim @ Oct. 26 2009, 15:45 )
Quote: (The_Real_Chris @ Oct. 26 2009, 13:24 )
I too am surprised at the speed 20cm WE. In testing the CI for guard it was found 15cm was too fast and if fact would be better at 10cm. This was because one march and it was at the half way line and the objectives you had placed there.
Fair point and I was not overjoyed at adding the speed either, however due to low DC and discussions with Jaldon on the Squat list we found that the Leviathan was a potential "death-ride" and rarely got where it needed to go.
I dunno. I've used Orkeosaur (6DC with no shields) with Ferals and so far it has not been a death trap. I don't see how Leviathan would be much different.
The 4 DC on the Leviathan profile is a problem. I can see if adding DC helps.
PostPosted: Tue Oct 27, 2009 2:49 am
Quote: (epilgrim @ Oct. 26 2009, 22:19 )
If you choose to discuss this topic or your previous questions I will respond. If not, then enjoy those parts of Epic that suit your gaming.
If you are going to take my observations seriously, then I will expand on those observations when I get a little bit more time. I am not being flippant, and I understand the troubles you go through as an AC. It is just a fact that I personally do not like being dismissed in a sarcastic way when I have (what I see as) valid questions.
PS Since your follow-up was in essence a separate thread question I suggest you search the various posts and find out for yourself what has transpired over the years since this list was introduced.
I would hope as the AC you could give some quick fire examples from these past discussions in relation to observations. If there are reasons, then that is fine. However they are not evident from the list or from your responses.
Like I said, I will come back to this with further in-depth observations of the points and see if I can either change the thinking, or be "educated" in the reasonings for something not conforming to another view.
PostPosted: Tue Oct 27, 2009 6:01 am
What is the current profile of the Capital Imperialis? There may be some common ground to re-examine this, although I am loathe to add DC to any of the MCF profiles...still worth pondering.
I believe it was tested at 6dc with 2 void shields, so yes tougher.
But even so the beast is tougher than say a brace (7) of chimera (10 1/2 hits to kill all the chimera vs 16 baring criticals) with more CC and FF hits as well (8/3 compared to 7/3 FF), all the WE benefits and all its guns. Stick it on a road and you are laughing. Hell march it up 60cm and next turn activate the formation inside followed by the leviathan itself (if you don't simply disembark into cover).
PostPosted: Tue Oct 27, 2009 11:28 am
sadly the only viable exchange for speed seems to be additional DC, which would mess up the uniformity of the MCF platform.
needs a few run throughs to consider...thanks for the notes on the CI.
PostPosted: Tue Oct 27, 2009 11:33 am
Quote: (Moscovian @ Oct. 26 2009, 22:48 )
Frogbear I believe has just recently added to his litter, and as such might be a bit testy due to a lack of sleep.
Mosc. You know nothing. Those that know nothing should keep their uneducated opinion to themselves. Especially when we have a less than favourable history.
Despite the fact that I think his tone sucks,
Do you really want to start this...?
Keep it civil.
PostPosted: Tue Oct 27, 2009 11:53 am
Without retreading or clashing further I did answer most of your observations in a very direct manner that does not require detailed examples or fact finding.
AS you may have note two of your observations spawned discussion into practical application of the rules and the reasoning behind them without requiring reference or research. Everyone who contributed was "up to speed" and adds thier own sense of the concepts allowing the discussion to flow regardless of outcome.
As AC I have agreed to continue to develop the lists and provide support, however I do not have time to function as a historian or librarian for each member of Tactical Command; my own time is limited and I rely on folks here to browse or search the threads if they are coming to the discussion fresh.
I look forward to hearing what you have to say, and the basis for it, whenever you have the opportunity.
PostPosted: Tue Oct 27, 2009 12:04 pm
The tyranids have it in very wide front (not in unit but as general rule) as they have a lot of LVs and AVs. So you don't have to remember it for one unit. Also it reduces the amount of rolling in turn in drastic amount. Tyranids are living creatures so they are really a lot better at moving in that kind of terrain than any tracked AVs are. I didn't push for the rule in Tyranids but can see it's application to be more understandable.
Ok, I see your point. As for sticking to the Collector's profile (mostly) the Gorgon was a particularly tough AV just below WE but designed as survivable - hence the special rule.
It is probably more to the point that so few people have them or have seen them fielded that this topic is rarely discussed.
PostPosted: Tue Oct 27, 2009 1:39 pm
Personally I had been thinking I'd likely sell off the small squat army I'd inherited (as they're not seen much in current W40k), but thinking about it I realised that was really stupid reasoning and that they're a fun and different army that I'll will keep and game with. There are lots of other armies I'll probably try first but I will the short chaps a try some time down the line.
Few comments on the list and the discussion:
I'd say Walker would be best for the Gorgon rather than a special rule. It is a sturdy vehicle with an armoured prow but it shouldn't be able to go straight through dense woods or ruined buildings as though they weren't there.
There are precedents for other bike scout units in both W40k and epic - e.g. SM Scout Bikers and certain Ork bikers in the Speed Freaks list. The former and the Squat ones could drive quietened ones but the Ork bikes are characteristically noisy.
Airship doesn't have to have low-tech connotations, it seems quite feasible to me a high tech one could fly lowish to the ground and so use cover as a skimmer. Iron Eagles are large and clearly Armoured Vehicles too.
It doesn't want to seem to let me download the siegemasters pdf at the mo but what are the rapiers and tarrantulas profiled as there? Probably best to follow the lead of there re: mounted or not IMO since these are basically the same guns.
Think 15cm for the Leviathan sounds more sensible than 20cm, but this is without personal testing.
Didn't all Squats used to move 10cm in the SM/TL days or am I mis-remembering? That limits their mobility horribly, but seemed very characteristically for short little legged troops.
PostPosted: Tue Oct 27, 2009 6:10 pm
Keep it civil.
Frogbear, I am hard pressed to find a civil tone in your posts within this thread. That isn't me being uncivil; it is me being observant.  And leave it to you to focus on negative things as opposed to the fact that I agree with half your arguments.  You calling me uneducated would be not only incorrect but obtuse.  Whereas I made an assumption based on this thread...
http://www.tacticalwargames.net/forums/ ... l=frogbear
... I found it unlikely for you to lie about having a child and you don't seem like the type to stick your wife with all the hard work.  Given that your tone did/does suck, you missing sleep seemed like the most plausible explanation.  In a convoluted way, I was coming to your defense.
PostPosted: Tue Oct 27, 2009 6:22 pm
Didn't all Squats used to move 10cm in the SM/TL days or am I mis-remembering? That limits their mobility horribly, but seemed very characteristic... for short little legged troops.
GlynG, I agree with you.  ePilgrim and I have played this army into the ground and it is IMO well done.  However, just because it works mechanically doesn't mean something isn't out of sorts with it.  15cm seems to be the upper limit for something like this given it is the same core technology as Imperial WE's.  If something else in the stats needs to be modified because of it, then so be it.
However, I am not convinced the unit couldn't suffer a -5cm on its move and still be just fine.  I would playtest them but I seem to be missing pictures to help me ID which units are what. (glances over at ePilgrim then looks away) :whistle:
PostPosted: Wed Oct 28, 2009 1:06 am
This is part of a set of very recent comments that I will consider. I am mulling an adjustment to the profile and the use of Walker.
Siegemasters rely primarily on fixed positions; the Demiurg are more flexible and adding Mounted to the profile would limit one of their core formations and upgrades. Suffice to say these profiles work for this army.
I am revisiting this along with the Gorgon, there are plenty of gameplay reasons to consider both sides of the issues, but they cannot be discussed and resolved without playtesting the impact.
True, they did move at 10cm in SM/TL, but that is not acceptable for Epic Armageddon. At this scale considering their ability to move at 2/3rds the speed of standard infantry is a unnecessary rationalization. As for fluff reasons: In a strictly fictional sense a creature from a high gravity environment would potentially have much quicker reactions and be proportionally faster and stronger than a being from a normal grav environ. (BTW: I stole that rationale from John Carter, Warlord of Mars and the Honor Harrington series).
PostPosted: Wed Oct 28, 2009 10:09 am
Siegemaster Thudd gun and rapier is not mounted, just normal 10cm move infantry.
