WAAAR again 26K Squats VS 39K IG, SM and TL
 Post subject: WAAAR again 26K Squats VS 39K IG, SM and TL
PostPosted: Fri Apr 03, 2015 12:19 pm
1st just a few pics from the terrain setup, this game is played from short to short side(2,8m x 2m)
 Post subject: Re: WAAAR again 26K Squats VS 39K IG, SM and TL
PostPosted: Fri Apr 03, 2015 1:40 pm
Will post Armies later
Here is the setup with troops, Squats fully deployed except tunneling troops.
Imperium has set up just artillery units and Titans&Kinghts to make a artillerystrike in the 1st turn,
suppored by 12 Maraudeurs.
PostPosted: Fri Apr 03, 2015 2:08 pm
I guess this is why it is called epic!
PostPosted: Fri Apr 03, 2015 4:18 pm
great to see you back in action ulric!
PostPosted: Fri Apr 03, 2015 6:13 pm
Hi Apoc, nice to see you here.
;D Inthought about a battle for several month now.
During the eastern time I found time.
Now here is the 1st turn after Firstfire
The Imperial artillery destroyed several wall sections so the groundforces could more easy advance
and collapsed many buildings with squats inside
after advanced even mor sections and buildings got detroyed
and the 1st squat defens line took heavy damage
in return the Squats managed to down many shields of the imperial Titans
although a lot of artillery fire missed or styed harmless
poor result
dp.
PostPosted: Sat Apr 04, 2015 1:16 am
Turn 2
the main forces arrive...well most of it ;D
End of Turn 2
PostPosted: Sat Apr 04, 2015 2:10 am
Simply awesome beyond words!
PostPosted: Sat Apr 04, 2015 9:17 am
Wow!! That is a BIG battle!
Gwydion
PostPosted: Sat Apr 04, 2015 9:45 am
Hi Primarch :),
glad you like it.
Here is what happend during the 2nd Turn
the artillery managed to down mor ewall sections and buildigs, "cleaning" the 1st part of the cirty from heavy struktures
A lot of squats units turned up to be out of range but the others caused the Imperium pain.
The Goliath mega cannons combined with Doomsday cannon fire and Rad bombs destroyed dozens of SM and IG tanks.
In return the Ordinatus fired a 2nd time at the Squats artillery placed on the big stronghold,
and a 2nd time it managed to destroy nothing, both GMC got hits on thier SHdamage tables though.
The Squat Preatorians in the 2nd defense line dealt out hevay blows with heavier IG stuff.
During this exchange of death the Reaver Titans turned out to have not enough shields for frontline actions, one got destroyed while another one survived only with the strenth of it´s armour.
On the other side the Squat Leviathan lost it´s battle and doomsdaycannon
QUESTION:
I remember reading a rule, that each hit on a hitlocation template increases the penetrating bonus by 1, is it out there or was it just a wish?
QUESTION2: if a hit location, is hit by a weapon which uses "penetrating bonus"(Vulcano canon, Cyclops main weapon)
and causing a flashback(weapon), does the penetrating bonus aply for the flash back-damaga roll too?
That is very important in Squat battles cause of the penetrating bonus+5 from the Cyclops main weapon
Back, in the CC segment the Squats fight very well,
can you belive that I forget about, in EVERY of my Squat battles, that the Squats are able to re-roll a "1" during
in every single oneCC :{[]
The Marines took heavy casualities and started wondering if anyone of them would survive the day.
In the Advance phase, the Marines, IG and Imperial Navy cleand the 1st city parts.
In Turn 3 the 2nd IG tank batallion will arrive.
PostPosted: Sat Apr 04, 2015 10:00 am
Turn 3
more IG troops arrive
After movement
After first fire,
in this turn the GMC were very accurate and killed several tanks
The Squats deytroyed a Warhound and crippled another while one Reaver took little damage to the head,
the Imperium concentrate now their fire at the heavy squat stuff and exterminated the already damaged Leviathan and one Cyclops
Pics from Turn 3
dp.
PostPosted: Mon Apr 06, 2015 11:44 am
Turn 4 now boys
parts of the IG artillery moved forward others got pulled by Chimeras
While the main forecs pushed over the bridges.
GREAT idea from me to place the most important bridge right in the middle of the table.
My back hurts so much now :{[]
I let Knights and SHT cross the river without bridge
The 1st tanks which crossed the bridge got attacked by Squat bikes
while Ironshield tanks welcomed the disembraking INf with Bolter an A.Cannonfire
The City suffered a lot lossing about 15 bulidings and bunkers up to now
(I used bail out rolls on any Inf. in collapsing bulidings)
ran out of small ruins very fast ;D
more Warhounds got destroyed by accurate Squat fire
Bloody CC fights in the center
The 1st wave of airborne troops (1 Scout CO) secured the flank of the big bridge
while IG armour rushed over it
Turn 4 end
Artillery support
god I love these minis
Again Imperial advanced fire destroyed most of the CC remains
But the Squats fought though at any frontline
and caused the Mrines more and more casualities
PostPosted: Mon Apr 06, 2015 11:52 am
Turn 5
my Plan was to play up to 8 Turns but MRS Ulrics strats to grumble :sos
The IG and SM had to hurry
So I decided to bring in more airborne support, 3 units of Thunderbolts escorting 3 more T-Hawks
I had used 5 t-hawks in the 4th Turn and lost 2 so I had 3 left, to bring in a battle Co another Scout det. and the Command Units and the Chaplain
Imperial artillery moved up to get a direct LOS
One of the artillery COs now mode use of their tracktors
Obiously my most favorite minis ;D
PostPosted: Mon Apr 06, 2015 12:07 pm
Turn 5
Squat Gyrocopters draw back
while the 2nd Squat defense was under heavy attack
a steady advance over the big bridge
Squat arillery caused here incredible damage
In the center the Marines got supported by Ig Tanks and Chimeras
the advancing heavy tanks cleared the buildings and ruins from the last defenders
Turn 5 after FF
